    Problem when installing MagicMirror on Raspbian Buster RPB3+
    26 Posts 4 Posters 12.2k Views 4 Watching
    • T Offline
      thomaslc
      Hey guys,
      I have an error when I try to install magic mirror on raspbian buster (fresh install) and with raspberry pi 3b+.
      https://ibb.co/Y8HVwVG
      Do you have any ideas ?
      Thank you !
      Have a good day !
        not really… try my updated installer.
        see here for instructions
        https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        • buzzkcB Offline
          buzzkc
          Give Sam’s installer a try. If I recall on Buster I had to apt-get uninstall nodejs and npm, then let the MagicMirror installer install the correct versions of those softwares.
          Darren
          My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
          • T Offline
            thomaslc
            Hey, thanks for you answers !
            Sdetweil I tried your installer. When I reboot the Raspberry, magic mirror start but it’s coming back to the rasbian desktop few seconds later. I uploaded what happens on youtube : https://youtu.be/1dbtU3U5StM
            Buzzkc, what do you mean with “Sam’s installer” ? Sdetweil installer ?
              sdetweil @thomaslc
              @thomaslc my name is Sam (i have that as my signature)
              i watched your video… very weird…
              open a terminal window , ctrl-alt-T, and then do
              pm2 status,
              pm2 logs
              u will have to ctrl-c to end that
              pm2 stop 0,
              pm2 start 0
              it LOOKS like pm2 starts WHILE still booting… I haven’t seen that on any of my systems…
              • T Offline
                thomaslc
                It tells me that the command is not found :
                https://ibb.co/FBmcNts
                  sdetweil @thomaslc
                  @thomaslc during the install, it should have asked you if you wanted pm2 to be used to start the mirror app…
                    sdetweil @thomaslc
                    @thomaslc easiest thing to do is rename the MagicMirror folder to MagicMirror.save
                    in linux the rename command is mv
                    then run my installer again
                    see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                    for the url to use
                    • T Offline
                      thomaslc
                      I swear I said yes for the pm2 lol. Oke Im gonna reinstall !
                      • T Offline
                        thomaslc
                        Same problem :(
                        https://ibb.co/DLS9hjm
                          sdetweil @thomaslc
                          @thomaslc are u doing this over vpn or ssh?
                          i use ssh, and then the display on my real machine shows the MagicMirror UI, while the ssh session is still active…
                          • T Offline
                            thomaslc
                            @sdetweil said in Problem when installing MagicMirror on Raspbian Buster RPB3+:
                            Nop without vpn or ssh, last fresh rasbian os and directly connected to my box with rj45 ethernet
                              sdetweil @thomaslc
                              @thomaslc also, the output says pm2 started MM and it is running , before u typed in your command…
                              can u send me the ~/install.log
                              same userid as here on gmail…
                                @sdetweil i am building a buster image for myself now
                                • T Offline
                                  thomaslc @sdetweil
                                  @sdetweil And do you know why the original Magic Mirror link doesnt work ?
                                    sdetweil @thomaslc
                                    @thomaslc said in Problem when installing MagicMirror on Raspbian Buster RPB3+:
                                    cause it is old, doesn’t handle a bunch of things… which is why I am doing the updated version…
                                    once tested I will submit mine to replace the one on the MM site
                                      sdetweil @thomaslc
                                      @thomaslc thanks for the log… found a bug in the installer on buster… testing fix now
                                      • T Offline
                                        thomaslc
                                        Nice ! Keep me in touch !
                                          sdetweil @thomaslc
                                          @thomaslc while I test the installer, u could use the pm2 only script
                                          see instructions here , fix already added
                                          https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                                          installer also tested and restarts on boot… have to delete the MagicMirror folder again if u go this way
                                          • T Offline
                                            thomaslc
                                            It’s not working :(
                                            https://ibb.co/4s4GNC2
                                            I can send you the log if you want :)
