    mail module problem
    13 Posts 4 Posters 4.4k Views 4 Watching
      papinel @mumblebaj
      Hello sir
      could you tell me if I use the right orders? with the terminal
      cd ~ / MagicMirror / modules
      git clone https://github.com/ronny3050/email-mirror.git
      cd email
      npm install
      because when i install your answer in my config.js
      I have my black page with the error message
      please create config file
      if you this message is ready for your config file probaly contains an error
      this message only happens when I install
      in the config.js
      Thank you very much for your help
      papinel
      strawberry 3.141S mumblebajM 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @papinel
        @papinel you didnt install it properly, the instructions say git clone https://github.com/ronny3050/email-mirror.git email, either start from scratch or rename the directory email-mirror to email and install the dependencies again.
        • mumblebajM Offline
          mumblebaj Module Developer @papinel
          @papinel I just installed the module and set it up and it works perfect with the setings that I gave you above. As @strawberry-3-141 mentioned, you may want to start from scratch with the module installation.
          • git clone https://github.com/ronny3050/email-mirror.git email
          • cd email
          • npm install
            papinel
            I’m sorry, but really sorry I still did not pay the email module for my magicmirror I did everything you told me
            first the 3 orders by the terminal
            cd email
            npm install
            return by image
            pi @ raspberrypi: ~ $ git clone https://github.com/ronny3050/email-mirror.git emailCloning in ‘email’ …
            remote: Enumerating objects: 3, done.
            remote: Counting objects: 100% (3/3), done.
            remote: Compressing objects: 100% (3/3), done.
            remote: Total 63 (delta 0), reused 0 (delta 0), pack-reused 60
            Unpacking objects: 100% (63/63), done.
            pi @ raspberrypi: ~ $ cd email
            pi @ raspberrypi: ~ / email $ npm install
            (node: 2831) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead.
            npm WARN package.json email@0.0.1 No repository field.
            npm WARN package.json email@0.0.1 No license field.
            npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
            npm WARN deprecated mimelib@0.3.1: This project is unmaintained
            underscore@1.9.1 node_modules / underscore
            debug@2.6.9 node_modules / debug
            └── ms@2.0.0
            imap@0.8.19 node_modules / imap
            ├── utf7@1.0.2 (semver@5.3.0)
            └── readable-stream@1.1.14 (string_decoder@0.10.31, isarray@0.0.1, inherits@2.0.4, core-util-is@1.0.2)
            mailparser@0.6.2 node_modules / mailparser
            ├── mime@1.6.0
            ├── mimelib@0.3.1 (addressparser@1.0.1)
            ├── uue@3.1.2 (escape-string-regexp@1.0.5, extend@3.0.2)
            └── encoding@0.1.12 (iconv-lite@0.4.24)
            as indicate by
             mumblebaj
            then I copy in config.js
            module: ‘email’,
            position: ‘top_left’,
            header: ‘Email’
            accounts: [
            user: ‘xxxxx@gmail.com’,
            password: ‘xxxxx’,
              host: ‘imap.gmail.com’,
              port: 993,
              tls: true,
              authTimeout: 10000,
              numberOfEmails: 5,
              fade: true
            as indicated by
            mumblebaj
            in my home / pi I have an email folder, but when I run pm2 start mm, I find my page that marks me errors, I really do not know or I make a mistake I am to the letter your advice
            I really do not know where I am making a mistake I am on the letter your advice
            I will stop bothering you with my problem, I will not use the clone mail
            I pass you all this through a .odt file
            thank you so much
            papinel
              sdetweil @papinel
              @papinel ALWAYS git clone ONLY with the MagicMirror/modules folder as the current folder, u have them all over the place…
                papinel
                Hello
                thank you for your answer, but could develop a little more because I have trouble understanding to execute this module
                thank you so much
                papinel
                  sdetweil @papinel
                  @papinel when someone tells u to install a module on MagicMirror
                  you do
                  cd modules
                  git clone .....
                  cd ../config
                  nano config.js
                  ... add the config info for this module
                  ... save the updated config (ctrl-o to write, ctrl-x to exit nano)
                  cd ..
                  either use pm2 to  start MagicMirror again or the installers/mm.sh
                  in general, you should not need to change anything IN the module folder itself
                    papinel @sdetweil
                      sdetweil @papinel
                      @papinel yes?
                        papinel
                        the answer I want to make is enterdite it goes into spam
                        bad luck for the helpers
                        papinel
