    Problem when installing MagicMirror on Raspbian Buster RPB3+
    26 Posts 4 Posters 11.9k Views 4 Watching
      not really… try my updated installer.
      see here for instructions
      https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
      • buzzkcB Offline
        buzzkc
        Give Sam’s installer a try. If I recall on Buster I had to apt-get uninstall nodejs and npm, then let the MagicMirror installer install the correct versions of those softwares.
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
        • T Offline
          thomaslc
          Hey, thanks for you answers !
          Sdetweil I tried your installer. When I reboot the Raspberry, magic mirror start but it’s coming back to the rasbian desktop few seconds later. I uploaded what happens on youtube : https://youtu.be/1dbtU3U5StM
          Buzzkc, what do you mean with “Sam’s installer” ? Sdetweil installer ?
            sdetweil @thomaslc
            @thomaslc my name is Sam (i have that as my signature)
            i watched your video… very weird…
            open a terminal window , ctrl-alt-T, and then do
            pm2 status,
            pm2 logs
            u will have to ctrl-c to end that
            pm2 stop 0,
            pm2 start 0
            it LOOKS like pm2 starts WHILE still booting… I haven’t seen that on any of my systems…
            • T Offline
              thomaslc
              It tells me that the command is not found :
              https://ibb.co/FBmcNts
                sdetweil @thomaslc
                @thomaslc during the install, it should have asked you if you wanted pm2 to be used to start the mirror app…
                  sdetweil @thomaslc
                  @thomaslc easiest thing to do is rename the MagicMirror folder to MagicMirror.save
                  in linux the rename command is mv
                  then run my installer again
                  see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                  for the url to use
                  • T Offline
                    thomaslc
                    I swear I said yes for the pm2 lol. Oke Im gonna reinstall !
                    • T Offline
                      thomaslc
                      Same problem :(
                      https://ibb.co/DLS9hjm
                        sdetweil @thomaslc
                        @thomaslc are u doing this over vpn or ssh?
                        i use ssh, and then the display on my real machine shows the MagicMirror UI, while the ssh session is still active…
