    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 53.3k Views 2 Watching
      jmartin1009 @sdetweil
      @sdetweil i accidentally installed it in the folder previous to MM, but it still worked, but im installing it in the MM folder right now. Thought you meant the first level cd. Should i remove it in the pi folder? If so how because it doesn’t show up
        sdetweil @jmartin1009
        @jmartin1009 sure
        cd ~
        npm uninstall rrule
        J 1 Reply Last reply
          @sdetweil how do i fix this?
          pi@raspberrypi:~/MagicMirror $ npm install rrule
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          + rrule@2.6.2
          added 2 packages from 2 contributors and audited 2431 packages in 49.239s
          found 4 vulnerabilities (2 low, 2 high)
            run `npm audit fix` to fix them, or `npm audit` for details
          pi@raspberrypi:~/MagicMirror $ npm audit fix
          up to date in 51.138s
          fixed 0 of 4 vulnerabilities in 2431 scanned packages
            2 package updates for 4 vulns involved breaking changes
            (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
          Thanks for all your help btw
            @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
            it says
            run npm audit fix to fix them
            many times you cannot fix them all… so, after one try, ignore it
              @sdetweil Okay! Do you know anything about MM-voice? having issues with that for some reason and i can’t figure out why.
                @jmartin1009 yes, what troubles? i have it installed on one of my MagicMirror systems…
                  @sdetweil I have it installed but when i run MM, the little microphone says initializing, then ERROR. I used debug: true, and the file said
                    @jmartin1009 ok. usually this is the device name of the mic…
                    run
                    arecord -l
                    to get the list of mic devices
                    make sure that is in the MMM-Voice config, mine is
                                  microphone: '1,0',
                      pi@raspberrypi:~ $ arecord -l
                      **** List of CAPTURE Hardware Devices ****
                      card 1: Snowball [Blue Snowball], device 0: USB Audio [USB Audio]
                        Subdevices: 1/1
                        Subdevice #0: subdevice #0
                      does this mean it is 1 or 1,0?
                        @jmartin1009
                        card 1
                        device 0
                        1,0
                        you can also test the mic with
                        arecord -D hw:1,0 test.wav
                        ctrl-break , ctrl-c, or ctrl-z after saying something
                        then
                        aplay test.wav
                        to hear the recorded voice back
                          @sdetweil should i change it in MM’s config file? or MM-voice’s file:MM-voice.js? and if the second, where?
                            @jmartin1009 never change anything in the module folder, only the config.js for magic mirror
                              @sdetweil so it should look like this?
                              		        module: 'MMM-voice',
                              		        position: 'upper_third',
                              		            microphone: '1,0',
                              		            keyword: 'Magic Mirror',
                              			    timeout: 15,
                                @jmartin1009 yes
                                mine looks like
                                        position: 'bottom_bar',
                                              microphone: '1,0',
                                              keyword:        'MAGIC MIRROR',
                                              timeout:        15,
                                              debug: true,
                                              standByMethod: 'hide',
                                              startHidden: false
                                J 2 Replies Last reply
                                  @sdetweil okay ,i will run it and see what happens.
                                    @sdetweil still came up saying error :(
                                      @jmartin1009 ok, add debug: yes,
                                      to the config
                                      run again and then look at the debug log in the modules/mmm-Voice folder
                                        @sdetweil when i add debug: yes, it fails and says this in the terminal:
                                        > magicmirror@2.6.0 start /home/pi/MagicMirror
                                        > sh run-start.sh
                                        Starting MagicMirror: v2.6.0
                                        Loading config ...
                                        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: yes is not defined
                                            at Object.<anonymous> (/home/pi/MagicMirror/config/config.js:80:15)
                                            at Object.<anonymous> (/home/pi/MagicMirror/config/config.js:123:3)
                                            at Module._compile (module.js:642:30)
                                            at Object.Module._extensions..js (module.js:653:10)
                                            at Module.load (module.js:561:32)
                                            at tryModuleLoad (module.js:504:12)
                                            at Function.Module._load (module.js:496:3)
                                            at Module.require (module.js:586:17)
                                            at require (internal/module.js:11:18)
                                            at loadConfig (/home/pi/MagicMirror/js/app.js:64:12)
                                        Loading module helpers ...
