    snowboy Install Failure
    13 Posts 5 Posters 5.3k Views 5 Watching
      A Former User @binaryhellstorm
      @binaryhellstorm
      You haven’t described “models” in your configuration.
      https://github.com/eouia/MMM-Hotword/blob/master/documents/config.md
        binaryhellstorm
        Awesome! That was it, thanks so much for the help.
          @binaryhellstorm After fixing this error, Does your magic mirror in snowboy,hotword is work on Google Ai?
            binaryhellstorm
            The hotword detection is working and it’s passing it to the Google Assistant module and that module is working too
            ? 1 Reply Last reply Reply Quote 1
              @binaryhellstorm Can you show me the modified config file or e-mail it to me?
              citizendevpiC S 2 Replies Last reply Reply Quote 0
              • citizendevpiC Offline
                citizendevpi @Guest
                @kai did you vr get the updated config ? i am also in need
                  A Former User @citizendevpi
                  @citizendevpi no I’ve not yet
                    sdetweil @Guest
                    @kai i use the sample config
                      module: "MMM-Hotword",
                        chimeOnFinish: null,
                        mic: {
                          recordProgram: "arecord",
                          device: "plughw:1"
                        models: [    // this is the start of the models, note this is an array, so you can have multiple word choices
                            hotwords    : "computer",  // what word you expect to hear
                            file        : "computer.umdl",  // where it gets the wave pattern model file
                            sensitivity : "0.5",
                        commands: {
                          "computer": {
                            notificationExec: {
                              notification: "ASSISTANT_ACTIVATE",
                              payload: (detected, afterRecord) => {
                                return {profile:"default"}
                            restart:false,
                            afterRecordLimit:0
