    Synchronous requests [solved]
    14 Posts 2 Posters 10.8k Views 1 Watching
    • MichMichM Offline
      MichMich @paviro
      @paviro Yeah, but try to understand what I did. Thats the best way to learn. Let me know what you don’t understand. I’ll explain.
        paviro
        I do not quite understand how the itemsReceivedCallbackworks :confused:
        – The Doctor
          paviro
          Does work great now! The only problem is sometimes a list is empty on a refresh even tough it should not be :/
          { inbox: [],
            'ViRO Entertainment':
             [ 'Todo1',
               'Todo2',
               'Todo3' ]
          – The Doctor
          • MichMichM Offline
            MichMich
            I’m on my phone now, so not really able to explain the callbacks. Will do that later.
            Regarding the empty lists: try debugging by putting some log statements on places where You receive and send data.
              paviro
              It is not the socket connection. The fetcher sometimes returns an empty list :/
              – The Doctor
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @paviro
                @paviro try debugging the Fetchet on the same way. ;)
                  paviro
                  I am on it but I can’t find the problem… :confounded:
                  When broadcastItems is fired and therefore fetcher.onReceive triggered the lists are populated. But once broadcastTodos() collects the tasks by looping over the fetchers some lists appear to be empty. Any chance you could have a look?
                  – The Doctor
                  • MichMichM Offline
                    MichMich
                    Will fork your module tomorrow and give it a try.
                      paviro
                      Thanks! :)
                      – The Doctor
                      • MichMichM Offline
                        MichMich
                        Ok, I looked into it, and it really is pretty simple and obvious when I’ll explain you. So prepare for a “Doh!” moment … ;)
                        Right before you do the request to WunderList, you empty the items array:
                        https://github.com/paviro/MMM-Wunderlist/blob/master/fetcher.js#L38
                        Then if Wunderlist responds, you fill the items array with new items.
                        This means that as long as your fetcher is waiting for wunderlist to respond, the items array is empty. If in the meantime an other fetcher is finished fetching, it uses the items array to make a full list. But that array is then still empty, waiting to be filled after the wunderlust response.
                        The solution? Move line 38 (items = [];) to line 51 (above for (var i = 0; i < JSON.parse(body).length; i++) {).
                        Thats all! :)
                          paviro
                          And there comes the “Doh!” moment! :D Thanks completely overlooked that…
                          – The Doctor
