    mail module problem
    13 Posts 4 Posters 4.3k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @papinel
      @papinel I just installed the module and set it up and it works perfect with the setings that I gave you above. As @strawberry-3-141 mentioned, you may want to start from scratch with the module installation.
      • git clone https://github.com/ronny3050/email-mirror.git email
      • cd email
      • npm install
        papinel
        I’m sorry, but really sorry I still did not pay the email module for my magicmirror I did everything you told me
        first the 3 orders by the terminal
        cd email
        npm install
        return by image
        pi @ raspberrypi: ~ $ git clone https://github.com/ronny3050/email-mirror.git emailCloning in ‘email’ …
        remote: Enumerating objects: 3, done.
        remote: Counting objects: 100% (3/3), done.
        remote: Compressing objects: 100% (3/3), done.
        remote: Total 63 (delta 0), reused 0 (delta 0), pack-reused 60
        Unpacking objects: 100% (63/63), done.
        pi @ raspberrypi: ~ $ cd email
        pi @ raspberrypi: ~ / email $ npm install
        (node: 2831) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead.
        npm WARN package.json email@0.0.1 No repository field.
        npm WARN package.json email@0.0.1 No license field.
        npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
        npm WARN deprecated mimelib@0.3.1: This project is unmaintained
        underscore@1.9.1 node_modules / underscore
        debug@2.6.9 node_modules / debug
        └── ms@2.0.0
        imap@0.8.19 node_modules / imap
        ├── utf7@1.0.2 (semver@5.3.0)
        └── readable-stream@1.1.14 (string_decoder@0.10.31, isarray@0.0.1, inherits@2.0.4, core-util-is@1.0.2)
        mailparser@0.6.2 node_modules / mailparser
        ├── mime@1.6.0
        ├── mimelib@0.3.1 (addressparser@1.0.1)
        ├── uue@3.1.2 (escape-string-regexp@1.0.5, extend@3.0.2)
        └── encoding@0.1.12 (iconv-lite@0.4.24)
        as indicate by
         mumblebaj
        then I copy in config.js
        module: ‘email’,
        position: ‘top_left’,
        header: ‘Email’
        accounts: [
        user: ‘xxxxx@gmail.com’,
        password: ‘xxxxx’,
          host: ‘imap.gmail.com’,
          port: 993,
          tls: true,
          authTimeout: 10000,
          numberOfEmails: 5,
          fade: true
        as indicated by
        mumblebaj
        in my home / pi I have an email folder, but when I run pm2 start mm, I find my page that marks me errors, I really do not know or I make a mistake I am to the letter your advice
        I really do not know where I am making a mistake I am on the letter your advice
        I will stop bothering you with my problem, I will not use the clone mail
        I pass you all this through a .odt file
        thank you so much
        papinel
          sdetweil @papinel
          @papinel ALWAYS git clone ONLY with the MagicMirror/modules folder as the current folder, u have them all over the place…
            papinel
            Hello
            thank you for your answer, but could develop a little more because I have trouble understanding to execute this module
            thank you so much
            papinel
              sdetweil @papinel
              @papinel when someone tells u to install a module on MagicMirror
              you do
              cd modules
              git clone .....
              cd ../config
              nano config.js
              ... add the config info for this module
              ... save the updated config (ctrl-o to write, ctrl-x to exit nano)
              cd ..
              either use pm2 to  start MagicMirror again or the installers/mm.sh
              in general, you should not need to change anything IN the module folder itself
                papinel @sdetweil
                  sdetweil @papinel
                  @papinel yes?
                    papinel
                    the answer I want to make is enterdite it goes into spam
                    bad luck for the helpers
                    papinel
                      papinel
                      hello
                      je tiens avous remercier pour votre aide
                      mon module fonctionne a 99 pour cent
                      il me dit '…no read mail … j’ai configurer comme ca
                      port: 993,
                      dans gmail j’ai active imap mais mes mails n’apparaisse pas sur l’ecran de magic m
                      une petite idee pour cloturer ma demande
                      merci beaucoup
                      papinel
                      343/5000
                      Hello
                      I want to thank you for your help
                      my module works at 99 percent
                      he told me '… no read mail … I set it up
                      port: 993,
                      in gmail i have active imap but my mails do not appear on the screen magic m
                      a little idea to close my request
                      thank you so much
                      papinel
