    Problem with the Module "email"
    57 Posts 4 Posters 38.8k Views 4 Watching
    • mumblebajM
      mumblebaj Module Developer @CyruS1337
      @CyruS1337 In gmail, you need to select the Google Apps menu: 0_1567611843267_e4890805-370c-4dac-b435-300a7a0fdb2c-image.png
      Next click on Account. On the left hand side click on Security.
      On the right Select App Passwords and create a password for your app. Copy that key into your mirror where you need to enter the password and that should work.
      • CyruS1337C
        CyruS1337 Project Sponsor
        Hello
        Sorry if I ask again, but unfortunately I can not find it. So I go like this -> Account -> Security and then I do not find what you mean.
        mumblebajM 1 Reply Last reply
        • mumblebajM
          @CyruS1337 No problem:
          When loggin into gmail, on the right hand side there is the “hamburger menu”:
          When you click that you get a list of apps, select Account from there. On the left click security:
          On the right you will see Signing into Google. Click on the “>” on the line “App Passwords”
          On the next screen enter your password and then on the next screen you will be able to create the key.
            i don’t see that on my console… I see
            password
            use your phone
            2-step verification
            • mumblebajM
              @sdetweil Strange. I had to generate a key to get email to work. Not sure why you guys don’t see the option.
              Edit:
              Maybe because your 2FA is turned off.
                sdetweil @mumblebaj
                @mumblebaj yes, had to turn on 2fa… hate that
                • CyruS1337C
                  I do not see it either. I see the same as sdetweil. I’ve also approved third-party apps with account access on this page below.
                  Can I do something that would help you? Post a log or something. You just have to tell me the command;)
                  S mumblebajM 2 Replies Last reply
                    sdetweil @CyruS1337
                    @CyruS1337 you have to turn on 2 step verification (2 factor authentication aka 2fa)
                    • mumblebajM
                      @CyruS1337 I just setup the module and created my app key and email is working for me.
                      And my config: I also had to change fade to false in order for email to display properly
                                      module: 'email',
                                      position: 'top_right',
                                      header: 'Email',
                                               accounts: [
                                                              user: 'xxxxxxxxxxxxx@gmail.com',
                                                              password: 'xxxxxxxxxxxxxxxx',
                                                              host:'imap.gmail.com',
                                                              port: 993,
                                                              tls: true,
                                                              authTimeout: 10000,
                                                              numberOfEmails: 5,
                                              fade: false,
                                              maxCharacters: 30
                      • CyruS1337C
                        Good Morning
                        So I activated the 2FA and replaced the generated key with my password. I also took your config and added my username and password from 2FA. Unfortunately, as before, there is still “load” and it does not show any emails.
                        • CyruS1337C
                          If i enter npm start dev he following will come out:
                          npm ERR! code ENOENT
                          npm ERR! errno -2
                          npm ERR! syscall open
                          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                          npm ERR! enoent This is related to npm not being able to find a file.
                          npm ERR! enoent
                          npm ERR!     /home/pi/.npm/_logs/2019-09-06T07_07_27_973Z-debug.log
                            sdetweil @CyruS1337
                            @CyruS1337 u need to be in the MagicMirror folder before npm start
                            CyruS1337C 1 Reply Last reply
                            • mumblebajM
                              @CyruS1337 I assume that you meant that you replace your password with the generated key? When you run pm2 logs what do you get? Does it show anything for email? Have you in the /modules/email folder run npm install?
                              • CyruS1337C
                                CyruS1337 Project Sponsor @sdetweil
                                That’s right, sorry
                                > magicmirror@2.8.0 start /home/pi/MagicMirror
                                > sh run-start.sh "dev"
                                Starting MagicMirror: v2.8.0
                                Loading config ...
                                Loading module helpers ...
                                Module helper loaded: MMM-SystemStats
                                Module helper loaded: MMM-Remote-Control
                                Module helper loaded: MMM-MyCommute
                                Module helper loaded: MMM-AVStock
                                Module helper loaded: MMM-GoogleMapsTraffic
                                Module helper loaded: MMM-SoccerLiveScore
                                Module helper loaded: email
                                Module helper loaded: MMM-MyCalendar
                                All module helpers loaded.
                                Server started ...
                                Connecting socket for: MMM-SystemStats
                                Connecting socket for: MMM-Remote-Control
                                Starting node helper for: MMM-Remote-Control
                                Connecting socket for: MMM-MyCommute
                                ====================== Starting node_helper for module [MMM-MyCommute]
                                Connecting socket for: MMM-AVStock
                                Connecting socket for: MMM-GoogleMapsTraffic
                                Starting node_helper for module: MMM-GoogleMapsTraffic
                                Connecting socket for: MMM-SoccerLiveScore
                                MMM-SoccerLiveScore helper started...
