    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 52.2k Views 2 Watching
      jmartin1009 @sdetweil
      @sdetweil i did npm install in the cd magicmirror folder, as well as the other folders with a package.json, but it is still doing and saying the same thing as before, any ideas?
        sdetweil @jmartin1009
        @jmartin1009
        cd MagicMirror/node_modules
        ls rrule
        does anything show?
        if not (expect it to be not there)
        cd ..
        npm install rrule
        also, edit package.json
        u should see this
        "rrule": "^2.6.2",
          @sdetweil i installed rrule in just the normal folder, or the blank cd. where should i edit the package file? like in which folders?
            @jmartin1009 everything MagicMirror starts in the MagicMirror folder…
            what does that mean?
            it MUST be in MagicMirror to update the runtime files…
            the
            cd .. (you were in node_modules, so back up one level, now in MagicMirror)
            npm install rrule
            was exact, if you followed my instructions
              @sdetweil i accidentally installed it in the folder previous to MM, but it still worked, but im installing it in the MM folder right now. Thought you meant the first level cd. Should i remove it in the pi folder? If so how because it doesn’t show up
                @jmartin1009 sure
                cd ~
                npm uninstall rrule
                  @sdetweil how do i fix this?
                  pi@raspberrypi:~/MagicMirror $ npm install rrule
                  npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                  + rrule@2.6.2
                  added 2 packages from 2 contributors and audited 2431 packages in 49.239s
                  found 4 vulnerabilities (2 low, 2 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  pi@raspberrypi:~/MagicMirror $ npm audit fix
                  up to date in 51.138s
                  fixed 0 of 4 vulnerabilities in 2431 scanned packages
                    2 package updates for 4 vulns involved breaking changes
                    (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
                  Thanks for all your help btw
                    @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
                    it says
                    run npm audit fix to fix them
                    many times you cannot fix them all… so, after one try, ignore it
                      @sdetweil Okay! Do you know anything about MM-voice? having issues with that for some reason and i can’t figure out why.
                        @jmartin1009 yes, what troubles? i have it installed on one of my MagicMirror systems…
                          @sdetweil I have it installed but when i run MM, the little microphone says initializing, then ERROR. I used debug: true, and the file said
                            @jmartin1009 ok. usually this is the device name of the mic…
                            run
                            arecord -l
                            to get the list of mic devices
                            make sure that is in the MMM-Voice config, mine is
                                          microphone: '1,0',
                              pi@raspberrypi:~ $ arecord -l
                              **** List of CAPTURE Hardware Devices ****
                              card 1: Snowball [Blue Snowball], device 0: USB Audio [USB Audio]
                                Subdevices: 1/1
                                Subdevice #0: subdevice #0
                              does this mean it is 1 or 1,0?
                                @jmartin1009
                                card 1
                                device 0
                                1,0
                                you can also test the mic with
                                arecord -D hw:1,0 test.wav
                                ctrl-break , ctrl-c, or ctrl-z after saying something
                                then
                                aplay test.wav
                                to hear the recorded voice back
                                  @sdetweil should i change it in MM’s config file? or MM-voice’s file:MM-voice.js? and if the second, where?
                                    @jmartin1009 never change anything in the module folder, only the config.js for magic mirror
                                      @sdetweil so it should look like this?
                                      		        module: 'MMM-voice',
                                      		        position: 'upper_third',
                                      		            microphone: '1,0',
                                      		            keyword: 'Magic Mirror',
                                      			    timeout: 15,
                                        @jmartin1009 yes
                                        mine looks like
                                                position: 'bottom_bar',
                                                      microphone: '1,0',
                                                      keyword:        'MAGIC MIRROR',
                                                      timeout:        15,
                                                      debug: true,
                                                      standByMethod: 'hide',
                                                      startHidden: false
                                          @sdetweil okay ,i will run it and see what happens.
                                            @sdetweil still came up saying error :(
                                            • 1 / 5
