    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 52.2k Views 2 Watching
      sdetweil @jmartin1009
      @jmartin1009 after downloading the code (with git pull) , you need to do
      npm install
      also, if u have modules other than the default, you must ALSO do
      nom install in each module folder where there is a package.json file present to cleanup the new dependencies
      in the future, i hope my updater script (link to topic below) will be available as part of the package to help solve these kinds of problems…
      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
        jmartin1009 @sdetweil
        @sdetweil Thank you for the quick answer! Doing that as we speak.Do you however also have any knowledge about MMM-Voice? Running into an error there as well, that’s what prompted the update. Thanks!
          @sdetweil i did npm install in the cd magicmirror folder, as well as the other folders with a package.json, but it is still doing and saying the same thing as before, any ideas?
            @jmartin1009
            cd MagicMirror/node_modules
            ls rrule
            does anything show?
            if not (expect it to be not there)
            cd ..
            npm install rrule
            also, edit package.json
            u should see this
            "rrule": "^2.6.2",
              @sdetweil i installed rrule in just the normal folder, or the blank cd. where should i edit the package file? like in which folders?
                @jmartin1009 everything MagicMirror starts in the MagicMirror folder…
                what does that mean?
                it MUST be in MagicMirror to update the runtime files…
                the
                cd .. (you were in node_modules, so back up one level, now in MagicMirror)
                npm install rrule
                was exact, if you followed my instructions
                  @sdetweil i accidentally installed it in the folder previous to MM, but it still worked, but im installing it in the MM folder right now. Thought you meant the first level cd. Should i remove it in the pi folder? If so how because it doesn’t show up
                    @jmartin1009 sure
                    cd ~
                    npm uninstall rrule
                      @sdetweil how do i fix this?
                      pi@raspberrypi:~/MagicMirror $ npm install rrule
                      npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                      + rrule@2.6.2
                      added 2 packages from 2 contributors and audited 2431 packages in 49.239s
                      found 4 vulnerabilities (2 low, 2 high)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      pi@raspberrypi:~/MagicMirror $ npm audit fix
                      up to date in 51.138s
                      fixed 0 of 4 vulnerabilities in 2431 scanned packages
                        2 package updates for 4 vulns involved breaking changes
                        (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
                      Thanks for all your help btw
                        @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
                        it says
                        run npm audit fix to fix them
                        many times you cannot fix them all… so, after one try, ignore it
                          @sdetweil Okay! Do you know anything about MM-voice? having issues with that for some reason and i can’t figure out why.
                            @jmartin1009 yes, what troubles? i have it installed on one of my MagicMirror systems…
                              @sdetweil I have it installed but when i run MM, the little microphone says initializing, then ERROR. I used debug: true, and the file said
                                @jmartin1009 ok. usually this is the device name of the mic…
                                run
                                arecord -l
                                to get the list of mic devices
                                make sure that is in the MMM-Voice config, mine is
                                              microphone: '1,0',
                                  pi@raspberrypi:~ $ arecord -l
                                  **** List of CAPTURE Hardware Devices ****
                                  card 1: Snowball [Blue Snowball], device 0: USB Audio [USB Audio]
                                    Subdevices: 1/1
                                    Subdevice #0: subdevice #0
                                  does this mean it is 1 or 1,0?
                                    @jmartin1009
                                    card 1
                                    device 0
                                    1,0
                                    you can also test the mic with
                                    arecord -D hw:1,0 test.wav
                                    ctrl-break , ctrl-c, or ctrl-z after saying something
                                    then
                                    aplay test.wav
                                    to hear the recorded voice back
                                      @sdetweil should i change it in MM’s config file? or MM-voice’s file:MM-voice.js? and if the second, where?
                                        @jmartin1009 never change anything in the module folder, only the config.js for magic mirror
                                          @sdetweil so it should look like this?
                                          		        module: 'MMM-voice',
                                          		        position: 'upper_third',
                                          		            microphone: '1,0',
                                          		            keyword: 'Magic Mirror',
                                          			    timeout: 15,
                                            @jmartin1009 yes
                                            mine looks like
                                                    position: 'bottom_bar',
                                                          microphone: '1,0',
                                                          keyword:        'MAGIC MIRROR',
                                                          timeout:        15,
                                                          debug: true,
                                                          standByMethod: 'hide',
                                                          startHidden: false
                                            • 1 / 5
