    snowboy Install Failure
    13 Posts 5 Posters 6.0k Views 5 Watching
      binaryhellstorm
      I’m trying to set up Google Assistant with hotword detection.
      I’ve follow the tutorials on Github, but when I try to install snowboy I’m getting the output below.
      I am running the latest Raspian build on a Pi 3. I’ve uninstalled and tried multiple times to install, I’ve even blown away the whole OS and Magic Mirror install and started from scratch.
      pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ ./installer/install.sh
      Cloning into ‘snowboy’…
      remote: Enumerating objects: 6, done.
      remote: Counting objects: 100% (6/6), done.
      remote: Compressing objects: 100% (4/4), done.
      remote: Total 2131 (delta 2), reused 5 (delta 2), pack-reused 2125
      Receiving objects: 100% (2131/2131), 55.22 MiB | 4.97 MiB/s, done.
      Resolving deltas: 100% (1060/1060), done.
      Checking out files: 100% (313/313), done.
      npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
      npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
      npm notice created a lockfile as package-lock.json. You should commit this file.
      • nan@2.14.0
      • node-pre-gyp@0.6.39
        added 115 packages from 85 contributors and audited 269 packages in 23.482s
        found 8 moderate severity vulnerabilities
        run npm audit fix to fix them, or npm audit for details
        node-pre-gyp info it worked if it ends with ok
        node-pre-gyp info using node-pre-gyp@0.6.39
        node-pre-gyp info using node@10.15.2 | linux | arm
        gyp info using node-gyp@3.8.0
        gyp info spawn /usr/bin/python2
        gyp info spawn args [ ‘/usr/share/node-gyp/gyp/gyp_main.py’,
        gyp info spawn args ‘binding.gyp’,
        gyp info spawn args ‘-f’,
        gyp info spawn args ‘make’,
        gyp info spawn args ‘-I’,
        gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/build/config.gypi’,
        gyp info spawn args ‘/usr/share/node-gyp/addon.gypi’,
        gyp info spawn args ‘/usr/include/nodejs/common.gypi’,
        gyp info spawn args ‘-Dlibrary=shared_library’,
        gyp info spawn args ‘-Dvisibility=default’,
        gyp info spawn args ‘-Dnode_root_dir=/usr/include/nodejs’,
        gyp info spawn args ‘-Dnode_gyp_dir=/usr/share/node-gyp’,
        gyp info spawn args ‘-Dnode_lib_file=/usr/include/nodejs/<(target_arch)/node.lib’,
        gyp info spawn args ‘-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Hotword/snowboy’,
        gyp info spawn args ‘-Dnode_engine=v8’,
        gyp info spawn args ‘–depth=.’,
        gyp info spawn args ‘–no-parallel’,
        gyp info spawn args ‘–generator-output’,
        gyp info spawn args ‘build’,
        gyp info spawn args ‘-Goutput_dir=.’ ]
        gyp info ok
        gyp info spawn make
        gyp info spawn args [ ‘BUILDTYPE=Release’, ‘-C’, ‘build’ ]
        make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/build’
        CXX(target) Release/obj.target/snowboy/swig/Node/snowboy.o
        In file included from …/swig/Node/snowboy.cc:1:
        …/node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        …/node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
        , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        …/swig/Node/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
        …/swig/Node/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
        } catch (std::runtime_error e) {
        In file included from …/node_modules/nan/nan.h:54,
        …/swig/Node/snowboy.cc: At global scope:
        /usr/include/nodejs/src/node.h:570:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
        (node::addon_register_func) (regfunc),
        /usr/include/nodejs/src/node.h:604:3: note: in expansion of macro ‘NODE_MODULE_X’
        NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
        …/swig/Node/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
        NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
        In file included from /usr/include/nodejs/src/node.h:63,
        /usr/include/nodejs/deps/v8/include/v8.h: In instantiation of ‘void v8::PersistentBase::SetWeak(P*, typename v8::WeakCallbackInfo
        ::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
        ::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
        /usr/include/nodejs/src/node_object_wrap.h:85:78: required from here
        /usr/include/nodejs/deps/v8/include/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void (
        )(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
        reinterpret_cast(callback), type);
        ::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
        ::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
        …/node_modules/nan/nan_object_wrap.h:65:61: required from here
        /usr/include/nodejs/deps/v8/include/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void (
        )(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
        SOLINK_MODULE(target) Release/obj.target/snowboy.node
        COPY Release/snowboy.node
        COPY /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node
        TOUCH Release/obj.target/action_after_build.stamp
        make: Leaving directory ‘/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/build’
        gyp info ok
        node-pre-gyp info ok
      snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/snowboy
      node-pre-gyp install --fallback-to-build
      [snowboy] Success: “/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” already installed
      Pass --update-binary to reinstall or --build-from-source to recompile
      npm WARN prepublish-on-install As of npm@5, prepublish scripts are deprecated.
