    Problem with the Module "email"
    57 Posts 4 Posters 38.8k Views 4 Watching
      sdetweil @mumblebaj
      @mumblebaj yes, had to turn on 2fa… hate that
      • CyruS1337C
        CyruS1337 Project Sponsor
        I do not see it either. I see the same as sdetweil. I’ve also approved third-party apps with account access on this page below.
        Can I do something that would help you? Post a log or something. You just have to tell me the command;)
        S mumblebajM 2 Replies Last reply
          sdetweil @CyruS1337
          @CyruS1337 you have to turn on 2 step verification (2 factor authentication aka 2fa)
          • mumblebajM
            mumblebaj Module Developer @CyruS1337
            @CyruS1337 I just setup the module and created my app key and email is working for me.
            And my config: I also had to change fade to false in order for email to display properly
                            module: 'email',
                            position: 'top_right',
                            header: 'Email',
                                     accounts: [
                                                    user: 'xxxxxxxxxxxxx@gmail.com',
                                                    password: 'xxxxxxxxxxxxxxxx',
                                                    host:'imap.gmail.com',
                                                    port: 993,
                                                    tls: true,
                                                    authTimeout: 10000,
                                                    numberOfEmails: 5,
                                    fade: false,
                                    maxCharacters: 30
            • CyruS1337C
              Good Morning
              So I activated the 2FA and replaced the generated key with my password. I also took your config and added my username and password from 2FA. Unfortunately, as before, there is still “load” and it does not show any emails.
              mumblebajM 1 Reply Last reply
              • CyruS1337C
                If i enter npm start dev he following will come out:
                npm ERR! code ENOENT
                npm ERR! errno -2
                npm ERR! syscall open
                npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                npm ERR! enoent This is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR!     /home/pi/.npm/_logs/2019-09-06T07_07_27_973Z-debug.log
                  sdetweil @CyruS1337
                  @CyruS1337 u need to be in the MagicMirror folder before npm start
                  CyruS1337C 1 Reply Last reply
                  • mumblebajM
                    @CyruS1337 I assume that you meant that you replace your password with the generated key? When you run pm2 logs what do you get? Does it show anything for email? Have you in the /modules/email folder run npm install?
                    • CyruS1337C
                      CyruS1337 Project Sponsor @sdetweil
                      That’s right, sorry
                      > magicmirror@2.8.0 start /home/pi/MagicMirror
                      > sh run-start.sh "dev"
                      Starting MagicMirror: v2.8.0
                      Loading config ...
                      Loading module helpers ...
                      Module helper loaded: MMM-SystemStats
                      Module helper loaded: MMM-Remote-Control
                      Module helper loaded: MMM-MyCommute
                      Module helper loaded: MMM-AVStock
                      Module helper loaded: MMM-GoogleMapsTraffic
                      Module helper loaded: MMM-SoccerLiveScore
                      Module helper loaded: email
                      Module helper loaded: MMM-MyCalendar
                      All module helpers loaded.
                      Server started ...
                      Connecting socket for: MMM-SystemStats
                      Connecting socket for: MMM-Remote-Control
                      Starting node helper for: MMM-Remote-Control
                      Connecting socket for: MMM-MyCommute
                      ====================== Starting node_helper for module [MMM-MyCommute]
                      Connecting socket for: MMM-AVStock
                      Connecting socket for: MMM-GoogleMapsTraffic
                      Starting node_helper for module: MMM-GoogleMapsTraffic
                      Connecting socket for: MMM-SoccerLiveScore
                      MMM-SoccerLiveScore helper started...
                      Connecting socket for: email
                      email helper started ...
                      Connecting socket for: MMM-MyCalendar
                      Starting node helper for: MMM-MyCalendar
                      { Error: listen EADDRINUSE 0.0.0.0:8080
                          at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                          at listenInCluster (net.js:1378:12)
                          at doListen (net.js:1492:7)
                          at process._tickCallback (internal/process/next_tick.js:63:19)
                          at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
                          at startup (internal/bootstrap/node.js:241:19)
                          at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
                        errno: 'EADDRINUSE',
                        code: 'EADDRINUSE',
                        syscall: 'listen',
                        address: '0.0.0.0',
                        port: 8080 }
                      Launching application.
