    Installing on a Pi Zero
    175 Posts 33 Posters 300.2k Views 33 Watching
      cdh1001 @andyc7687
      @andyc7687 - I needed to delete the line: key_mgmt=WPA-PSK Based on discussions elsewhere I originally tried renaming Key_mgmt to WPA2 and/or changing group=CCMP, but neither of those were necessary for me; simply deleting the line was sufficient.
      A 1 Reply Last reply
      • A
        andyc7687 @cdh1001
        @cdh1001 thanks, I will amend my guide over the weekend then.
          Smolo
          Thanks for the script and the hints so far :-)
          Unfortunately I am really frustrated after x installations. :-( Currently everything is installed the autostart works but chrome says “err_connection_refused”!
          Does anyone have an idea?
          Zero W V1.1 / Raspian Desktop / no sudo
          B 1 Reply Last reply
            bhepler Module Developer @Smolo
            @smolo Some suggestions: First, make sure that some form of IP address is present in the address key. Usually 127.0.0.1, but the IP address of your pi will probably work too. Without that value, the web server has a tendency to freak out.
            Second, make sure you are specifying the port in your web call. That one has bitten me a couple times.
            Third, I would double-check your IP whitelist in the config.js. Possibly open it up to all connections and attempt to view the magic mirror from another computer. See if the problem is local to the PI Zero or if it is on a deeper level.
              Smolo
              @bhepler
              First, as a supplement the installation is absolute standard except for another VNC server.
              Chromium starts automaticly with http://localhost:8080
              I have already tested the following constellations before my post.
              the local ip (192.168.2.84:8080)
              127.0.0.1:8080
              localhost:8080
              with https browser fault > “err_address_unreachable”
              Other things :…
              • ublock is inactive!
              • Configuration vom MagicMirror Config:
                var config = {
                port: 8080,
                address: “0.0.0.0”,
                ipWhitelist: [],
              • Test from another pc > “err_connection_refused”
                Smolo
                I’ve solved the problem and it’s going crazy. After I tried with a portscanner to find out if there is anything running I found out that there is no port 8080 open.
                If somebody has problems checking the logs via "pm2 logs MagicMirror --lines 1000
                I missed the npm module “moment” under “/home/pi/MagicMirror/node_modules/moment”!!!:astonished_face:
                Go to MagicMirror > “npm install” the problem was solved!:slightly_smiling_face:
                • A
                  AnalogCHeep
                  @andyc7687, thanks a lot! It will be easy for me now, I planned going for building a device like yours
                  Regards
                  • A
                    andyc7687 @AnalogCHeep
                    @analogcheep thanks, let me know if yours works and upvote if it is helpful!
                      12wsx
                      today i have to reinstall MM and I have some small problem. MM do not show on local hdmi outpul- I can see the dektop but no MM. Server is working properly because when I open it from laptop i can see MM, when I connect to raspberry pi via vnc i can see to MM. What is going on? what i miss?
                        sdetweil @12wsx
                        @12wsx in terminal, or script u use to start mm do
                        export DISPLAY=:0
                        Then npm start
                          12wsx
                          thank you for help, i had to reinstal system once more becase there were a lot of errors.
                          After new instalation pm2 didn’t start properly. after few hours i found why.
                          In pm2_MagicMirrorPi0.json
                          line:
                          “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
                          should be :
                          “script” : “/MagicMirror/PiZero/startMagicMirrorPi0.sh”,
                            which installer are you using? I don’t see the filename pm2_MagicMirrorPi0.json
                            or “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
                            in the raspberry.sh script…
                              ah, ok… i see you followed the manual instructions back a few posts…
                              i have a modified raspberry.sh I have for testing, that takes user into account
                              https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0
                              to use it like normal
                              bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)”
                                johnnyt1111
                                If I try to install magic mirror on the pi zero i get an error that electron 3.0.13 not found for armv6 , by editing the package.json file to specify electron 2.0.18. I can get it to work, although I cannot find a version of electron for armv6 on the electron repo. Any idea why 2.0.18 would work? What would I need to try to compile electron 3 for armv6?
                                https://github.com/electron/electron/releases/tag/v2.0.18
                                Thanks!
                                S 2 Replies Last reply
                                  sdetweil @johnnyt1111
                                  @johnnyt1111 download the electron source and follow the build process
                                    @johnnyt1111 why work. Cause electron 2.0.18 binary exists and 3.0.13 does not. There may be a technical reason, or they skipped it due to low demand.
                                    J 1 Reply Last reply
                                    • qu1queQ
                                      qu1que Project Sponsor
                                      I’ve found the same problem on last MM update:
                                      https://forum.magicmirror.builders/topic/10188/can-t-upgrade-mm-2-7-0-on-raspberry-pi-zero-w/2
                                        johnnyt1111 @sdetweil
                                        @sdetweil Thanks for the reply, I’m surprised the 2.0.18 even exists for armv6 as the electron issues states they don’t support it and is not listed in the releases page. but as long as it works I’m ok with that, thanks!
                                          johnnyt1111 @qu1que
                                          @qu1que Thanks for the link! Glad I’m not the only looking into this problem, hopefully we can get electron 3 working on the pi zero. but updating the package.json electron to “^2.0.0” will install 2.0.18 and will work with latest version of magic mirror
                                          • L
                                            liamangelus
                                            can you explain in detail how to do it? I’m new and have the same problem
                                            • 3 / 9
