    "Error: Cannot find module 'ping' " and black screen on startup (Beginner)
    5 Posts 3 Posters 2.2k Views 3 Watching
    • K Offline
      keyk123
      Not sure entirely what’s happening, as I’m super new to Raspberry Pi and everything involved with it. At first, I thought it was an issue with the module (MMM-network-signal) so I removed it from my config.js but I’m still getting the error. I’ve installed all the dependencies as well.
      Any help would be appriciated!
      config (sorry for the messy code):
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			module: "MMM-network-signal",
      			module: "currentweather",
      				locationID: "5819347",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "d78a6e9838b2fa659664f139495fda91",
      			module: "weatherforecast",
      			header: "Weather Forecast",
      			module: 'MMM-OnScreenMenu',
      			position: 'bottom_right',
      			/* Valid positions: 'top_right', 'top_left', 'bottom_right', 'bottom_left' */
      				touchMode: true,
      				enableKeyboard: true,
      				// ... see more options below
              module: 'MMM-Events',
              position: 'bottom_left',
      		city: "Boulder",              // Your City
      		eventType: "music_dance,music_pop,music_easy_listening,music_folk,music_rock,music_alternative,performing_arts_musical,performing_arts_comedy,comedy,movies_film,movies_film_filmfestival",            // See Events List in ReadMe
      		when: "Next Week",             // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
             		mode: "noFrame",               // Frame or noFrame (around picture)
             		apikey: "SJw8XkCWk7qj8cC3",
      		rotateInterval: 5 * 60 * 1000, // New Event Appears
      		useHeader: true,
              	header: "Events",
      		maxWidth: "195px",             // adjust to your liking
      		animationSpeed: 3000,          // Event fades in and out
              	initialLoadDelay: 4250,
              	retryDelay: 2500,
      		updateInterval: 60 * 60 * 1000, // 60 minutes. No need to change!
      		picture: false,                  // true, false = no picture
              module: 'MMM-Strava',
              position: 'lower_third',
                  strava_id: '11175670',
                  access_token: '225112bc74d27f282bfcb445393f1205d1440d8b'
              module: 'MMM-MovieListings',
          		apiKey: 'c5e8b03ed6966b680e8addc68f87afd3',
      		region: 'US',
          		language: 'en-US',
          		interface: 'poster', //'list', 'poster', 'detailed'
          		includeMoviePlot: true,
          		maxPlotLength: 198,
          		header: 'Movies',
          		moviesPerPage: 1,
          		refreshInterval: 1000 * 60 * 60 * 24, //Once a day
          		baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
          		animationSpeed: 2.5 * 1000,
          		pageChangeInterval: 30 * 1000
        		module: "MMM-NowPlayingOnSpotify",
        		position: "bottom_left",
          			clientID: "a60da971b5884399a581d132c221ce27",
          			clientSecret: "d064d24a94ca4fbb9e3efeeea6767da7",
          			accessToken: "BQDC5F33IPjzt_ksr2t1mLFtTUBOXzlq5FBDu5gKSqwxshbuM9geAGVh9y8fNqQYmN_8W9f36SdorRo6zRRX98pK8UuI62pOoJOCbeGkqKKW8x4XzY4Ol040kHIyotIS7wKMjTWTfUVbpzppP4zVw-ZL",
          			refreshToken: "AQAxiQB-7To8nb3Rv6ICfFT4mFxLGiTWS2XnKeJUi5KHatnMaMpwMvyq5ULtBKz_MEjxh5uBeyaF2cRWmOVgz3SqItqpii54rmEsHeh3Ubcl63p_y3St1skXeqx4iPOCGuj8jA",
      			showCoverArt: false
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      • K Offline
        keyk123
        If it helps, here’s what the terminal spits out
        npm WARN npm npm does not support Node.js v10.15.2
        npm WARN npm You should probably upgrade to a newer version of node as we
        npm WARN npm can't make any promises that npm will work with this version.
        npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
        npm WARN npm You can find the latest version at https://nodejs.org/
        > magicmirror@2.8.0 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.8.0
        Loading config ...
        Loading module helpers ...
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'ping'
        App threw an error during load
            at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            at Function.Module._load (internal/modules/cjs/loader.js:528:25)
            at Module.require (internal/modules/cjs/loader.js:658:17)
            at require (internal/modules/cjs/helpers.js:20:18)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-network-signal/node_helper.js:2:14)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-network-signal/node_helper.js:35:3)
            at Module._compile (internal/modules/cjs/loader.js:711:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
            at Module.load (internal/modules/cjs/loader.js:620:32)
        { Error: Cannot find module 'ping'
            at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
        Launching application.
        mumblebajM evroomE 2 Replies Last reply Reply Quote 0
        • mumblebajM Offline
          mumblebaj Module Developer @keyk123
          @keyk123 Can you edit your post and remove your keys etc?
            @keyk123 Can you cd into the MMM-network-signal module folder, cd ~/MagicMirror/modules/MMM-network-signal and run npm install? It requires you to run the command so that it can install all the dependencies. Try that and let us know if it solved your problem.
            • evroomE Offline
              evroom @keyk123
              @keyk123 said in "Error: Cannot find module 'ping' " and black screen on startup (Beginner):
              Update npm:
              pi@raspberrypi:~ $ npm -v
              5.8.0
              pi@raspberrypi:~ $ cd
              pi@raspberrypi:~ $ sudo npm install npm@latest -g
              [ pi@raspberrypi:~ $ sudo reboot ]
              6.10.3
              When in doubt if you’re config.js is okay, always run:
              pi@raspberrypi:~ $ cd ~/MagicMirror; npm run config:check
              MagicMirror version: 2.33.0
              Test environment:
              MagicMirror version: v2.33.0