                      • CyruS1337C
                        CyruS1337 Project Sponsor @mumblebaj
                        @mumblebaj
                        Exactly, I replaced the password with the key. I have also installed npm.
                        cd MagicMirror/modules
                        cd email
                        npm install
                        npm WARN email@0.0.1 No repository field.
                        npm WARN email@0.0.1 No license field.
                        audited 24 packages in 2.521s
                        found 0 vulnerabilities
                        pm2 logs
                        pi@raspberrypi_LOL:~/MagicMirror/modules/email $ pm2 logs
                        /home/pi/.pm2/pm2.log last 15 lines:
                        PM2        | 2019-09-07T04:30:05: PM2 log: App [mm:0] online
                        PM2        | 2019-09-07T07:40:45: PM2 log: Process 0 in a stopped status, starting it
                        PM2        | 2019-09-07T07:40:45: PM2 log: Stopping app:mm id:0
                        PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=failed to kill - retrying in 100ms
                        PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                        PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=process killed
                        PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] starting in -fork mode-
                        PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] online
                        PM2        | 2019-09-07T07:55:09: PM2 log: Process 0 in a stopped status, starting it
                        PM2        | 2019-09-07T07:55:09: PM2 log: Stopping app:mm id:0
                        PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=failed to kill - retrying in 100ms
                        PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                        PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=process killed
                        PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] starting in -fork mode-
                        PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] online
                        0|mm       | SyntaxError: Unexpected token u in JSON at position 0
                        0|mm       |     at JSON.parse (<anonymous>)
                        0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                        0|mm       |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                        0|mm       |     at Request.emit (events.js:182:13)
                        0|mm       |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                        0|mm       |     at ClientRequest.emit (events.js:182:13)
                        0|mm       |     at TLSSocket.socketErrorListener (_http_client.js:382:9)
                        0|mm       |     at TLSSocket.emit (events.js:182:13)
                        0|mm       |     at emitErrorNT (internal/streams/destroy.js:82:8)
                        0|mm       |     at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
                        0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                        0|mm       | (node:5525) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                        0|mm       | (node:7860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                        0|mm       | Connecting socket for: email
                        0|mm       | email helper started ...
                        0|mm       | Connecting socket for: MMM-MyCalendar
                        0|mm       | Starting node helper for: MMM-MyCalendar
                        0|mm       | Sockets connected & modules started ...
                        0|mm       | Launching application.
                        0|mm       | [AVSTOCK] Initialized.
                        0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                        0|mm       | listening for emails...
                        0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
                        0|mm       | NEW MAIL
                        0|mm       | NEW MAIL
                        0|mm       | NEW MAIL
                        0|mm       | NEW MAIL
                        0|mm       | NEW MAIL
                          sdetweil @CyruS1337
                          @CyruS1337 MMM-SoccerLiveScore/ is the one throwing the error… not email
                          • CyruS1337C
                            I have disabled the module, but the mails are still not displayed :(
                            	module: 'MMM-SoccerLiveScore',
                            	header: 'Fussball Rangliste',
                            		leagues: [215,399,1],
                                    showNames: true,
                                    showLogos: true,
                                    displayTime: 60 * 1000,
                                    showTables: true
                              sdetweil @CyruS1337
                              @CyruS1337 i don’t know anything about email module, i remember it was hard to get working, i didn;t like the results…
                              anyhow… for the commenting out module,
                              you can also just add
                              disabled: true,
                              to the module info, before/after the module name
                              disabled: false,
                              is the default
                              • CyruS1337C
                                @sdetweil I do not really like the module any more. I’m trying to get it up and running for a year :)
                                Thank you very much for your great support
                                • mumblebajM
                                  @CyruS1337 Please remember, for the emails to display you need to set fade: false.
                                  • 3 / 3
