    328 Posts 27 Posters 740.7k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams can you show me the MagicMirror/installers/upgrade.log
      or send it to me mail, same userid as here on gmail, thanks
        bobwilliams
        Upgrade started - Sun Oct 6 11:26:51 +05 2019
        user requested to apply changes
        doing test run = false
        saving custom.css
        remote name = origin
        upgrading from version 2.8.0 to 2.9.0
        fetching latest revisions
        current branch = master
        there are 7 local files that are different than the master repo
        installers/mm.sh
        modules/default/calendar/calendar.js
        modules/default/currentweather/currentweather.js
        modules/default/weather/weather.js
        modules/default/weatherforecast/weatherforecast.js
        package-lock.json
        run-start.sh
        save/restore files selection = y
        test merge result rc=‘’ if empty, no conflicts
        executing merge, apply specified
        merge result rc= 0n Updating a31546b…500147e
        magicmirror@2.8.0 install /home/pi/MagicMirror
        cd vendor && npm install
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
        audited 220 packages in 53.517s
        found 5 vulnerabilities (4 low, 1 high)
        run npm audit fix to fix them, or npm audit for details
        magicmirror@2.8.0 postinstall /home/pi/MagicMirror
        sh installers/postinstall/postinstall.sh && npm run install-fonts
        ^[[32mMagicMirror installation successful!
        magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
        cd fonts && npm install
        audited 1 package in 3.78s
        found 0 vulnerabilities
        npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
        audited 3573 packages in 310.648s
        found 16 vulnerabilities (1 moderate, 15 high)
        processing for module MMM-WeeklySchedule please wait
        audited 1 package in 3.297s
        processing complete for module MMM-WeeklySchedule
        processing for module MMM-MyPrayerTimes please wait
        audited 3 packages in 4.211s
        processing complete for module MMM-MyPrayerTimes
        restoring custom.css
        we stashed a set of files that appear changed from the latest repo versions. you should review them
            @bobwilliams do a git pull, and show the results…
            looks like git lied on the return code of the merge…
            lets try the output of this
            git merge-tree `git merge-base master HEAD` HEAD master
            thanks
              bobwilliams
              no change … I’m a simple user so don’t judge strictly
                @bobwilliams no judging… my script should help with this
                just gotta understand it…
                the output of those two commands is the same?
                then
                git pull
                  bobwilliams
                  @sdetweil said in new update/upgrade script, ready for testing:
                  git pull
                  pi@raspberrypi:~/MagicMirror $ git merge-tree git merge-base master HEAD HEAD master
                  pi@raspberrypi:~/MagicMirror $ git pull
                  error: Your local changes to the following files would be overwritten by merge:
                  package-lock.json
                  run-start.sh
                  Please commit your changes or stash them before you merge.
                  Aborting
                    @bobwilliams said in new update/upgrade script, ready for testing:
                    there were two little backtics (left of 1 on us keyboard)
                    replace backtic in the next command with that keyboard character
                     git merge-tree backtic git merge-base master HEAD backtic HEAD master
                    git pull results hm… we did a stash, why are those files still listed
                    try some more
                    git stash show
                    git stash
                    git pull
                      bobwilliams
                      pi@raspberrypi:~/MagicMirror $ git merge-tree ~ git merge-base master HEAD ~ HEAD master
                      usage: git merge-tree
                      pi@raspberrypi:~/MagicMirror $ git stash show
                      No stash entries found.
                      *** Please tell me who you are.
                      Run
                      git config --global user.email “you@example.com”
                      git config --global user.name “Your Name”
                      to set your account’s default identity.
                      Omit --global to set the identity only in this repository.
                      fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
                      Cannot save the current index state
                      package-lock.json
                      run-start.sh
                      Aborting
                      S 2 Replies Last reply
                        @bobwilliams great!!.. let me see what I can do about that…
                        also ~ git , that is the tilde character, i need the single quote leaning to the left (backtic), same keyboard key for me, just not with shift
                        B 1 Reply Last reply
                          @bobwilliams lets try this
                          git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                          then
                          git stash show
                            bobwilliams @sdetweil
                            @sdetweil English is not my native language … sorry but I did not quite understand what to do
                              @bobwilliams no problems… no need to apologize… we will work thru it…
                              ps, I can’t speak ANYTHING in your language.
                                bobwilliams
                                pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                                Saved working directory and index state WIP on master: a31546b Merge pull request #1717 from MichMich/develop
                                installers/mm.sh | 2 ±
                                modules/default/calendar/calendar.js | 4 ±
                                modules/default/currentweather/currentweather.js | 2 ±
                                modules/default/weather/weather.js | 2 ±
                                modules/default/weatherforecast/weatherforecast.js | 2 ±
                                package-lock.json | 799 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------------------------------------------------
                                run-start.sh | 4 ±
                                7 files changed, 442 insertions(+), 373 deletions(-)
                                  @bobwilliams cool… then try this
                                  git status
                                  git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                                  git status
                                    bobwilliams
                                    pi@raspberrypi:~/MagicMirror $ git status
                                    On branch master
                                    Your branch is behind ‘origin/master’ by 2715 commits, and can be fast-forwarded.
                                    (use “git pull” to update your local branch)
                                    Untracked files:
                                    (use “git add …” to include in what will be committed)
                                        installers/dumpactivemodules.js
                                        installers/mm_temp.sh
                                        installers/pm2_MagicMirror_new.json
                                        installers/startMagicMirror.sh
                                        installers/stashed_files
                                        xdotool.sh
                                    nothing added to commit but untracked files present (use “git add” to track)
                                    pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                                    On branch master
                                    (use “git add …” to update what will be committed)
                                    (use “git checkout – …” to discard changes in working directory)
                                        modified:   installers/mm.sh
                                        modified:   modules/default/calendar/calendar.js
                                        modified:   modules/default/currentweather/currentweather.js
                                        modified:   modules/default/weather/weather.js
                                        modified:   modules/default/weatherforecast/weatherforecast.js
                                        modified:   package-lock.json
                                        modified:   run-start.sh
                                    Untracked files:
                                        xdotool.sh
                                    no changes added to commit (use “git add” and/or “git commit -a”)
                                    Dropped refs/stash@{0} (83cd0d8b2b4ace83bbebb79d03b3d7456a861583)
                                    On branch master
                                    Untracked files:
                                        xdotool.sh
                                      @bobwilliams fabulous!!
                                      so the ‘problem’ was that there were modified files found…
                                      you asked to save them, but the save command (stash) failed, because it needed some additional info
                                      so the files weren’t merged, and then we reinstalled the currently downloaded version (2.8.0)
                                      I didn’t detect that, i do now
                                      so, when u have time, please retry the upgrade script.
                                       bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                                        bobwilliams
                                        thanks, I’ll try now
                                          bobwilliams
                                          a lot of mistakes and the mirror stopped showing
                                            @bobwilliams can u send me the log ? same userid as here on gmail
                                            • 16
                                            • 17
                                            • 5 / 17
