    328 Posts 27 Posters 724.5k Views 24 Watching
      sdetweil @Mykle1
      @Mykle1 thanks… they(last night and today) actually look good
      i did make one change, the merge results generated one LONE line… i added some formatting to make it readable
        sdetweil @Mykle1
        @Mykle1 well, there is installed modules, and there is active modules…
        i only update the ACTIVE (ie, not disabled: true) modules with package.json files
          Understood. :thumbsup:
            bobwilliams
            for some reason, it updates me to version 2.8.0, although it seems like version 2.9.0 has already been released.
            MagicMirror installation successful!
            magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
            cd fonts && npm install
              sdetweil @bobwilliams
              @bobwilliams can you show me the MagicMirror/installers/upgrade.log
              or send it to me mail, same userid as here on gmail, thanks
                bobwilliams
                Upgrade started - Sun Oct 6 11:26:51 +05 2019
                user requested to apply changes
                doing test run = false
                saving custom.css
                remote name = origin
                upgrading from version 2.8.0 to 2.9.0
                fetching latest revisions
                current branch = master
                there are 7 local files that are different than the master repo
                installers/mm.sh
                modules/default/calendar/calendar.js
                modules/default/currentweather/currentweather.js
                modules/default/weather/weather.js
                modules/default/weatherforecast/weatherforecast.js
                package-lock.json
                run-start.sh
                save/restore files selection = y
                test merge result rc=‘’ if empty, no conflicts
                executing merge, apply specified
                merge result rc= 0n Updating a31546b…500147e
                magicmirror@2.8.0 install /home/pi/MagicMirror
                cd vendor && npm install
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                audited 220 packages in 53.517s
                found 5 vulnerabilities (4 low, 1 high)
                run npm audit fix to fix them, or npm audit for details
                magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                sh installers/postinstall/postinstall.sh && npm run install-fonts
                ^[[32mMagicMirror installation successful!
                audited 1 package in 3.78s
                found 0 vulnerabilities
                npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                audited 3573 packages in 310.648s
                found 16 vulnerabilities (1 moderate, 15 high)
                processing for module MMM-WeeklySchedule please wait
                audited 1 package in 3.297s
                processing complete for module MMM-WeeklySchedule
                processing for module MMM-MyPrayerTimes please wait
                audited 3 packages in 4.211s
                processing complete for module MMM-MyPrayerTimes
                restoring custom.css
                we stashed a set of files that appear changed from the latest repo versions. you should review them
                    @bobwilliams do a git pull, and show the results…
                    looks like git lied on the return code of the merge…
                    lets try the output of this
                    git merge-tree `git merge-base master HEAD` HEAD master
                    thanks
                      bobwilliams
                      no change … I’m a simple user so don’t judge strictly
                        @bobwilliams no judging… my script should help with this
                        just gotta understand it…
                        the output of those two commands is the same?
                        then
                        git pull
                          bobwilliams
                          @sdetweil said in new update/upgrade script, ready for testing:
                          git pull
                          pi@raspberrypi:~/MagicMirror $ git merge-tree git merge-base master HEAD HEAD master
                          pi@raspberrypi:~/MagicMirror $ git pull
                          error: Your local changes to the following files would be overwritten by merge:
                          package-lock.json
                          run-start.sh
                          Please commit your changes or stash them before you merge.
                          Aborting
                            @bobwilliams said in new update/upgrade script, ready for testing:
                            there were two little backtics (left of 1 on us keyboard)
                            replace backtic in the next command with that keyboard character
                             git merge-tree backtic git merge-base master HEAD backtic HEAD master
                            git pull results hm… we did a stash, why are those files still listed
                            try some more
                            git stash show
                            git stash
                            git pull
                              bobwilliams
                              pi@raspberrypi:~/MagicMirror $ git merge-tree ~ git merge-base master HEAD ~ HEAD master
                              usage: git merge-tree
                              pi@raspberrypi:~/MagicMirror $ git stash show
                              No stash entries found.
                              *** Please tell me who you are.
                              Run
                              git config --global user.email “you@example.com”
                              git config --global user.name “Your Name”
                              to set your account’s default identity.
                              Omit --global to set the identity only in this repository.
                              fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
                              Cannot save the current index state
                              package-lock.json
                              run-start.sh
                              Aborting
                                @bobwilliams great!!.. let me see what I can do about that…
                                also ~ git , that is the tilde character, i need the single quote leaning to the left (backtic), same keyboard key for me, just not with shift
                                  @bobwilliams lets try this
                                  git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                                  then
                                  git stash show
                                    bobwilliams @sdetweil
                                    @sdetweil English is not my native language … sorry but I did not quite understand what to do
                                      @bobwilliams no problems… no need to apologize… we will work thru it…
                                      ps, I can’t speak ANYTHING in your language.
                                        bobwilliams
                                        pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                                        Saved working directory and index state WIP on master: a31546b Merge pull request #1717 from MichMich/develop
                                        installers/mm.sh | 2 ±
                                        modules/default/calendar/calendar.js | 4 ±
                                        modules/default/currentweather/currentweather.js | 2 ±
                                        modules/default/weather/weather.js | 2 ±
                                        modules/default/weatherforecast/weatherforecast.js | 2 ±
                                        package-lock.json | 799 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------------------------------------------------
                                        run-start.sh | 4 ±
                                        7 files changed, 442 insertions(+), 373 deletions(-)
                                          @bobwilliams cool… then try this
                                          git status
                                          git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                                          git status
                                            bobwilliams
                                            pi@raspberrypi:~/MagicMirror $ git status
                                            On branch master
                                            Your branch is behind ‘origin/master’ by 2715 commits, and can be fast-forwarded.
                                            (use “git pull” to update your local branch)
                                            Untracked files:
                                            (use “git add …” to include in what will be committed)
                                                installers/dumpactivemodules.js
                                                installers/mm_temp.sh
                                                installers/pm2_MagicMirror_new.json
                                                installers/startMagicMirror.sh
                                                installers/stashed_files
                                                xdotool.sh
                                            nothing added to commit but untracked files present (use “git add” to track)
                                            pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                                            On branch master
                                            (use “git add …” to update what will be committed)
                                            (use “git checkout – …” to discard changes in working directory)
                                                modified:   installers/mm.sh
                                                modified:   modules/default/calendar/calendar.js
                                                modified:   modules/default/currentweather/currentweather.js
                                                modified:   modules/default/weather/weather.js
                                                modified:   modules/default/weatherforecast/weatherforecast.js
                                                modified:   package-lock.json
                                                modified:   run-start.sh
                                            Untracked files:
                                                xdotool.sh
                                            no changes added to commit (use “git add” and/or “git commit -a”)
                                            Dropped refs/stash@{0} (83cd0d8b2b4ace83bbebb79d03b3d7456a861583)
                                            On branch master
                                            Untracked files:
                                                xdotool.sh
                                            • 16
                                            • 17
                                            • 5 / 17
