    Problem with the Module "email"
    57 Posts 4 Posters 37.4k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      If i enter npm start dev he following will come out:
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2019-09-06T07_07_27_973Z-debug.log
        sdetweil @CyruS1337
        @CyruS1337 u need to be in the MagicMirror folder before npm start
        CyruS1337C 1 Reply Last reply Reply Quote 0
        • mumblebajM Offline
          mumblebaj Module Developer @CyruS1337
          @CyruS1337 I assume that you meant that you replace your password with the generated key? When you run pm2 logs what do you get? Does it show anything for email? Have you in the /modules/email folder run npm install?
            CyruS1337 Project Sponsor @sdetweil
            That’s right, sorry
            > magicmirror@2.8.0 start /home/pi/MagicMirror
            > sh run-start.sh "dev"
            Starting MagicMirror: v2.8.0
            Loading config ...
            Loading module helpers ...
            Module helper loaded: MMM-SystemStats
            Module helper loaded: MMM-Remote-Control
            Module helper loaded: MMM-MyCommute
            Module helper loaded: MMM-AVStock
            Module helper loaded: MMM-GoogleMapsTraffic
            Module helper loaded: MMM-SoccerLiveScore
            Module helper loaded: email
            Module helper loaded: MMM-MyCalendar
            All module helpers loaded.
            Server started ...
            Connecting socket for: MMM-SystemStats
            Connecting socket for: MMM-Remote-Control
            Starting node helper for: MMM-Remote-Control
            Connecting socket for: MMM-MyCommute
            ====================== Starting node_helper for module [MMM-MyCommute]
            Connecting socket for: MMM-AVStock
            Connecting socket for: MMM-GoogleMapsTraffic
            Starting node_helper for module: MMM-GoogleMapsTraffic
            Connecting socket for: MMM-SoccerLiveScore
            MMM-SoccerLiveScore helper started...
            Connecting socket for: email
            email helper started ...
            Connecting socket for: MMM-MyCalendar
            Starting node helper for: MMM-MyCalendar
            { Error: listen EADDRINUSE 0.0.0.0:8080
                at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                at listenInCluster (net.js:1378:12)
                at doListen (net.js:1492:7)
                at process._tickCallback (internal/process/next_tick.js:63:19)
                at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
                at startup (internal/bootstrap/node.js:241:19)
                at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
              errno: 'EADDRINUSE',
              code: 'EADDRINUSE',
              syscall: 'listen',
              address: '0.0.0.0',
              port: 8080 }
            Launching application.
              CyruS1337 Project Sponsor @mumblebaj
              @mumblebaj
              Exactly, I replaced the password with the key. I have also installed npm.
              cd MagicMirror/modules
              cd email
              npm install
              npm WARN email@0.0.1 No repository field.
              npm WARN email@0.0.1 No license field.
              audited 24 packages in 2.521s
              found 0 vulnerabilities
              pm2 logs
              pi@raspberrypi_LOL:~/MagicMirror/modules/email $ pm2 logs
              /home/pi/.pm2/pm2.log last 15 lines:
              PM2        | 2019-09-07T04:30:05: PM2 log: App [mm:0] online
              PM2        | 2019-09-07T07:40:45: PM2 log: Process 0 in a stopped status, starting it
              PM2        | 2019-09-07T07:40:45: PM2 log: Stopping app:mm id:0
              PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=failed to kill - retrying in 100ms
              PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
              PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=process killed
              PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] starting in -fork mode-
              PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] online
              PM2        | 2019-09-07T07:55:09: PM2 log: Process 0 in a stopped status, starting it
              PM2        | 2019-09-07T07:55:09: PM2 log: Stopping app:mm id:0
              PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=failed to kill - retrying in 100ms
              PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
              PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=process killed
              PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] starting in -fork mode-
              PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] online
              0|mm       | SyntaxError: Unexpected token u in JSON at position 0
              0|mm       |     at JSON.parse (<anonymous>)
              0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
              0|mm       |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
              0|mm       |     at Request.emit (events.js:182:13)
              0|mm       |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
              0|mm       |     at ClientRequest.emit (events.js:182:13)
              0|mm       |     at TLSSocket.socketErrorListener (_http_client.js:382:9)
              0|mm       |     at TLSSocket.emit (events.js:182:13)
              0|mm       |     at emitErrorNT (internal/streams/destroy.js:82:8)
              0|mm       |     at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
              0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
              0|mm       | (node:5525) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              0|mm       | (node:7860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              0|mm       | Connecting socket for: email
              0|mm       | email helper started ...
              0|mm       | Connecting socket for: MMM-MyCalendar
              0|mm       | Starting node helper for: MMM-MyCalendar
              0|mm       | Sockets connected & modules started ...
              0|mm       | Launching application.
              0|mm       | [AVSTOCK] Initialized.
              0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
              0|mm       | listening for emails...
              0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
              0|mm       | NEW MAIL
              0|mm       | NEW MAIL
              0|mm       | NEW MAIL
              0|mm       | NEW MAIL
              0|mm       | NEW MAIL
                sdetweil @CyruS1337
                @CyruS1337 MMM-SoccerLiveScore/ is the one throwing the error… not email
                  I have disabled the module, but the mails are still not displayed :(
                  	module: 'MMM-SoccerLiveScore',
                  	position: 'top_right',
                  	header: 'Fussball Rangliste',
                  		leagues: [215,399,1],
                          showNames: true,
                          showLogos: true,
                          displayTime: 60 * 1000,
                          showTables: true
                    sdetweil @CyruS1337
                    @CyruS1337 i don’t know anything about email module, i remember it was hard to get working, i didn;t like the results…
                    anyhow… for the commenting out module,
                    you can also just add
                    disabled: true,
                    to the module info, before/after the module name
                    disabled: false,
                    is the default
                      @sdetweil I do not really like the module any more. I’m trying to get it up and running for a year :)
                      Thank you very much for your great support
                        @CyruS1337 Please remember, for the emails to display you need to set fade: false.
                        • 3 / 3
