    328 Posts 27 Posters 740.6k Views 24 Watching
      @bobwilliams do a git pull, and show the results…
      looks like git lied on the return code of the merge…
      merge result rc= 0n Updating a31546b…500147e
      lets try the output of this
      git merge-tree `git merge-base master HEAD` HEAD master
      thanks
        bobwilliams
        no change … I’m a simple user so don’t judge strictly
          sdetweil @bobwilliams
          @bobwilliams no judging… my script should help with this
          just gotta understand it…
          the output of those two commands is the same?
          then
          git pull
            bobwilliams
            @sdetweil said in new update/upgrade script, ready for testing:
            git pull
            pi@raspberrypi:~/MagicMirror $ git merge-tree git merge-base master HEAD HEAD master
            pi@raspberrypi:~/MagicMirror $ git pull
            error: Your local changes to the following files would be overwritten by merge:
            modules/default/currentweather/currentweather.js
            modules/default/weather/weather.js
            modules/default/weatherforecast/weatherforecast.js
            package-lock.json
            run-start.sh
            Please commit your changes or stash them before you merge.
            Aborting
              @bobwilliams said in new update/upgrade script, ready for testing:
              there were two little backtics (left of 1 on us keyboard)
              replace backtic in the next command with that keyboard character
               git merge-tree backtic git merge-base master HEAD backtic HEAD master
              git pull results hm… we did a stash, why are those files still listed
              try some more
              git stash show
              git stash
              git pull
                bobwilliams
                pi@raspberrypi:~/MagicMirror $ git merge-tree ~ git merge-base master HEAD ~ HEAD master
                usage: git merge-tree
                pi@raspberrypi:~/MagicMirror $ git stash show
                No stash entries found.
                *** Please tell me who you are.
                Run
                git config --global user.email “you@example.com”
                git config --global user.name “Your Name”
                to set your account’s default identity.
                Omit --global to set the identity only in this repository.
                fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
                Cannot save the current index state
                package-lock.json
                run-start.sh
                Aborting
                S 2 Replies Last reply
                  @bobwilliams great!!.. let me see what I can do about that…
                  also ~ git , that is the tilde character, i need the single quote leaning to the left (backtic), same keyboard key for me, just not with shift
                  B 1 Reply Last reply
                    @bobwilliams lets try this
                    git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                    then
                    git stash show
                      bobwilliams @sdetweil
                      @sdetweil English is not my native language … sorry but I did not quite understand what to do
                        @bobwilliams no problems… no need to apologize… we will work thru it…
                        ps, I can’t speak ANYTHING in your language.
                          bobwilliams
                          pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                          Saved working directory and index state WIP on master: a31546b Merge pull request #1717 from MichMich/develop
                          installers/mm.sh | 2 ±
                          modules/default/calendar/calendar.js | 4 ±
                          modules/default/currentweather/currentweather.js | 2 ±
                          modules/default/weather/weather.js | 2 ±
                          modules/default/weatherforecast/weatherforecast.js | 2 ±
                          package-lock.json | 799 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------------------------------------------------
                          run-start.sh | 4 ±
                          7 files changed, 442 insertions(+), 373 deletions(-)
                            @bobwilliams cool… then try this
                            git status
                            git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                            git status
                              bobwilliams
                              pi@raspberrypi:~/MagicMirror $ git status
                              On branch master
                              Your branch is behind ‘origin/master’ by 2715 commits, and can be fast-forwarded.
                              (use “git pull” to update your local branch)
                              Untracked files:
                              (use “git add …” to include in what will be committed)
                                  installers/dumpactivemodules.js
                                  installers/mm_temp.sh
                                  installers/pm2_MagicMirror_new.json
                                  installers/startMagicMirror.sh
                                  installers/stashed_files
                                  xdotool.sh
                              nothing added to commit but untracked files present (use “git add” to track)
                              pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                              On branch master
                              (use “git add …” to update what will be committed)
                              (use “git checkout – …” to discard changes in working directory)
                                  modified:   installers/mm.sh
                                  modified:   modules/default/calendar/calendar.js
                                  modified:   modules/default/currentweather/currentweather.js
                                  modified:   modules/default/weather/weather.js
                                  modified:   modules/default/weatherforecast/weatherforecast.js
                                  modified:   package-lock.json
                                  modified:   run-start.sh
                              Untracked files:
                                  xdotool.sh
                              no changes added to commit (use “git add” and/or “git commit -a”)
                              Dropped refs/stash@{0} (83cd0d8b2b4ace83bbebb79d03b3d7456a861583)
                              On branch master
                              Untracked files:
                                  xdotool.sh
                                @bobwilliams fabulous!!
                                so the ‘problem’ was that there were modified files found…
                                you asked to save them, but the save command (stash) failed, because it needed some additional info
                                so the files weren’t merged, and then we reinstalled the currently downloaded version (2.8.0)
                                I didn’t detect that, i do now
                                so, when u have time, please retry the upgrade script.
                                 bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                                  bobwilliams
                                  thanks, I’ll try now
                                    bobwilliams
                                    a lot of mistakes and the mirror stopped showing
                                      @bobwilliams can u send me the log ? same userid as here on gmail
                                        bobwilliams
                                        where to send? here does not let me write writes that spam
                                          @bobwilliams my userid (sdetweil) at gmail (.com)
                                            @sdetweil sort of sent))))
                                            • 16
                                            • 17
                                            • 5 / 17
