    Problem with the Module "email"
    57 Posts 4 Posters 37.4k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @CyruS1337
      @CyruS1337 With gmail you have to create an application key on gmail itself. Your email account password would not work.
      CyruS1337C 1 Reply Last reply Reply Quote 0
      • CyruS1337C Offline
        CyruS1337 Project Sponsor @mumblebaj
        @mumblebaj said in Problem with the Module "email":
        And how do I create an application key myself? :-/
          @CyruS1337 In gmail, you need to select the Google Apps menu: 0_1567611843267_e4890805-370c-4dac-b435-300a7a0fdb2c-image.png
          Next click on Account. On the left hand side click on Security.
          On the right Select App Passwords and create a password for your app. Copy that key into your mirror where you need to enter the password and that should work.
            Hello
            Sorry if I ask again, but unfortunately I can not find it. So I go like this -> Account -> Security and then I do not find what you mean.
              @CyruS1337 No problem:
              When loggin into gmail, on the right hand side there is the “hamburger menu”:
              When you click that you get a list of apps, select Account from there. On the left click security:
              On the right you will see Signing into Google. Click on the “>” on the line “App Passwords”
              On the next screen enter your password and then on the next screen you will be able to create the key.
                i don’t see that on my console… I see
                password
                use your phone
                2-step verification
                  @sdetweil Strange. I had to generate a key to get email to work. Not sure why you guys don’t see the option.
                  Edit:
                  Maybe because your 2FA is turned off.
                    sdetweil @mumblebaj
                    @mumblebaj yes, had to turn on 2fa… hate that
                      I do not see it either. I see the same as sdetweil. I’ve also approved third-party apps with account access on this page below.
                      Can I do something that would help you? Post a log or something. You just have to tell me the command;)
                      S mumblebajM 2 Replies Last reply Reply Quote 0
                        sdetweil @CyruS1337
                        @CyruS1337 you have to turn on 2 step verification (2 factor authentication aka 2fa)
                          @CyruS1337 I just setup the module and created my app key and email is working for me.
                          And my config: I also had to change fade to false in order for email to display properly
                                          module: 'email',
                                          position: 'top_right',
                                          header: 'Email',
                                                   accounts: [
        user: 'xxxxxxxxxxxxx@gmail.com',
        password: 'xxxxxxxxxxxxxxxx',
        host:'imap.gmail.com',
        port: 993,
        tls: true,
        authTimeout: 10000,
        numberOfEmails: 5,
                                                  fade: false,
                                                  maxCharacters: 30
                            Good Morning
                            So I activated the 2FA and replaced the generated key with my password. I also took your config and added my username and password from 2FA. Unfortunately, as before, there is still “load” and it does not show any emails.
                              If i enter npm start dev he following will come out:
                              npm ERR! code ENOENT
                              npm ERR! errno -2
                              npm ERR! syscall open
                              npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                              npm ERR! enoent This is related to npm not being able to find a file.
                              npm ERR! enoent
                              npm ERR!     /home/pi/.npm/_logs/2019-09-06T07_07_27_973Z-debug.log
                                sdetweil @CyruS1337
                                @CyruS1337 u need to be in the MagicMirror folder before npm start
                                  @CyruS1337 I assume that you meant that you replace your password with the generated key? When you run pm2 logs what do you get? Does it show anything for email? Have you in the /modules/email folder run npm install?
                                    CyruS1337 Project Sponsor @sdetweil
                                    That’s right, sorry
                                    > magicmirror@2.8.0 start /home/pi/MagicMirror
                                    > sh run-start.sh "dev"
                                    Starting MagicMirror: v2.8.0
                                    Loading config ...
                                    Loading module helpers ...
                                    Module helper loaded: MMM-SystemStats
                                    Module helper loaded: MMM-Remote-Control
                                    Module helper loaded: MMM-MyCommute
                                    Module helper loaded: MMM-AVStock
                                    Module helper loaded: MMM-GoogleMapsTraffic
                                    Module helper loaded: MMM-SoccerLiveScore
                                    Module helper loaded: email
                                    Module helper loaded: MMM-MyCalendar
                                    All module helpers loaded.
                                    Server started ...
                                    Connecting socket for: MMM-SystemStats
                                    Connecting socket for: MMM-Remote-Control
                                    Starting node helper for: MMM-Remote-Control
                                    Connecting socket for: MMM-MyCommute
                                    ====================== Starting node_helper for module [MMM-MyCommute]
                                    Connecting socket for: MMM-AVStock
                                    Connecting socket for: MMM-GoogleMapsTraffic
                                    Starting node_helper for module: MMM-GoogleMapsTraffic
                                    Connecting socket for: MMM-SoccerLiveScore
                                    MMM-SoccerLiveScore helper started...
