    snowboy Install Failure
    13 Posts 5 Posters 6.2k Views 5 Watching
      binaryhellstorm
      Ah Ok, I guess I assumed the errors were bad.
      So then I guess my next question is, why would Hotword detection not work? I’ve enabled it in the config.js and I get the Google Assistant icon at the bottom of my screen, but no hotword icon, and saying any of the built in hotwords doesn’t seem to do anything.
      I’ve done test recordings from command line and the microphone is picking up audio, but just no dice on getting the mirror to respond to voice commands.
        [[global:former-user]] @binaryhellstorm
        @binaryhellstorm
        First, you’d better check Hotword standalone without other modules in config.js (to make things simple)
        Backup your current config.js and make a new one, which has only MMM-Hotword and other modules be removed.
        Then try to execute and see the log (It is convenient to use npm start dev instead pm2), If there is some issue, it will be logged.
        Then show me your config.
          binaryhellstorm
          Ok, here’s the bog standard config with just the hotword module loaded, still don’t get an icon for it.
          I am noticing that in the terminal window there is a
          [HOTWORD] No model to load
          Even though there are models in the directory
          /home/pi/MagicMirror/modules/MMM-Hotword/models
          as well as
          /home/pi/MagicMirror/modules/MMM-Hotword/snoboy/resources/models
          /* Magic Mirror Config Sample
          • MIT Licensed.
          • For more information how you can configurate this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          // - “”, “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out, is “localhost”
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 24,
          units: "metric",
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "US Holidays",
          					symbol: "calendar-check",
          					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          		module: "compliments",
          		position: "lower_third"
          		module: "currentweather",
          			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          		module: "weatherforecast",
          		header: "Weather Forecast",
          			locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "New York Times",
          			showSourceTitle: true,
          			showPublishDate: true,
          			broadcastNewsFeeds: true,
          			broadcastNewsUpdates: true
          	//Hotword Module
          module: “MMM-Hotword”,
          record: {
          recordProgram : “arecord”,
          device : “plughw:1”,
          autostart:true,
          onDetected: {
          notification: function (payload) {
          return “ASSISTANT_ACTIVATE”
          payload: function (payload){
          return {
          profile: payload.hotword
          if (typeof module !== “undefined”) {module.exports = config;}
            @binaryhellstorm
            You haven’t described “models” in your configuration.
            https://github.com/eouia/MMM-Hotword/blob/master/documents/config.md
              binaryhellstorm
              Awesome! That was it, thanks so much for the help.
                @binaryhellstorm After fixing this error, Does your magic mirror in snowboy,hotword is work on Google Ai?
                  binaryhellstorm
                  The hotword detection is working and it’s passing it to the Google Assistant module and that module is working too
                  ? 1 Reply Last reply Reply Quote 1
                    @binaryhellstorm Can you show me the modified config file or e-mail it to me?
                    citizendevpiC S 2 Replies Last reply Reply Quote 0
                    • citizendevpiC Offline
                      citizendevpi @Guest
                      @kai did you vr get the updated config ? i am also in need
                        [[global:former-user]] @citizendevpi
                        @citizendevpi no I’ve not yet
                          sdetweil @Guest
                          @kai i use the sample config
                            module: "MMM-Hotword",
                              chimeOnFinish: null,
                              mic: {
                                recordProgram: "arecord",
                                device: "plughw:1"
                              models: [    // this is the start of the models, note this is an array, so you can have multiple word choices
                                  hotwords    : "computer",  // what word you expect to hear
                                  file        : "computer.umdl",  // where it gets the wave pattern model file
                                  sensitivity : "0.5",
                              commands: {
                                "computer": {
                                  notificationExec: {
                                    notification: "ASSISTANT_ACTIVATE",
                                    payload: (detected, afterRecord) => {
                                      return {profile:"default"}
                                  restart:false,
                                  afterRecordLimit:0
