    Installing on a Pi Zero
    175 Posts 33 Posters 293.9k Views 33 Watching
    • 1 Offline
      12wsx
      same problem to me.
      using raspberry pi Zero (not W)
      installed latest Raspbian Stretch with desktop. update from first run creator.
      Full instalation LOG
      pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/     MagicMirror/master/installers/raspberry.sh)"
      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                             $$  __$$\
      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$     $\   $$$$$$\   $$$$$$\  \__/  $$ |
      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __     $$\ $$  __$$\ $$  __$$\  $$$$$$  |
      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |       \__|$$ /  $$ |$$ |  \__|$$  ____/
      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |           $$ |  $$ |$$ |      $$ |
      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |           \$$$$$$  |$$ |      $$$$$$$$\
      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|            \______/ \__|      \________|
                              \______/
      If you are running a Pi Zero, installation will continue, but you will have to r     un in server only mode.
      Updating packages ...
      Stary:1 http://archive.raspberrypi.org/debian stretch InRelease
      Stary:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
      Czytanie list pakietów... Gotowe
      Budowanie drzewa zależności
      Odczyt informacji o stanie... Gotowe
      Obliczanie aktualizacji... Gotowe
      0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
      E: Nie udało się otworzyć pliku blokady /var/lib/dpkg/lock - open (13: Brak dost     ępu)
      E: Nie udało się zablokować katalogu administracyjnego (/var/lib/dpkg/), czy uży     to uprawnień administratora?
      Update failed, carrying on installation ...
      Installing helper tools ...
      build-essential is already the newest version (12.3).
      curl is already the newest version (7.52.1-5+deb9u8).
      git is already the newest version (1:2.11.0-3+deb9u4).
      unzip is already the newest version (6.0-21).
      wget is already the newest version (1.18-5+deb9u2).
      Node.js is not installed.
      Installing Node.js ...
      Downloading node v11.6.0
        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                       Dload  Upload   Total   Spent    Left  Speed
      100 17.0M  100 17.0M    0     0   861k      0  0:00:20  0:00:20 --:--:--  968k
      Extracting node v11.6.0
      Extracting node and npm
      Zostaną zainstalowane następujące NOWE pakiety:
        unclutter
      0 aktualizowanych, 1 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
      Konieczne pobranie 16,6 kB archiwów.
      Po tej operacji zostanie dodatkowo użyte 47,1 kB miejsca na dysku.
      Pobieranie:1 http://ftp.icm.edu.pl/pub/Linux/distributions/raspbian/raspbian str     etch/main armhf unclutter armhf 8-20 [16,6 kB]
      Pobrano 16,6 kB w 1s (14,1 kB/s)
      Prekonfiguracja pakietów ...
      Wybieranie wcześniej niewybranego pakietu unclutter.
      (Odczytywanie bazy danych ... 80763 pliki i katalogi obecnie zainstalowane.)
      Przygotowywanie do rozpakowania pakietu .../unclutter_8-20_armhf.deb ...
      Rozpakowywanie pakietu unclutter (8-20) ...
      Konfigurowanie pakietu unclutter (8-20) ...
      Przetwarzanie wyzwalaczy pakietu man-db (2.7.6.1-2)...
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Enumerating objects: 305, done.
      remote: Counting objects: 100% (305/305), done.
      remote: Compressing objects: 100% (273/273), done.
      remote: Total 305 (delta 37), reused 169 (delta 22), pack-reused 0
      Receiving objects: 100% (305/305), 614.71 KiB | 747.00 KiB/s, done.
      Resolving deltas: 100% (37/37), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      npx: zainstalowano 405 w 218.392s
      npm notice CANARY npmc is experimental software. If you find an issue, please fi     le it in the main npm repository, and call out that you were using npmc.
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically un     maintained. Move on to something better. This package will continue to work with      Grunt v1, but it will not receive any updates.
      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@n     pmjs.com for more info.
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron     -chromedriver
      > node ./download-chromedriver.js
      successfully dowloaded and extracted!
      > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      Downloading SHASUMS256.txt
      [============================================>] 100.0% of 5.39 kB (5.39 kB/s)
      > magicmirror@2.6.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fse     vents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@     1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}     )
      added 82 packages from 57 contributors and audited 220 packages in 118.631s
      found 3 low severity vulnerabilities
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
      > cd fonts && npm install
      added 1 package from 1 contributor and audited 1 package in 42.42s
      found 0 vulnerabilities
      npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is      installed. You must install peer dependencies yourself.
      npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed.      You must install peer dependencies yourself.
      added 921 packages from 1366 contributors in 1049.638s
      Errors while installing dependencies! (source command: npmc@latest install)
      + acorn@6.0.5
      added 2 packages from 78 contributors, updated 1 package and audited 2467 packag     es in 175.814s
      found 8 vulnerabilities (7 low, 1 high)
      Errors while installing dependencies! (source command: npm install acorn@latest)
      + stylelint@9.9.0
      added 155 packages from 107 contributors, removed 32 packages, updated 99 packages, moved 6 packages and audited 4452 packages in 458.975s
      found 4 vulnerabilities (3 low, 1 high)
      Errors while installing dependencies! (source command: pm install stylelint@latest)
      + jshint@2.9.7
      added 2 packages from 1 contributor, removed 6 packages and updated 5 packages in 226.509s
      fixed 3 of 4 vulnerabilities in 4452 scanned packages
        1 vulnerability required manual review and could not be updated
      Vulnerabilities may remain!
      Check plymouth installation ...
      Splashscreen: Checking themes directory.
      Splashscreen: Create theme directory if not exists.
      Splashscreen: Theme copied successfully.
      Splashscreen: Changed theme to MagicMirror successfully.
      Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
      /usr/local/bin/pm2 -> /usr/local/lib/node_modules/pm2/bin/pm2
      /usr/local/bin/pm2-dev -> /usr/local/lib/node_modules/pm2/bin/pm2-dev
      /usr/local/bin/pm2-docker -> /usr/local/lib/node_modules/pm2/bin/pm2-docker
      /usr/local/bin/pm2-runtime -> /usr/local/lib/node_modules/pm2/bin/pm2-runtime
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/pm2/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + pm2@3.2.4
      added 313 packages from 246 contributors in 320.301s
      __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
       _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
        _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
         _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
          _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
           _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
            _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
             _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
              _\///______________\///______________\///__\///////////////__
                                Runtime Edition
              PM2 is a Production Process Manager for Node.js applications
                           with a built-in Load Balancer.
                      Start and Daemonize any application:
                      $ pm2 start app.js
                      Load Balance 4 instances of api.js:
                      $ pm2 start api.js -i 4
                      Monitor in production:
                      $ pm2 monitor
                      Make pm2 auto-boot at server restart:
                      $ pm2 startup
                      To go further checkout:
                      http://pm2.io/
      [PM2] Init System found: systemd
      Platform systemd
      Template
      [Unit]
      Description=PM2 process manager
      Documentation=https://pm2.keymetrics.io/
      After=network.target
      [Service]
      Type=forking
      User=pi
      LimitNOFILE=infinity
      LimitNPROC=infinity
      LimitCORE=infinity
      Environment=PATH=/usr/local/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
      Environment=PM2_HOME=/home/pi/.pm2
      PIDFile=/home/pi/.pm2/pm2.pid
      ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
      ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
      ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
      [Install]
      WantedBy=multi-user.target
      Target path
      /etc/systemd/system/pm2-pi.service
      Command list
      [ 'systemctl enable pm2-pi' ]
      [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
      [PM2] Making script booting at startup...
      [PM2] [-] Executing: systemctl enable pm2-pi...
      Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
      [PM2] [v] Command successfully executed.
      [PM2] Freeze a process list on reboot via:
      $ pm2 save
      [PM2] Remove init script via:
      $ pm2 unstartup systemd
                                Runtime Edition
                      $ pm2 start app.js
                      $ pm2 monitor
                      $ pm2 startup
                      http://pm2.io/
      [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
      [PM2] PM2 Successfully daemonized
      [PM2][WARN] Applications MagicMirror not running, starting...
      [PM2] App [MagicMirror] launched (1 instances)
      │ Name        │ id │ mode  │ status │ ↺      │ cpu │ memory │
      │ MagicMirror │ 0  │ 2.6.0 │ fork   │ online │ 0   │ 0%     │ 2.5 MB   │
       Use `pm2 show ` to get more details about an app
      [PM2] Saving current process list...
