    mail module problem
    13 Posts 4 Posters 4.9k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @papinel
      @papinel you didnt install it properly, the instructions say git clone https://github.com/ronny3050/email-mirror.git email, either start from scratch or rename the directory email-mirror to email and install the dependencies again.
      • mumblebajM Online
        mumblebaj Module Developer @papinel
        @papinel I just installed the module and set it up and it works perfect with the setings that I gave you above. As @strawberry-3-141 mentioned, you may want to start from scratch with the module installation.
        • git clone https://github.com/ronny3050/email-mirror.git email
        • cd email
        • npm install
          papinel
          I’m sorry, but really sorry I still did not pay the email module for my magicmirror I did everything you told me
          first the 3 orders by the terminal
          cd email
          npm install
          return by image
          pi @ raspberrypi: ~ $ git clone https://github.com/ronny3050/email-mirror.git emailCloning in ‘email’ …
          remote: Enumerating objects: 3, done.
          remote: Counting objects: 100% (3/3), done.
          remote: Compressing objects: 100% (3/3), done.
          remote: Total 63 (delta 0), reused 0 (delta 0), pack-reused 60
          Unpacking objects: 100% (63/63), done.
          pi @ raspberrypi: ~ $ cd email
          pi @ raspberrypi: ~ / email $ npm install
          (node: 2831) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead.
          npm WARN package.json email@0.0.1 No repository field.
          npm WARN package.json email@0.0.1 No license field.
          npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
          npm WARN deprecated mimelib@0.3.1: This project is unmaintained
          underscore@1.9.1 node_modules / underscore
          debug@2.6.9 node_modules / debug
          └── ms@2.0.0
          imap@0.8.19 node_modules / imap
          ├── utf7@1.0.2 (semver@5.3.0)
          └── readable-stream@1.1.14 (string_decoder@0.10.31, isarray@0.0.1, inherits@2.0.4, core-util-is@1.0.2)
          mailparser@0.6.2 node_modules / mailparser
          ├── mime@1.6.0
          ├── mimelib@0.3.1 (addressparser@1.0.1)
          ├── uue@3.1.2 (escape-string-regexp@1.0.5, extend@3.0.2)
          └── encoding@0.1.12 (iconv-lite@0.4.24)
          as indicate by
           mumblebaj
          then I copy in config.js
          module: ‘email’,
          position: ‘top_left’,
          header: ‘Email’
          accounts: [
          user: ‘xxxxx@gmail.com’,
          password: ‘xxxxx’,
            host: ‘imap.gmail.com’,
            port: 993,
            tls: true,
            authTimeout: 10000,
            numberOfEmails: 5,
            fade: true
          as indicated by
          mumblebaj
          in my home / pi I have an email folder, but when I run pm2 start mm, I find my page that marks me errors, I really do not know or I make a mistake I am to the letter your advice
          I really do not know where I am making a mistake I am on the letter your advice
          I will stop bothering you with my problem, I will not use the clone mail
          I pass you all this through a .odt file
          thank you so much
          papinel
            sdetweil @papinel
            @papinel ALWAYS git clone ONLY with the MagicMirror/modules folder as the current folder, u have them all over the place…
              papinel
              Hello
              thank you for your answer, but could develop a little more because I have trouble understanding to execute this module
              thank you so much
              papinel
                sdetweil @papinel
                @papinel when someone tells u to install a module on MagicMirror
                you do
                cd modules
                git clone .....
                cd ../config
                nano config.js
                ... add the config info for this module
                ... save the updated config (ctrl-o to write, ctrl-x to exit nano)
                cd ..
                either use pm2 to  start MagicMirror again or the installers/mm.sh
                in general, you should not need to change anything IN the module folder itself
                  papinel @sdetweil
                    sdetweil @papinel
                    @papinel yes?
                      papinel
                      the answer I want to make is enterdite it goes into spam
                      bad luck for the helpers
                      papinel
                        papinel
                        hello
                        je tiens avous remercier pour votre aide
                        mon module fonctionne a 99 pour cent
                        il me dit '…no read mail … j’ai configurer comme ca
                        port: 993,
                        dans gmail j’ai active imap mais mes mails n’apparaisse pas sur l’ecran de magic m
                        une petite idee pour cloturer ma demande
                        merci beaucoup
                        papinel
                        343/5000
                        Hello
                        I want to thank you for your help
                        my module works at 99 percent
                        he told me '… no read mail … I set it up
                        port: 993,
                        in gmail i have active imap but my mails do not appear on the screen magic m
                        a little idea to close my request
                        thank you so much
                        papinel
