    snowboy Install Failure
    13 Posts 5 Posters 5.2k Views 5 Watching
      binaryhellstorm
      Ok, here’s the bog standard config with just the hotword module loaded, still don’t get an icon for it.
      I am noticing that in the terminal window there is a
      [HOTWORD] No model to load
      Even though there are models in the directory
      /home/pi/MagicMirror/modules/MMM-Hotword/models
      as well as
      /home/pi/MagicMirror/modules/MMM-Hotword/snoboy/resources/models
      /* Magic Mirror Config Sample
      • MIT Licensed.
      • For more information how you can configurate this file
      • See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: "en",
      timeFormat: 24,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "US Holidays",
      					symbol: "calendar-check",
      					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      		module: "compliments",
      		position: "lower_third"
      		module: "currentweather",
      			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      		module: "weatherforecast",
      		header: "Weather Forecast",
      			locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true,
      			broadcastNewsFeeds: true,
      			broadcastNewsUpdates: true
      	//Hotword Module
      module: “MMM-Hotword”,
      record: {
      recordProgram : “arecord”,
      device : “plughw:1”,
      autostart:true,
      onDetected: {
      notification: function (payload) {
      return “ASSISTANT_ACTIVATE”
      payload: function (payload){
      return {
      profile: payload.hotword
      if (typeof module !== “undefined”) {module.exports = config;}
        A Former User @binaryhellstorm
        @binaryhellstorm
        You haven’t described “models” in your configuration.
        https://github.com/eouia/MMM-Hotword/blob/master/documents/config.md
          binaryhellstorm
          Awesome! That was it, thanks so much for the help.
            @binaryhellstorm After fixing this error, Does your magic mirror in snowboy,hotword is work on Google Ai?
              binaryhellstorm
              The hotword detection is working and it’s passing it to the Google Assistant module and that module is working too
              ? 1 Reply Last reply Reply Quote 1
                @binaryhellstorm Can you show me the modified config file or e-mail it to me?
                citizendevpiC S 2 Replies Last reply Reply Quote 0
                • citizendevpiC Offline
                  citizendevpi @Guest
                  @kai did you vr get the updated config ? i am also in need
                    A Former User @citizendevpi
                    @citizendevpi no I’ve not yet
                      sdetweil @Guest
                      @kai i use the sample config
                        module: "MMM-Hotword",
                          chimeOnFinish: null,
                          mic: {
                            recordProgram: "arecord",
                            device: "plughw:1"
                          models: [    // this is the start of the models, note this is an array, so you can have multiple word choices
                              hotwords    : "computer",  // what word you expect to hear
                              file        : "computer.umdl",  // where it gets the wave pattern model file
                              sensitivity : "0.5",
                          commands: {
                            "computer": {
                              notificationExec: {
                                notification: "ASSISTANT_ACTIVATE",
                                payload: (detected, afterRecord) => {
                                  return {profile:"default"}
                              restart:false,
                              afterRecordLimit:0