                                        No helper found for module: helloworld.
                                        All module helpers loaded.
                                        Server started ...
                                        Launching application.
                                        Shutting down server...
                                        Stopping module helper: updatenotification
                                          jmartin1009 @jmartin1009
                                          @jmartin1009 AH! it is debug: true, not yes haha after that, it says in debug.log, SORRY FOR LENGTH:
                                          INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                                          Current configuration:
                                          [NAME]			[DEFLT]		[VALUE]
                                          -agc			none		none
                                          -agcthresh		2.0		2.000000e+00
                                          -allphone
                                          -allphone_ci		yes		yes
                                          -alpha			0.97		9.700000e-01
                                          -ascale			20.0		2.000000e+01
                                          -aw			1		1
                                          -backtrace		no		no
                                          -beam			1e-48		1.000000e-48
                                          -bestpath		yes		yes
                                          -bestpathlw		9.5		9.500000e+00
                                          -ceplen			13		13
                                          -cmn			live		batch
                                          -cmninit		40,3,-1		41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                                          -compallsen		no		no
                                          -dict					modules/MMM-voice/MMM-voice.dic
                                          -dictcase		no		no
                                          -dither			no		no
                                          -doublebw		no		no
                                          -ds			1		1
                                          -fdict
                                          -feat			1s_c_d_dd	1s_c_d_dd
                                          -featparams
                                          -fillprob		1e-8		1.000000e-08
                                          -frate			100		100
                                          -fsg
                                          -fsgusealtpron		yes		yes
                                          -fsgusefiller		yes		yes
                                          -fwdflat		yes		yes
                                          -fwdflatbeam		1e-64		1.000000e-64
                                          -fwdflatefwid		4		4
                                          -fwdflatlw		8.5		8.500000e+00
                                          -fwdflatsfwin		25		25
                                          -fwdflatwbeam		7e-29		7.000000e-29
                                          -fwdtree		yes		yes
                                          -hmm					/usr/local/share/pocketsphinx/model/en-us/en-us
                                          -input_endian		little		little
                                          -jsgf
                                          -keyphrase
                                          -kws
                                          -kws_delay		10		10
                                          -kws_plp		1e-1		1.000000e-01
                                          -kws_threshold		1e-30		1.000000e-30
                                          -latsize		5000		5000
                                          -lda
                                          -ldadim			0		0
                                          -lifter			0		22
                                          -lm					modules/MMM-voice/MMM-voice.lm
                                          -lmctl
                                          -lmname
                                          -logbase		1.0001		1.000100e+00
                                          -logfn
                                          -logspec		no		no
                                          -lowerf			133.33334	1.300000e+02
                                          -lpbeam			1e-40		1.000000e-40
                                          -lponlybeam		7e-29		7.000000e-29
                                          -lw			6.5		6.500000e+00
                                          -maxhmmpf		30000		30000
                                          -maxwpf			-1		-1
                                          -mdef
                                          -mean
                                          -mfclogdir
                                          -min_endfr		0		0
                                          -mixw
                                          -mixwfloor		0.0000001	1.000000e-07
                                          -mllr
                                          -mmap			yes		yes
                                          -ncep			13		13
                                          -nfft			512		512
                                          -nfilt			40		25
                                          -nwpen			1.0		1.000000e+00
                                          -pbeam			1e-48		1.000000e-48
                                          -pip			1.0		1.000000e+00
                                          -pl_beam		1e-10		1.000000e-10
                                          -pl_pbeam		1e-10		1.000000e-10
                                          -pl_pip			1.0		1.000000e+00
                                          -pl_weight		3.0		3.000000e+00
                                          -pl_window		5		5
                                          -rawlogdir
                                          -remove_dc		no		no
                                          -remove_noise		yes		yes
                                          -remove_silence		yes		yes
                                          -round_filters		yes		yes
                                          -samprate		16000		1.600000e+04
                                          -seed			-1		-1
                                          -sendump
                                          -senlogdir
                                          -senmgau
                                          -silprob		0.005		5.000000e-03
                                          -smoothspec		no		no
                                          -svspec					0-12/13-25/26-38
                                          -tmat
                                          -tmatfloor		0.0001		1.000000e-04
                                          -topn			4		4
                                          -topn_beam		0		0
                                          -toprule
                                          -transform		legacy		dct
                                          -unit_area		yes		yes
                                          -upperf			6855.4976	6.800000e+03
                                          -uw			1.0		1.000000e+00
                                          -vad_postspeech		50		50
                                          -vad_prespeech		20		20
                                          -vad_startspeech	10		10
                                          -vad_threshold		3.0		3.000000e+00
                                          -var
                                          -varfloor		0.0001		1.000000e-04
                                          -varnorm		no		no
                                          -verbose		no		no
                                          -warp_params
                                          -warp_type		inverse_linear	inverse_linear
                                          -wbeam			7e-29		7.000000e-29
                                          -wip			0.65		6.500000e-01
