    Installing on a Pi Zero
    175 Posts 33 Posters 292.0k Views 33 Watching
      Big11 @andyc7687
      @andyc7687
      i run just
      bash -c “$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)”
      don’t know if this leads to bare or Pi0 …
      This is your “modified” installer script also for the Pi0…
        andyc7687 @Big11
        @big11 this goes to my forked repo. Are you booting through to the desktop or to the console?
          Big11 @andyc7687
          @andyc7687
          so since yesterday i installed many times from Scratch but without success……
          With your script i ran into Troubles with a lot of Errors…
          missing dependencies….
          so i suggest to do more steps after “sudo apt INSTALL --fix-missing” -> “apt UPGRADE --fix-missing” does not work…
          sudo dpkg –configure -a. and.
          sudo apt install -f.
          at npm install a lot of Warnings e.g.
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          added 921 packages from 1366 contributors and audited 2466 packages in 859.404s
          found 8 vulnerabilities (7 low, 1 high)
            run `npm audit fix` to fix them, or `npm audit` for details
          Errors while installing dependencies! (source command: npmc@latest install)
          + stylelint@9.9.0
          added 156 packages from 107 contributors, removed 32 packages, updated 99 packages, moved 6 packages and audited 4452 packages in 370.707s
          found 4 vulnerabilities (3 low, 1 high)
          Errors while installing dependencies! (source command: pm install stylelint@latest)
          pi@magicpi:~ $   run `npm audit fix` to fix them, or `npm audit` for details
          npm ERR! code EAUDITNOPJSON
          npm ERR! audit No package.json found: Cannot audit a project without a package.json
          npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_26_138Z-debug.log
          npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_35_497Z-debug.log
          -bash: run: Kommando nicht gefunden.
          pi@magicpi:~ $ Errors while installing dependencies! (source command: pm install stylelint@latest)
          -bash: Syntaxfehler beim unerwarteten Wort `('
          i could fix this with
          "npm audit fix" or "npm audit fix --force" in directory MagicMirror
          and then i figured out autostart with PM2 as described in MM-Wiki but…
          it won’t start …
          as done in the guide i created a mm.sh script und configured this for autostart with pm2
          at next start Nothing happens to start MagicMirror localy
          a “pm2 logs mm”
          Shows a loop of “sh run-start.sh”
          |mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
          0|mm       | > sh run-start.sh
          0|mm       |
          0|mm       |
          0|mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
          0|mm       |
          0|mm       |
          0|mm       |
          0|mm       |
          a cat to run-start.sh Shows
          pi@magicpi:~/MagicMirror $ cat run-start.sh
          if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                  export DISPLAY=:0 # Set by default display
          fi
          electron js/electron.js $1
          but electron.js isn’t installed
          trying manually install this with
          sudo npm install electron -g
          ended again in Error-Messages
          Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/electron/.electron'
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! electron@4.0.1 postinstall: `node install.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the electron@4.0.1 postinstall script.
          npm ERR!     /root/.npm/_logs/2019-01-09T09_13_51_893Z-debug.log
          so… now i’m giving up for These days….
          does anybody know where my Failure is ??
          Thank you
            andyc7687 @Big11
            @big11 I did a test install today, so I’m really not sure what you are doing.
            You will notice that the missing dependencies are installed in subsequent steps (e.g. there’s a problem with style lint and acorn. This is then fixed (see where it says + stylelint@9.9.0 and + acorn lower down in your warnings).
            This installation is completely different from the MM-Wiki. It does not use sh run-start.sh at all. Therefore there may well be problems.
            Can I ask, are you doing your installation over SSH/Telnet? or on the Pi itself? because you keep mentioning ‘locally’ and I just want to make sure I know what you mean by that.
            Edit: Also, don’t use npm install in sudo; it should be run as the normal user
              Big11 @andyc7687
              @andyc7687
              as for your Question
              i’m installing over SSH but start it then directly on the Pi0…
              i will i try a new Installation by now…
              normally i don’t run “npm install” as root…
              don’t know if i wrote so…
                Big11 @Big11
                @big11
                thats my “achievment” from last night…
                pi@raspberrypi:~ $ cd MagicMirror/
                > sh run-start.sh
                run-start.sh: 4: run-start.sh: electron: not found
                npm ERR! file sh
                npm ERR! errno ENOENT
                npm ERR! syscall spawn
                npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
                npm ERR! spawn ENOENT
                npm ERR!
                npm ERR! Failed at the magicmirror@2.6.0 start script.
                npm ERR!     /home/pi/.npm/_logs/2019-01-10T07_11_11_053Z-debug.log
                • 1 Offline
                  12wsx
                  finally full success!!:)
                  @big11 install directly from raspberry terminal not via ssh.
