    328 Posts 27 Posters 740.7k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams no judging… my script should help with this
      just gotta understand it…
      the output of those two commands is the same?
      git merge-tree `git merge-base master HEAD` HEAD master
      then
      git pull
        bobwilliams
        @sdetweil said in new update/upgrade script, ready for testing:
        git pull
        pi@raspberrypi:~/MagicMirror $ git merge-tree git merge-base master HEAD HEAD master
        pi@raspberrypi:~/MagicMirror $ git pull
        Updating a31546b…500147e
        error: Your local changes to the following files would be overwritten by merge:
        modules/default/currentweather/currentweather.js
        modules/default/weather/weather.js
        modules/default/weatherforecast/weatherforecast.js
        package-lock.json
        run-start.sh
        Please commit your changes or stash them before you merge.
        Aborting
          @bobwilliams said in new update/upgrade script, ready for testing:
          there were two little backtics (left of 1 on us keyboard)
          replace backtic in the next command with that keyboard character
           git merge-tree backtic git merge-base master HEAD backtic HEAD master
          git pull results hm… we did a stash, why are those files still listed
          try some more
          git stash show
          git stash
          git pull
            bobwilliams
            pi@raspberrypi:~/MagicMirror $ git merge-tree ~ git merge-base master HEAD ~ HEAD master
            usage: git merge-tree
            pi@raspberrypi:~/MagicMirror $ git stash show
            No stash entries found.
            *** Please tell me who you are.
            Run
            git config --global user.email “you@example.com”
            git config --global user.name “Your Name”
            to set your account’s default identity.
            Omit --global to set the identity only in this repository.
            fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
            Cannot save the current index state
            package-lock.json
            run-start.sh
            Aborting
            S 2 Replies Last reply
              @bobwilliams great!!.. let me see what I can do about that…
              also ~ git , that is the tilde character, i need the single quote leaning to the left (backtic), same keyboard key for me, just not with shift
              B 1 Reply Last reply
                @bobwilliams lets try this
                git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                then
                git stash show
                  bobwilliams @sdetweil
                  @sdetweil English is not my native language … sorry but I did not quite understand what to do
                    @bobwilliams no problems… no need to apologize… we will work thru it…
                    ps, I can’t speak ANYTHING in your language.
                      bobwilliams
                      pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                      Saved working directory and index state WIP on master: a31546b Merge pull request #1717 from MichMich/develop
                      installers/mm.sh | 2 ±
                      modules/default/calendar/calendar.js | 4 ±
                      modules/default/currentweather/currentweather.js | 2 ±
                      modules/default/weather/weather.js | 2 ±
                      modules/default/weatherforecast/weatherforecast.js | 2 ±
                      package-lock.json | 799 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------------------------------------------------
                      run-start.sh | 4 ±
                      7 files changed, 442 insertions(+), 373 deletions(-)
                        @bobwilliams cool… then try this
                        git status
                        git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                        git status
                          bobwilliams
                          pi@raspberrypi:~/MagicMirror $ git status
                          On branch master
                          Your branch is behind ‘origin/master’ by 2715 commits, and can be fast-forwarded.
                          (use “git pull” to update your local branch)
                          Untracked files:
                          (use “git add …” to include in what will be committed)
                              installers/dumpactivemodules.js
                              installers/mm_temp.sh
                              installers/pm2_MagicMirror_new.json
                              installers/startMagicMirror.sh
                              installers/stashed_files
                              xdotool.sh
                          nothing added to commit but untracked files present (use “git add” to track)
                          pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                          On branch master
                          (use “git add …” to update what will be committed)
                          (use “git checkout – …” to discard changes in working directory)
                              modified:   installers/mm.sh
                              modified:   modules/default/calendar/calendar.js
                              modified:   modules/default/currentweather/currentweather.js
                              modified:   modules/default/weather/weather.js
                              modified:   modules/default/weatherforecast/weatherforecast.js
                              modified:   package-lock.json
                              modified:   run-start.sh
                          Untracked files:
                              xdotool.sh
                          no changes added to commit (use “git add” and/or “git commit -a”)
                          Dropped refs/stash@{0} (83cd0d8b2b4ace83bbebb79d03b3d7456a861583)
                          On branch master
                          Untracked files:
                              xdotool.sh
                            @bobwilliams fabulous!!
                            so the ‘problem’ was that there were modified files found…
                            you asked to save them, but the save command (stash) failed, because it needed some additional info
                            so the files weren’t merged, and then we reinstalled the currently downloaded version (2.8.0)
                            I didn’t detect that, i do now
                            so, when u have time, please retry the upgrade script.
                             bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                              bobwilliams
                              thanks, I’ll try now
                                bobwilliams
                                a lot of mistakes and the mirror stopped showing
                                  @bobwilliams can u send me the log ? same userid as here on gmail
                                    bobwilliams
                                    where to send? here does not let me write writes that spam
                                      @bobwilliams my userid (sdetweil) at gmail (.com)
                                        @sdetweil sort of sent))))
                                          @bobwilliams got it… looking…
                                            @sdetweil can u show me the output of
                                            uname -m
                                            thanks
                                            this appears to be a pi 0, correct?
                                            • 16
                                            • 17
                                            • 5 / 17