      npm WARN prepublish-on-install Use prepare for build steps and prepublishOnly for upload-only.
      npm WARN prepublish-on-install See the deprecation note in npm help scripts for more information.
      snowboy@1.3.1 prepublish /home/pi/MagicMirror/modules/MMM-Hotword/snowboy
      tsc --listFiles
      …/…/…/node_modules/@types/unist/index.d.ts:31:20 - error TS2304: Cannot find name ‘unknown’.
      31 [key: string]: unknown;
      …/…/…/node_modules/@types/unist/index.d.ts:40:20 - error TS2304: Cannot find name ‘unknown’.
      40 [key: string]: unknown;
      …/…/…/node_modules/@types/unist/index.d.ts:97:12 - error TS2304: Cannot find name ‘unknown’.
      97 value: unknown;
      …/…/…/node_modules/@types/vfile-message/index.d.ts:69:24 - error TS2304: Cannot find name ‘unknown’.
      69 [key: string]: unknown;
      …/…/…/node_modules/@types/vfile/index.d.ts:48:15 - error TS2304: Cannot find name ‘unknown’.
      48 data: unknown;
      /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/node_modules/typescript/lib/lib.es6.d.ts
      /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.ts
      /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/node-pre-gyp.d.ts
      /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/SnowboyDetectNative.d.ts
      /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/node_modules/@types/node/base.d.ts
      /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/node_modules/@types/node/index.d.ts
      /home/pi/MagicMirror/node_modules/@types/events/index.d.ts
      /home/pi/MagicMirror/node_modules/@types/minimatch/index.d.ts
      /home/pi/MagicMirror/node_modules/@types/glob/index.d.ts
      /home/pi/MagicMirror/node_modules/@types/unist/index.d.ts
      /home/pi/MagicMirror/node_modules/@types/vfile-message/index.d.ts
      /home/pi/MagicMirror/node_modules/@types/vfile/index.d.ts
      npm ERR! code ELIFECYCLE
      npm ERR! errno 2
      npm ERR! snowboy@1.3.1 prepublish: tsc --listFiles
      npm ERR! Exit status 2
      npm ERR!
      npm ERR! Failed at the snowboy@1.3.1 prepublish script.
      npm ERR! /home/pi/.npm/_logs/2019-09-15T03_46_46_443Z-debug.log
      • electron-rebuild@1.8.6
        added 91 packages from 76 contributors, removed 15 packages and audited 508 packages in 30.672s
        ✔ Rebuild Complete
        electron-v3.1-linux-arm node-v64-linux-arm
        lib/node/index.js
        [[global:former-user]] @binaryhellstorm
        @binaryhellstorm
        ✔ Rebuild Complete
        lib/node/index.js
        means you completed installation finally.
          binaryhellstorm
          Ah Ok, I guess I assumed the errors were bad.
          So then I guess my next question is, why would Hotword detection not work? I’ve enabled it in the config.js and I get the Google Assistant icon at the bottom of my screen, but no hotword icon, and saying any of the built in hotwords doesn’t seem to do anything.
