    mail module problem
    13 Posts 4 Posters 5.1k Views 4 Watching
    • mumblebajM
      mumblebaj Module Developer @papinel
      @papinel Hi. Your config looks wrong. Can you try changing it to match the below?
      module: 'email',
      position: 'top_left',
      header: 'Email'
      	accounts: [
      	user: 'xxxxx@gmail.com',
      	password: 'xxxxx',
        host: 'imap.gmail.com',
        port: 993,
        tls: true,
        authTimeout: 10000,
        numberOfEmails: 5,
        fade: true
      P 1 Reply Last reply
        papinel @mumblebaj
        Hello sir
        could you tell me if I use the right orders? with the terminal
        cd ~ / MagicMirror / modules
        git clone https://github.com/ronny3050/email-mirror.git
        cd email
        npm install
        because when i install your answer in my config.js
        I have my black page with the error message
        please create config file
        if you this message is ready for your config file probaly contains an error
        this message only happens when I install
        in the config.js
        Thank you very much for your help
        papinel
        strawberry 3.141S mumblebajM 2 Replies Last reply
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @papinel
          @papinel you didnt install it properly, the instructions say git clone https://github.com/ronny3050/email-mirror.git email, either start from scratch or rename the directory email-mirror to email and install the dependencies again.
          • mumblebajM
            @papinel I just installed the module and set it up and it works perfect with the setings that I gave you above. As @strawberry-3-141 mentioned, you may want to start from scratch with the module installation.
            • git clone https://github.com/ronny3050/email-mirror.git email
            • cd email
            • npm install
              papinel
              I’m sorry, but really sorry I still did not pay the email module for my magicmirror I did everything you told me
              first the 3 orders by the terminal
              cd email
              npm install
              return by image
              pi @ raspberrypi: ~ $ git clone https://github.com/ronny3050/email-mirror.git emailCloning in ‘email’ …
              remote: Enumerating objects: 3, done.
              remote: Counting objects: 100% (3/3), done.
              remote: Compressing objects: 100% (3/3), done.
              remote: Total 63 (delta 0), reused 0 (delta 0), pack-reused 60
              Unpacking objects: 100% (63/63), done.
              pi @ raspberrypi: ~ $ cd email
              pi @ raspberrypi: ~ / email $ npm install
              (node: 2831) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead.
              npm WARN package.json email@0.0.1 No repository field.
              npm WARN package.json email@0.0.1 No license field.
              npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
              npm WARN deprecated mimelib@0.3.1: This project is unmaintained
              underscore@1.9.1 node_modules / underscore
              debug@2.6.9 node_modules / debug
              └── ms@2.0.0
              imap@0.8.19 node_modules / imap
              ├── utf7@1.0.2 (semver@5.3.0)
              └── readable-stream@1.1.14 (string_decoder@0.10.31, isarray@0.0.1, inherits@2.0.4, core-util-is@1.0.2)
              mailparser@0.6.2 node_modules / mailparser
              ├── mime@1.6.0
              ├── mimelib@0.3.1 (addressparser@1.0.1)
              ├── uue@3.1.2 (escape-string-regexp@1.0.5, extend@3.0.2)
              └── encoding@0.1.12 (iconv-lite@0.4.24)
              as indicate by
               mumblebaj
              then I copy in config.js
              module: ‘email’,
              position: ‘top_left’,
              header: ‘Email’
              accounts: [
              user: ‘xxxxx@gmail.com’,
              password: ‘xxxxx’,
                host: ‘imap.gmail.com’,
                port: 993,
                tls: true,
                authTimeout: 10000,
                numberOfEmails: 5,
                fade: true
              as indicated by
              mumblebaj
              in my home / pi I have an email folder, but when I run pm2 start mm, I find my page that marks me errors, I really do not know or I make a mistake I am to the letter your advice
              I really do not know where I am making a mistake I am on the letter your advice
              I will stop bothering you with my problem, I will not use the clone mail
              I pass you all this through a .odt file
              thank you so much
              papinel
                sdetweil @papinel
                @papinel ALWAYS git clone ONLY with the MagicMirror/modules folder as the current folder, u have them all over the place…
                  papinel
                  Hello
                  thank you for your answer, but could develop a little more because I have trouble understanding to execute this module
                  thank you so much
                  papinel
                    sdetweil @papinel
                    @papinel when someone tells u to install a module on MagicMirror
                    you do
                    cd modules
                    git clone .....
                    cd ../config
                    nano config.js
                    ... add the config info for this module
                    ... save the updated config (ctrl-o to write, ctrl-x to exit nano)
                    cd ..
                    either use pm2 to  start MagicMirror again or the installers/mm.sh
                    in general, you should not need to change anything IN the module folder itself
                      papinel @sdetweil
                        sdetweil @papinel
                        @papinel yes?
                          papinel
                          the answer I want to make is enterdite it goes into spam
                          bad luck for the helpers
                          papinel
                            papinel
                            hello
                            je tiens avous remercier pour votre aide
                            mon module fonctionne a 99 pour cent
                            il me dit '…no read mail … j’ai configurer comme ca
                            port: 993,
                            dans gmail j’ai active imap mais mes mails n’apparaisse pas sur l’ecran de magic m
                            une petite idee pour cloturer ma demande
                            merci beaucoup
                            papinel
                            343/5000
                            Hello
                            I want to thank you for your help
                            my module works at 99 percent
                            he told me '… no read mail … I set it up
                            port: 993,
                            in gmail i have active imap but my mails do not appear on the screen magic m
                            a little idea to close my request
                            thank you so much
                            papinel
