    snowboy Install Failure
    13 Posts 5 Posters 6.2k Views 5 Watching
      A Former User @binaryhellstorm
      @binaryhellstorm
      ✔ Rebuild Complete
      electron-v3.1-linux-arm node-v64-linux-arm
      lib/node/index.js
      means you completed installation finally.
        binaryhellstorm
        Ah Ok, I guess I assumed the errors were bad.
        So then I guess my next question is, why would Hotword detection not work? I’ve enabled it in the config.js and I get the Google Assistant icon at the bottom of my screen, but no hotword icon, and saying any of the built in hotwords doesn’t seem to do anything.
        I’ve done test recordings from command line and the microphone is picking up audio, but just no dice on getting the mirror to respond to voice commands.
          @binaryhellstorm
          First, you’d better check Hotword standalone without other modules in config.js (to make things simple)
          Backup your current config.js and make a new one, which has only MMM-Hotword and other modules be removed.
          Then try to execute and see the log (It is convenient to use npm start dev instead pm2), If there is some issue, it will be logged.
          Then show me your config.
            binaryhellstorm
            Ok, here’s the bog standard config with just the hotword module loaded, still don’t get an icon for it.
            I am noticing that in the terminal window there is a
            [HOTWORD] No model to load
            Even though there are models in the directory
            /home/pi/MagicMirror/modules/MMM-Hotword/models
            as well as
            /home/pi/MagicMirror/modules/MMM-Hotword/snoboy/resources/models
            /* Magic Mirror Config Sample
            • MIT Licensed.
            • For more information how you can configurate this file
            • See https://github.com/MichMich/MagicMirror#configuration
            var config = {
            // - “”, “0.0.0.0”, “::” to listen on any interface
            // Default, when address config is left out, is “localhost”
            port: 8080,
            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
            language: "en",
            timeFormat: 24,
            units: "metric",
            		module: "alert",
            		module: "updatenotification",
            		position: "top_bar"
            		module: "clock",
            		position: "top_left"
            		header: "US Holidays",
            					symbol: "calendar-check",
            					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
            		module: "compliments",
            		position: "lower_third"
            		module: "currentweather",
            			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            		module: "weatherforecast",
            		header: "Weather Forecast",
            			locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            		module: "newsfeed",
            		position: "bottom_bar",
            			feeds: [
            					title: "New York Times",
            			showSourceTitle: true,
            			showPublishDate: true,
            			broadcastNewsFeeds: true,
            			broadcastNewsUpdates: true
            	//Hotword Module
            module: “MMM-Hotword”,
            record: {
            recordProgram : “arecord”,
            device : “plughw:1”,
            autostart:true,
            onDetected: {
            notification: function (payload) {
            return “ASSISTANT_ACTIVATE”
            payload: function (payload){
            return {
            profile: payload.hotword
            if (typeof module !== “undefined”) {module.exports = config;}
              @binaryhellstorm
              You haven’t described “models” in your configuration.
              https://github.com/eouia/MMM-Hotword/blob/master/documents/config.md
                binaryhellstorm
                Awesome! That was it, thanks so much for the help.
                  @binaryhellstorm After fixing this error, Does your magic mirror in snowboy,hotword is work on Google Ai?
                    binaryhellstorm
                    The hotword detection is working and it’s passing it to the Google Assistant module and that module is working too
                    ? 1 Reply Last reply Reply Quote 1
                      @binaryhellstorm Can you show me the modified config file or e-mail it to me?
                      citizendevpiC S 2 Replies Last reply Reply Quote 0
                      • citizendevpiC Offline
                        citizendevpi @Guest
                        @kai did you vr get the updated config ? i am also in need
                          A Former User @citizendevpi
                          @citizendevpi no I’ve not yet
                            sdetweil @Guest
                            @kai i use the sample config
                              module: "MMM-Hotword",
                                chimeOnFinish: null,
                                mic: {
                                  recordProgram: "arecord",
                                  device: "plughw:1"
                                models: [    // this is the start of the models, note this is an array, so you can have multiple word choices
                                    hotwords    : "computer",  // what word you expect to hear
                                    file        : "computer.umdl",  // where it gets the wave pattern model file
                                    sensitivity : "0.5",
                                commands: {
                                  "computer": {
                                    notificationExec: {
                                      notification: "ASSISTANT_ACTIVATE",
                                      payload: (detected, afterRecord) => {
                                        return {profile:"default"}
                                    restart:false,
                                    afterRecordLimit:0
