    Installing on a Pi Zero
    175 Posts 33 Posters 303.4k Views 33 Watching
      Big11 @andyc7687
      @andyc7687
      as for your Question
      i’m installing over SSH but start it then directly on the Pi0…
      i will i try a new Installation by now…
      normally i don’t run “npm install” as root…
      don’t know if i wrote so…
      B 1 Reply Last reply
        Big11 @Big11
        @big11
        thats my “achievment” from last night…
        pi@raspberrypi:~ $ cd MagicMirror/
        > magicmirror@2.6.0 start /home/pi/MagicMirror
        > sh run-start.sh
        run-start.sh: 4: run-start.sh: electron: not found
        npm ERR! file sh
        npm ERR! code ELIFECYCLE
        npm ERR! errno ENOENT
        npm ERR! syscall spawn
        npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.6.0 start script.
        npm ERR!     /home/pi/.npm/_logs/2019-01-10T07_11_11_053Z-debug.log
          12wsx
          finally full success!!:)
          @big11 install directly from raspberry terminal not via ssh.
          After few fresh installation and hundreds errors last time tried install using
          bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)"
          from raspberrypi terminal.There were some errors but finally worked.
          if you want, I can make a image of my card and share it.
            Big11 @12wsx
            @12wsx
            you made my day…
            it works…
            the first differences i encountered was the Installation of electron …
            this i didn’t found at all the others…
            and i thought before, that this will be the quest…
            regarding to the warnings installing npm
            you could fix that with “npm Audit fix” or “npm Audit fix --force”
            as suggested…
            i did this also, so maybe this could be an error too…
            and if it works but this warnings, who cares…. :-)
            have a great day…
            thank you
            • W
              Wordonroad
              Awesome write up. Super helpful!
              • qu1queQ
                qu1que Project Sponsor
                Thank you very much for this work! The tutorial works perfectly. I just installed it in a rpi zero W. Highly recommended for anyone who wants to install it on this SBC.
                  cdh1001
                  Many thanks Andrew - worked well for me (other than first step: connecting to wifi with WPA2 needed some minor tweaks.)
                  A 1 Reply Last reply
                  • A
                    andyc7687 @cdh1001
                    @cdh1001 please specify tweaks as they might help others.
                    C 1 Reply Last reply
                      cdh1001 @andyc7687
                      @andyc7687 - I needed to delete the line: key_mgmt=WPA-PSK Based on discussions elsewhere I originally tried renaming Key_mgmt to WPA2 and/or changing group=CCMP, but neither of those were necessary for me; simply deleting the line was sufficient.
                      • A
                        andyc7687 @cdh1001
                        @cdh1001 thanks, I will amend my guide over the weekend then.
                          Smolo
                          Thanks for the script and the hints so far :-)
                          Unfortunately I am really frustrated after x installations. :-( Currently everything is installed the autostart works but chrome says “err_connection_refused”!
                          Does anyone have an idea?
                          Zero W V1.1 / Raspian Desktop / no sudo
                          bheplerB 1 Reply Last reply
                          • bheplerB
                            bhepler Module Developer @Smolo
                            @smolo Some suggestions: First, make sure that some form of IP address is present in the address key. Usually 127.0.0.1, but the IP address of your pi will probably work too. Without that value, the web server has a tendency to freak out.
                            Second, make sure you are specifying the port in your web call. That one has bitten me a couple times.
                            Third, I would double-check your IP whitelist in the config.js. Possibly open it up to all connections and attempt to view the magic mirror from another computer. See if the problem is local to the PI Zero or if it is on a deeper level.
                              Smolo
                              @bhepler
                              First, as a supplement the installation is absolute standard except for another VNC server.
                              Chromium starts automaticly with http://localhost:8080
                              I have already tested the following constellations before my post.
                              the local ip (192.168.2.84:8080)
                              127.0.0.1:8080
                              localhost:8080
                              with https browser fault > “err_address_unreachable”
                              Other things :…
                              • ublock is inactive!
                              • Configuration vom MagicMirror Config:
                                var config = {
                                port: 8080,
                                address: “0.0.0.0”,
                                ipWhitelist: [],
                              • Test from another pc > “err_connection_refused”
                                Smolo
                                I’ve solved the problem and it’s going crazy. After I tried with a portscanner to find out if there is anything running I found out that there is no port 8080 open.
                                If somebody has problems checking the logs via "pm2 logs MagicMirror --lines 1000
                                I missed the npm module “moment” under “/home/pi/MagicMirror/node_modules/moment”!!!:astonished_face:
                                Go to MagicMirror > “npm install” the problem was solved!:slightly_smiling_face:
                                • A
                                  AnalogCHeep
                                  @andyc7687, thanks a lot! It will be easy for me now, I planned going for building a device like yours
                                  Regards
                                  • A
                                    andyc7687 @AnalogCHeep
                                    @analogcheep thanks, let me know if yours works and upvote if it is helpful!
                                      12wsx
                                      today i have to reinstall MM and I have some small problem. MM do not show on local hdmi outpul- I can see the dektop but no MM. Server is working properly because when I open it from laptop i can see MM, when I connect to raspberry pi via vnc i can see to MM. What is going on? what i miss?
                                        sdetweil @12wsx
                                        @12wsx in terminal, or script u use to start mm do
                                        export DISPLAY=:0
                                        Then npm start
                                          12wsx
                                          thank you for help, i had to reinstal system once more becase there were a lot of errors.
                                          After new instalation pm2 didn’t start properly. after few hours i found why.
                                          In pm2_MagicMirrorPi0.json
                                          line:
                                          “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
                                          should be :
                                          “script” : “/MagicMirror/PiZero/startMagicMirrorPi0.sh”,
                                            which installer are you using? I don’t see the filename pm2_MagicMirrorPi0.json
                                            or “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
                                            in the raspberry.sh script…
                                            • 2 / 9