                                Connecting socket for: email
                                email helper started ...
                                Connecting socket for: MMM-MyCalendar
                                Starting node helper for: MMM-MyCalendar
                                { Error: listen EADDRINUSE 0.0.0.0:8080
                                    at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                                    at listenInCluster (net.js:1378:12)
                                    at doListen (net.js:1492:7)
                                    at process._tickCallback (internal/process/next_tick.js:63:19)
                                    at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
                                    at startup (internal/bootstrap/node.js:241:19)
                                    at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
                                  errno: 'EADDRINUSE',
                                  code: 'EADDRINUSE',
                                  syscall: 'listen',
                                  address: '0.0.0.0',
                                  port: 8080 }
                                Launching application.
                                • CyruS1337C
                                  CyruS1337 Project Sponsor @mumblebaj
                                  @mumblebaj
                                  Exactly, I replaced the password with the key. I have also installed npm.
                                  cd MagicMirror/modules
                                  cd email
                                  npm install
                                  npm WARN email@0.0.1 No repository field.
                                  npm WARN email@0.0.1 No license field.
                                  audited 24 packages in 2.521s
                                  found 0 vulnerabilities
                                  pm2 logs
                                  pi@raspberrypi_LOL:~/MagicMirror/modules/email $ pm2 logs
                                  /home/pi/.pm2/pm2.log last 15 lines:
                                  PM2        | 2019-09-07T04:30:05: PM2 log: App [mm:0] online
                                  PM2        | 2019-09-07T07:40:45: PM2 log: Process 0 in a stopped status, starting it
                                  PM2        | 2019-09-07T07:40:45: PM2 log: Stopping app:mm id:0
                                  PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=failed to kill - retrying in 100ms
                                  PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                  PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=process killed
                                  PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] starting in -fork mode-
                                  PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] online
                                  PM2        | 2019-09-07T07:55:09: PM2 log: Process 0 in a stopped status, starting it
                                  PM2        | 2019-09-07T07:55:09: PM2 log: Stopping app:mm id:0
                                  PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=failed to kill - retrying in 100ms
                                  PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                  PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=process killed
                                  PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] starting in -fork mode-
                                  PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] online
                                  0|mm       | SyntaxError: Unexpected token u in JSON at position 0
                                  0|mm       |     at JSON.parse (<anonymous>)
                                  0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                                  0|mm       |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                  0|mm       |     at Request.emit (events.js:182:13)
                                  0|mm       |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                                  0|mm       |     at ClientRequest.emit (events.js:182:13)
                                  0|mm       |     at TLSSocket.socketErrorListener (_http_client.js:382:9)
                                  0|mm       |     at TLSSocket.emit (events.js:182:13)
                                  0|mm       |     at emitErrorNT (internal/streams/destroy.js:82:8)
                                  0|mm       |     at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
                                  0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                  0|mm       | (node:5525) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                  0|mm       | (node:7860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                  0|mm       | Connecting socket for: email
                                  0|mm       | email helper started ...
                                  0|mm       | Connecting socket for: MMM-MyCalendar
                                  0|mm       | Starting node helper for: MMM-MyCalendar
                                  0|mm       | Sockets connected & modules started ...
                                  0|mm       | Launching application.
                                  0|mm       | [AVSTOCK] Initialized.
                                  0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                                  0|mm       | listening for emails...
                                  0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
                                  0|mm       | NEW MAIL
                                  0|mm       | NEW MAIL
                                  0|mm       | NEW MAIL
                                  0|mm       | NEW MAIL
                                  0|mm       | NEW MAIL
                                    sdetweil @CyruS1337
                                    @CyruS1337 MMM-SoccerLiveScore/ is the one throwing the error… not email
                                    • CyruS1337C
                                      I have disabled the module, but the mails are still not displayed :(
                                      	module: 'MMM-SoccerLiveScore',
                                      	header: 'Fussball Rangliste',
                                      		leagues: [215,399,1],
                                              showNames: true,
                                              showLogos: true,
                                              displayTime: 60 * 1000,
                                              showTables: true
                                        sdetweil @CyruS1337
                                        @CyruS1337 i don’t know anything about email module, i remember it was hard to get working, i didn;t like the results…
                                        anyhow… for the commenting out module,
                                        you can also just add
                                        disabled: true,
                                        to the module info, before/after the module name
                                        disabled: false,
                                        is the default
                                        • CyruS1337C
                                          @sdetweil I do not really like the module any more. I’m trying to get it up and running for a year :)
                                          Thank you very much for your great support
                                          • mumblebajM
                                            @CyruS1337 Please remember, for the emails to display you need to set fade: false.
                                            • 3 / 3