      [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
      We're ready! Restart your Pi Zero to start your MagicMirror.
      pi@raspberrypi:~ $ sudo login as: pi
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Mon Jan  7 20:33:42 2019
                              \______/
        unclutter
      > node install.js
      + acorn@6.0.5
      + stylelint@9.9.0
      + jshint@2.9.7
      Do you want usHasło:
      Nieprawidłowe logowanie
      raspberrypi login: rror (y/N)?y
      + pm2@3.2.4
                                Runtime Edition
                      $ pm2 start app.js
                      $ pm2 monitor
                      $ pm2 startup
                      http://pm2.io/
      Platform systemd
      Template
      [Unit]
      [Service]
      Type=forking
      User=pi
      LimitNPROC=infinity
      LimitCORE=infinity
      [Install]
      Target path
      Command list
      $ pm2 save
                                Runtime Edition
                      $ pm2 start app.js
                   Hasło:
      after reboot server work properly. If I connect from my computer webbrowser everythings is fine.
      On local LCD raspberry load to desktop and do not run chromium (default browser)
      sorry for 2 post one by one.
        Big11 @andyc7687
        @andyc7687
        i run just
        bash -c “$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)”
        don’t know if this leads to bare or Pi0 …
        This is your “modified” installer script also for the Pi0…
          andyc7687 @Big11
          @big11 this goes to my forked repo. Are you booting through to the desktop or to the console?
            Big11 @andyc7687
            @andyc7687
            so since yesterday i installed many times from Scratch but without success……
            With your script i ran into Troubles with a lot of Errors…
            missing dependencies….
            so i suggest to do more steps after “sudo apt INSTALL --fix-missing” -> “apt UPGRADE --fix-missing” does not work…
            sudo dpkg –configure -a. and.
            sudo apt install -f.
            at npm install a lot of Warnings e.g.
            added 921 packages from 1366 contributors and audited 2466 packages in 859.404s
            + stylelint@9.9.0
            added 156 packages from 107 contributors, removed 32 packages, updated 99 packages, moved 6 packages and audited 4452 packages in 370.707s
            pi@magicpi:~ $   run `npm audit fix` to fix them, or `npm audit` for details
            npm ERR! code EAUDITNOPJSON
            npm ERR! audit No package.json found: Cannot audit a project without a package.json
            npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_26_138Z-debug.log
            npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_35_497Z-debug.log
            -bash: run: Kommando nicht gefunden.
            pi@magicpi:~ $ Errors while installing dependencies! (source command: pm install stylelint@latest)
            -bash: Syntaxfehler beim unerwarteten Wort `('
            i could fix this with
            "npm audit fix" or "npm audit fix --force" in directory MagicMirror
            and then i figured out autostart with PM2 as described in MM-Wiki but…
            it won’t start …
            as done in the guide i created a mm.sh script und configured this for autostart with pm2
            at next start Nothing happens to start MagicMirror localy
            a “pm2 logs mm”
            Shows a loop of “sh run-start.sh”
            |mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
            0|mm       | > sh run-start.sh
            0|mm       |
            0|mm       |
            0|mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
            0|mm       |
            0|mm       |
            0|mm       |
            0|mm       |
            a cat to run-start.sh Shows
            pi@magicpi:~/MagicMirror $ cat run-start.sh
            if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                    export DISPLAY=:0 # Set by default display
            fi
            electron js/electron.js $1
            but electron.js isn’t installed
            trying manually install this with
            sudo npm install electron -g
            ended again in Error-Messages
            Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/electron/.electron'
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! electron@4.0.1 postinstall: `node install.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the electron@4.0.1 postinstall script.
            npm ERR!     /root/.npm/_logs/2019-01-09T09_13_51_893Z-debug.log
            so… now i’m giving up for These days….
            does anybody know where my Failure is ??
            Thank you
              andyc7687 @Big11
              @big11 I did a test install today, so I’m really not sure what you are doing.
              You will notice that the missing dependencies are installed in subsequent steps (e.g. there’s a problem with style lint and acorn. This is then fixed (see where it says + stylelint@9.9.0 and + acorn lower down in your warnings).
              This installation is completely different from the MM-Wiki. It does not use sh run-start.sh at all. Therefore there may well be problems.
              Can I ask, are you doing your installation over SSH/Telnet? or on the Pi itself? because you keep mentioning ‘locally’ and I just want to make sure I know what you mean by that.