                                          -wlen			0.025625	2.562500e-02
                                          INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none'
                                          INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                                          INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                          INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                                          INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                          INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                                          INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                                          INFO: acmod.c(113): Attempting to use PTM computation module
                                          INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                                          INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                                          INFO: ms_gauden.c(244):  128x13
                                          INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                                          INFO: ms_gauden.c(304): 222 variance values floored
                                          INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                                          INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                                          INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                                          INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                                          INFO: ptm_mgau.c(837): Maximum top-N: 4
                                          INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                                          INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                                          INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic
                                          INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                                          INFO: dict.c(336): 29 words read
                                          INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                                          INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                                          INFO: dict.c(361): 5 words read
                                          INFO: dict2pid.c(396): Building PID tables for dictionary
                                          INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                                          INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                                          INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                                          INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                                          INFO: ngram_model_trie.c(365): Header doesn't match
                                          INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                                          INFO: ngram_model_trie.c(193): LM of order 3
                                          INFO: ngram_model_trie.c(195): #1-grams: 25
                                          INFO: ngram_model_trie.c(195): #2-grams: 46
                                          INFO: ngram_model_trie.c(195): #3-grams: 23
                                          INFO: lm_trie.c(474): Training quantizer
                                          INFO: lm_trie.c(482): Building LM trie
                                          INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                          INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                                          INFO: ngram_search_fwdtree.c(186): Creating search channels
                                          INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                                          INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                                          INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                          INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                                          Error opening audio device plughw:1 for capture: Invalid argument
                                          FATAL: "continuous.c", line 245: Failed to open audio device
                                          -agc			none		none
                                          -allphone
                                          -aw			1		1
                                          -backtrace		no		no
                                          -bestpath		yes		yes
                                          -ceplen			13		13
                                          -cmn			live		batch
                                          -compallsen		no		no
                                          -dictcase		no		no
                                          -dither			no		no
                                          -doublebw		no		no
                                          -ds			1		1
                                          -fdict
                                          -featparams
                                          -frate			100		100
                                          -fsg
                                          -fwdflat		yes		yes
                                          -fwdflatefwid		4		4
                                          -fwdflatsfwin		25		25
                                          -fwdtree		yes		yes
                                          -jsgf
                                          -keyphrase
                                          -kws
                                          -kws_delay		10		10
                                          -latsize		5000		5000
                                          -lda
                                          -ldadim			0		0
                                          -lifter			0		22
                                          -lmctl
                                          -lmname
                                          -logfn
                                          -logspec		no		no
                                          -maxwpf			-1		-1
                                          -mdef
                                          -mean
                                          -mfclogdir
                                          -min_endfr		0		0
                                          -mixw
                                          -mllr
                                          -mmap			yes		yes
                                          -ncep			13		13
                                          -nfft			512		512
                                          -nfilt			40		25
                                          -pl_window		5		5
                                          -rawlogdir
                                          -remove_dc		no		no
                                          -seed			-1		-1
                                          -sendump
                                          -senlogdir
                                          -senmgau
                                          -smoothspec		no		no
                                          -tmat
                                          -topn			4		4
                                          -topn_beam		0		0
                                          -toprule
                                          -unit_area		yes		yes
                                          -var
                                          -varnorm		no		no
                                          -verbose		no		no
                                          -warp_params
                                          Error opening audio device plughw:1,0 for capture: Invalid argument
                                            • 1 / 5