                  After few fresh installation and hundreds errors last time tried install using
                  bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)"
                  from raspberrypi terminal.There were some errors but finally worked.
                  if you want, I can make a image of my card and share it.
                    Big11 @12wsx
                    @12wsx
                    you made my day…
                    it works…
                    the first differences i encountered was the Installation of electron …
                    this i didn’t found at all the others…
                    and i thought before, that this will be the quest…
                    regarding to the warnings installing npm
                    you could fix that with “npm Audit fix” or “npm Audit fix --force”
                    as suggested…
                    i did this also, so maybe this could be an error too…
                    and if it works but this warnings, who cares…. :-)
                    have a great day…
                    thank you
                    • W Offline
                      Wordonroad
                      Awesome write up. Super helpful!
                      • qu1queQ Offline
                        qu1que Project Sponsor
                        Thank you very much for this work! The tutorial works perfectly. I just installed it in a rpi zero W. Highly recommended for anyone who wants to install it on this SBC.
                          cdh1001
                          Many thanks Andrew - worked well for me (other than first step: connecting to wifi with WPA2 needed some minor tweaks.)
                            andyc7687 @cdh1001
                            @cdh1001 please specify tweaks as they might help others.
                              cdh1001 @andyc7687
                              @andyc7687 - I needed to delete the line: key_mgmt=WPA-PSK Based on discussions elsewhere I originally tried renaming Key_mgmt to WPA2 and/or changing group=CCMP, but neither of those were necessary for me; simply deleting the line was sufficient.
                              A 1 Reply Last reply Reply Quote 1
                                andyc7687 @cdh1001
                                @cdh1001 thanks, I will amend my guide over the weekend then.
                                  Smolo
                                  Thanks for the script and the hints so far :-)
                                  Unfortunately I am really frustrated after x installations. :-( Currently everything is installed the autostart works but chrome says “err_connection_refused”!
                                  Does anyone have an idea?
                                  Zero W V1.1 / Raspian Desktop / no sudo
                                    bhepler Module Developer @Smolo
                                    @smolo Some suggestions: First, make sure that some form of IP address is present in the address key. Usually 127.0.0.1, but the IP address of your pi will probably work too. Without that value, the web server has a tendency to freak out.
                                    Second, make sure you are specifying the port in your web call. That one has bitten me a couple times.
                                    Third, I would double-check your IP whitelist in the config.js. Possibly open it up to all connections and attempt to view the magic mirror from another computer. See if the problem is local to the PI Zero or if it is on a deeper level.
                                      Smolo
                                      @bhepler
                                      First, as a supplement the installation is absolute standard except for another VNC server.
                                      Chromium starts automaticly with http://localhost:8080
                                      I have already tested the following constellations before my post.
                                      the local ip (192.168.2.84:8080)
                                      127.0.0.1:8080
                                      localhost:8080
                                      with https browser fault > “err_address_unreachable”
                                      Other things :…
                                      • ublock is inactive!
                                      • Configuration vom MagicMirror Config:
                                        var config = {
                                        port: 8080,
                                        address: “0.0.0.0”,
                                        ipWhitelist: [],
                                      • Test from another pc > “err_connection_refused”
                                        Smolo
                                        I’ve solved the problem and it’s going crazy. After I tried with a portscanner to find out if there is anything running I found out that there is no port 8080 open.
                                        If somebody has problems checking the logs via "pm2 logs MagicMirror --lines 1000
                                        I missed the npm module “moment” under “/home/pi/MagicMirror/node_modules/moment”!!!:astonished_face:
                                        Go to MagicMirror > “npm install” the problem was solved!:slightly_smiling_face:
                                          AnalogCHeep
                                          @andyc7687, thanks a lot! It will be easy for me now, I planned going for building a device like yours
                                          Regards
                                            andyc7687 @AnalogCHeep
                                            @analogcheep thanks, let me know if yours works and upvote if it is helpful!
                                            • 2 / 9