              Edit: Also, don’t use npm install in sudo; it should be run as the normal user
                Big11 @andyc7687
                @andyc7687
                as for your Question
                i’m installing over SSH but start it then directly on the Pi0…
                i will i try a new Installation by now…
                normally i don’t run “npm install” as root…
                don’t know if i wrote so…
                  Big11 @Big11
                  @big11
                  thats my “achievment” from last night…
                  pi@raspberrypi:~ $ cd MagicMirror/
                  > sh run-start.sh
                  run-start.sh: 4: run-start.sh: electron: not found
                  npm ERR! file sh
                  npm ERR! errno ENOENT
                  npm ERR! syscall spawn
                  npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.6.0 start script.
                  npm ERR!     /home/pi/.npm/_logs/2019-01-10T07_11_11_053Z-debug.log
                  • 1 Offline
                    12wsx
                    finally full success!!:)
                    @big11 install directly from raspberry terminal not via ssh.
                    After few fresh installation and hundreds errors last time tried install using
                    bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)"
                    from raspberrypi terminal.There were some errors but finally worked.
                    if you want, I can make a image of my card and share it.
                      Big11 @12wsx
                      @12wsx
                      you made my day…
                      it works…
                      the first differences i encountered was the Installation of electron …
                      this i didn’t found at all the others…
                      and i thought before, that this will be the quest…
                      regarding to the warnings installing npm
                      you could fix that with “npm Audit fix” or “npm Audit fix --force”
                      as suggested…
                      i did this also, so maybe this could be an error too…
                      and if it works but this warnings, who cares…. :-)
                      have a great day…
                      thank you
                      • W Offline
                        Wordonroad
                        Awesome write up. Super helpful!
                        • qu1queQ Offline
                          qu1que Project Sponsor
                          Thank you very much for this work! The tutorial works perfectly. I just installed it in a rpi zero W. Highly recommended for anyone who wants to install it on this SBC.
                            cdh1001
                            Many thanks Andrew - worked well for me (other than first step: connecting to wifi with WPA2 needed some minor tweaks.)
                              andyc7687 @cdh1001
                              @cdh1001 please specify tweaks as they might help others.
                                cdh1001 @andyc7687
                                @andyc7687 - I needed to delete the line: key_mgmt=WPA-PSK Based on discussions elsewhere I originally tried renaming Key_mgmt to WPA2 and/or changing group=CCMP, but neither of those were necessary for me; simply deleting the line was sufficient.
                                A 1 Reply Last reply Reply Quote 1
                                  andyc7687 @cdh1001
                                  @cdh1001 thanks, I will amend my guide over the weekend then.
                                    Smolo
                                    Thanks for the script and the hints so far :-)
                                    Unfortunately I am really frustrated after x installations. :-( Currently everything is installed the autostart works but chrome says “err_connection_refused”!
                                    Does anyone have an idea?
                                    Zero W V1.1 / Raspian Desktop / no sudo
                                      bhepler Module Developer @Smolo
                                      @smolo Some suggestions: First, make sure that some form of IP address is present in the address key. Usually 127.0.0.1, but the IP address of your pi will probably work too. Without that value, the web server has a tendency to freak out.
                                      Second, make sure you are specifying the port in your web call. That one has bitten me a couple times.
                                      Third, I would double-check your IP whitelist in the config.js. Possibly open it up to all connections and attempt to view the magic mirror from another computer. See if the problem is local to the PI Zero or if it is on a deeper level.
                                        Smolo
                                        @bhepler
                                        First, as a supplement the installation is absolute standard except for another VNC server.
                                        Chromium starts automaticly with http://localhost:8080
                                        I have already tested the following constellations before my post.
                                        the local ip (192.168.2.84:8080)
                                        127.0.0.1:8080
                                        localhost:8080
                                        with https browser fault > “err_address_unreachable”
                                        Other things :…
                                        • ublock is inactive!
                                        • Configuration vom MagicMirror Config:
                                          var config = {
                                          port: 8080,
                                          address: “0.0.0.0”,
                                          ipWhitelist: [],
                                        • Test from another pc > “err_connection_refused”
                                          Smolo
                                          I’ve solved the problem and it’s going crazy. After I tried with a portscanner to find out if there is anything running I found out that there is no port 8080 open.
                                          If somebody has problems checking the logs via "pm2 logs MagicMirror --lines 1000
                                          I missed the npm module “moment” under “/home/pi/MagicMirror/node_modules/moment”!!!:astonished_face:
                                          Go to MagicMirror > “npm install” the problem was solved!:slightly_smiling_face:
                                            AnalogCHeep
                                            @andyc7687, thanks a lot! It will be easy for me now, I planned going for building a device like yours
                                            Regards
                                            • 2 / 9
