Unsolved snowboy Install Failure
Ok, here’s the bog standard config with just the hotword module loaded, still don’t get an icon for it.
I am noticing that in the terminal window there is a
[HOTWORD] No model to loadEven though there are models in the directory
/home/pi/MagicMirror/modules/MMM-Hotword/models
as well as
/home/pi/MagicMirror/modules/MMM-Hotword/snoboy/resources/models/* Magic Mirror Config Sample
*- By Michael Teeuw http://michaelteeuw.nl
- MIT Licensed.
- For more information how you can configurate this file
- See https://github.com/MichMich/MagicMirror#configuration
var config = {
// - “”, “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out, is “localhost”
port: 8080,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],language: "en", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, //Hotword Module
module: “MMM-Hotword”,
record: {
recordProgram : “arecord”,
device : “plughw:1”,
autostart:true,
onDetected: {
notification: function (payload) {
return “ASSISTANT_ACTIVATE”
payload: function (payload){
return {
profile: payload.hotword
if (typeof module !== “undefined”) {module.exports = config;} -
@binaryhellstorm
You haven’t described “models” in your configuration.
https://github.com/eouia/MMM-Hotword/blob/master/documents/config.md -
Awesome! That was it, thanks so much for the help.
@binaryhellstorm After fixing this error, Does your magic mirror in snowboy,hotword is work on Google Ai?
The hotword detection is working and it’s passing it to the Google Assistant module and that module is working too
@binaryhellstorm Can you show me the modified config file or e-mail it to me?
@kai did you vr get the updated config ? i am also in need
@citizendevpi no I’ve not yet
@kai i use the sample config
{ module: "MMM-Hotword", position: "top_right", config: { chimeOnFinish: null, mic: { recordProgram: "arecord", device: "plughw:1" }, models: [ // this is the start of the models, note this is an array, so you can have multiple word choices { hotwords : "computer", // what word you expect to hear file : "computer.umdl", // where it gets the wave pattern model file sensitivity : "0.5", }, ], commands: { "computer": { notificationExec: { notification: "ASSISTANT_ACTIVATE", payload: (detected, afterRecord) => { return {profile:"default"} } }, restart:false, afterRecordLimit:0 } } } },