          I’ve done test recordings from command line and the microphone is picking up audio, but just no dice on getting the mirror to respond to voice commands.
            @binaryhellstorm
            First, you’d better check Hotword standalone without other modules in config.js (to make things simple)
            Backup your current config.js and make a new one, which has only MMM-Hotword and other modules be removed.
            Then try to execute and see the log (It is convenient to use npm start dev instead pm2), If there is some issue, it will be logged.
            Then show me your config.
              binaryhellstorm
              Ok, here’s the bog standard config with just the hotword module loaded, still don’t get an icon for it.
              I am noticing that in the terminal window there is a
              [HOTWORD] No model to load
              Even though there are models in the directory
              /home/pi/MagicMirror/modules/MMM-Hotword/models
              as well as
              /home/pi/MagicMirror/modules/MMM-Hotword/snoboy/resources/models
              /* Magic Mirror Config Sample
              • MIT Licensed.
              • For more information how you can configurate this file
              • See https://github.com/MichMich/MagicMirror#configuration
              var config = {
              // - “”, “0.0.0.0”, “::” to listen on any interface
              // Default, when address config is left out, is “localhost”
              port: 8080,
              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
              language: "en",
              timeFormat: 24,
              units: "metric",
              		module: "alert",
              		module: "updatenotification",
              		position: "top_bar"
              		module: "clock",
              		position: "top_left"
              		header: "US Holidays",
              					symbol: "calendar-check",
              					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
              		module: "compliments",
              		position: "lower_third"
              		module: "currentweather",
              			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              		module: "weatherforecast",
              		header: "Weather Forecast",
              			locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              		module: "newsfeed",
              		position: "bottom_bar",
              			feeds: [
              					title: "New York Times",
              			showSourceTitle: true,
              			showPublishDate: true,
              			broadcastNewsFeeds: true,
              			broadcastNewsUpdates: true
              	//Hotword Module
              module: “MMM-Hotword”,
              record: {
              recordProgram : “arecord”,
              device : “plughw:1”,
              autostart:true,
              onDetected: {
              notification: function (payload) {
              return “ASSISTANT_ACTIVATE”
              payload: function (payload){
              return {
              profile: payload.hotword
              if (typeof module !== “undefined”) {module.exports = config;}
                @binaryhellstorm
                You haven’t described “models” in your configuration.
                https://github.com/eouia/MMM-Hotword/blob/master/documents/config.md
                  binaryhellstorm
                  Awesome! That was it, thanks so much for the help.
                    @binaryhellstorm After fixing this error, Does your magic mirror in snowboy,hotword is work on Google Ai?
                      binaryhellstorm
                      The hotword detection is working and it’s passing it to the Google Assistant module and that module is working too
                      ? 1 Reply Last reply Reply Quote 1
                        @binaryhellstorm Can you show me the modified config file or e-mail it to me?
                        citizendevpiC S 2 Replies Last reply Reply Quote 0
                        • citizendevpiC Offline
                          citizendevpi @Guest
                          @kai did you vr get the updated config ? i am also in need
                            [[global:former-user]] @citizendevpi
                            @citizendevpi no I’ve not yet
                              sdetweil @Guest
                              @kai i use the sample config
                                module: "MMM-Hotword",
                                  chimeOnFinish: null,
                                  mic: {
                                    recordProgram: "arecord",
                                    device: "plughw:1"
                                  models: [    // this is the start of the models, note this is an array, so you can have multiple word choices
                                      hotwords    : "computer",  // what word you expect to hear
                                      file        : "computer.umdl",  // where it gets the wave pattern model file
                                      sensitivity : "0.5",
                                  commands: {
                                    "computer": {
                                      notificationExec: {
                                        notification: "ASSISTANT_ACTIVATE",
                                        payload: (detected, afterRecord) => {
                                          return {profile:"default"}
                                      restart:false,
                                      afterRecordLimit:0
