Unsolved MMM-Assistantmk2 and MMM-Hotword not picking up
@jmartin1009
rm -rf /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/.gitThen try again
Hi, why?
When I change the activation word, it doesn’t work for me?,
I want to change it to another word, like alexa, jarvis, etc, and it doesn’t work for me.
I have copied the parameters of @ejay-ibm and nothing.language: "es", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "Calendario", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "https://www.calendarlabs.com/ical-calendar/ics/70/Spain_Holidays.ics" }, { symbol: "MyCalendar", url: "https://calendar.google.com/calendar/ical/............/public/basic.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Arrecife, ES", locationID: "2521570", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "..........................." } }, { module: 'currentweather', position: 'top_right', config: { location: 'Arrecife, es', locationID: '2521570', //ID from bulk.openweather.org/sample/ appid:" .............................'', updateInterval: '3600000', onlyTemp: true } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "Canarias7", url: "https://www.canarias7.es/rss/portada.xml" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, { module: "MMM-Hotword", position: "top_right", config: { chimeOnFinish: null, mic: { recordProgram: "arecord", device: "plughw:1" }, models: [ { hotwords : "Smart_mirror", file : "smart_mirror.umdl", sensitivity : "0.5", }, ], commands: { "smart_mirror": { notificationExec: { notification: "ASSISTANT_ACTIVATE", payload: (detected, afterRecord) => { return {profile:"default"} } }, restart:false, afterRecordLimit:0 } } } }, { module: "MMM-AssistantMk2", position: "top_right", config: { deviceLocation: { coordinates: { latitude: 28.969593, // -90.0 - +90.0 longitude: -13.556344, // -180.0 - +180.0 }, }, record: { recordProgram : "arecord", device : "plughw:1", }, notifications: { ASSISTANT_ACTIVATED: "HOTWORD_PAUSE", ASSISTANT_DEACTIVATED: "HOTWORD_RESUME", }, useWelcomeMessage: "brief today", profiles: { "default" : { lang: "es-ES" } }, } }, ]
@raedonlpa can u edit your post, and put three back-tics (shifted, left of 1) before the 1st line, and after the last line.
@sdetweil Better this way, I’m sorry I use google traslator
@raedonlpa yes, much better… thank you … you missed one close brace }; at the end, inside the backtics
@sdetweil I know, don’t let me put it in the forum
@raedonlpa it was only on the edit of the forum post…
@sdetweil said in MMM-Assistantmk2 and MMM-Hotword not picking up:
Do you mean the end of everything?
yes, I get spawn error