                                    Connecting socket for: email
                                    email helper started ...
                                    Connecting socket for: MMM-MyCalendar
                                    Starting node helper for: MMM-MyCalendar
                                    { Error: listen EADDRINUSE 0.0.0.0:8080
                                        at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                                        at listenInCluster (net.js:1378:12)
                                        at doListen (net.js:1492:7)
                                        at process._tickCallback (internal/process/next_tick.js:63:19)
                                        at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
                                        at startup (internal/bootstrap/node.js:241:19)
                                        at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
                                      errno: 'EADDRINUSE',
                                      code: 'EADDRINUSE',
                                      syscall: 'listen',
                                      address: '0.0.0.0',
                                      port: 8080 }
                                    Launching application.
                                      @mumblebaj
                                      Exactly, I replaced the password with the key. I have also installed npm.
                                      cd MagicMirror/modules
                                      cd email
                                      npm install
                                      npm WARN email@0.0.1 No repository field.
                                      npm WARN email@0.0.1 No license field.
                                      audited 24 packages in 2.521s
                                      found 0 vulnerabilities
                                      pm2 logs
                                      pi@raspberrypi_LOL:~/MagicMirror/modules/email $ pm2 logs
                                      /home/pi/.pm2/pm2.log last 15 lines:
                                      PM2        | 2019-09-07T04:30:05: PM2 log: App [mm:0] online
                                      PM2        | 2019-09-07T07:40:45: PM2 log: Process 0 in a stopped status, starting it
                                      PM2        | 2019-09-07T07:40:45: PM2 log: Stopping app:mm id:0
                                      PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=failed to kill - retrying in 100ms
                                      PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                      PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=process killed
                                      PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] starting in -fork mode-
                                      PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] online
                                      PM2        | 2019-09-07T07:55:09: PM2 log: Process 0 in a stopped status, starting it
                                      PM2        | 2019-09-07T07:55:09: PM2 log: Stopping app:mm id:0
                                      PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=failed to kill - retrying in 100ms
                                      PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                      PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=process killed
                                      PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] starting in -fork mode-
                                      PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] online
                                      0|mm       | SyntaxError: Unexpected token u in JSON at position 0
                                      0|mm       |     at JSON.parse (<anonymous>)
                                      0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
                                      0|mm       |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                      0|mm       |     at Request.emit (events.js:182:13)
                                      0|mm       |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                                      0|mm       |     at ClientRequest.emit (events.js:182:13)
                                      0|mm       |     at TLSSocket.socketErrorListener (_http_client.js:382:9)
                                      0|mm       |     at TLSSocket.emit (events.js:182:13)
                                      0|mm       |     at emitErrorNT (internal/streams/destroy.js:82:8)
                                      0|mm       |     at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
                                      0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                      0|mm       | (node:5525) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                      0|mm       | (node:7860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                      0|mm       | Connecting socket for: email
                                      0|mm       | email helper started ...
                                      0|mm       | Connecting socket for: MMM-MyCalendar
                                      0|mm       | Starting node helper for: MMM-MyCalendar
                                      0|mm       | Sockets connected & modules started ...
                                      0|mm       | Launching application.
                                      0|mm       | [AVSTOCK] Initialized.
                                      0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
                                      0|mm       | listening for emails...
                                      0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
                                      0|mm       | NEW MAIL
                                      0|mm       | NEW MAIL
                                      0|mm       | NEW MAIL
                                      0|mm       | NEW MAIL
                                      0|mm       | NEW MAIL
                                        sdetweil @CyruS1337
                                        @CyruS1337 MMM-SoccerLiveScore/ is the one throwing the error… not email
                                          I have disabled the module, but the mails are still not displayed :(
                                          	module: 'MMM-SoccerLiveScore',
                                          	header: 'Fussball Rangliste',
                                          		leagues: [215,399,1],
                                                  showNames: true,
                                                  showLogos: true,
                                                  displayTime: 60 * 1000,
                                                  showTables: true
                                            sdetweil @CyruS1337
                                            @CyruS1337 i don’t know anything about email module, i remember it was hard to get working, i didn;t like the results…
                                            anyhow… for the commenting out module,
                                            you can also just add
                                            disabled: true,
                                            to the module info, before/after the module name
                                            disabled: false,
                                            is the default
                                            • 3 / 3
