    328 Posts 27 Posters 650.1k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams lets try this
      git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
      then
      git stash show
        bobwilliams @sdetweil
        @sdetweil English is not my native language … sorry but I did not quite understand what to do
          @bobwilliams no problems… no need to apologize… we will work thru it…
          ps, I can’t speak ANYTHING in your language.
            bobwilliams
            pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
            Saved working directory and index state WIP on master: a31546b Merge pull request #1717 from MichMich/develop
            pi@raspberrypi:~/MagicMirror $ git stash show
            installers/mm.sh | 2 ±
            modules/default/calendar/calendar.js | 4 ±
            modules/default/currentweather/currentweather.js | 2 ±
            modules/default/weather/weather.js | 2 ±
            modules/default/weatherforecast/weatherforecast.js | 2 ±
            package-lock.json | 799 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------------------------------------------------
            run-start.sh | 4 ±
            7 files changed, 442 insertions(+), 373 deletions(-)
              @bobwilliams cool… then try this
              git status
              git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
              git status
                bobwilliams
                pi@raspberrypi:~/MagicMirror $ git status
                On branch master
                Your branch is behind ‘origin/master’ by 2715 commits, and can be fast-forwarded.
                (use “git pull” to update your local branch)
                Untracked files:
                (use “git add …” to include in what will be committed)
                    installers/dumpactivemodules.js
                    installers/mm_temp.sh
                    installers/pm2_MagicMirror_new.json
                    installers/startMagicMirror.sh
                    installers/stashed_files
                    xdotool.sh
                nothing added to commit but untracked files present (use “git add” to track)
                pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                On branch master
                (use “git add …” to update what will be committed)
                (use “git checkout – …” to discard changes in working directory)
                    modified:   installers/mm.sh
                    modified:   modules/default/calendar/calendar.js
                    modified:   modules/default/currentweather/currentweather.js
                    modified:   modules/default/weather/weather.js
                    modified:   modules/default/weatherforecast/weatherforecast.js
                    modified:   package-lock.json
                    modified:   run-start.sh
                Untracked files:
                    xdotool.sh
                no changes added to commit (use “git add” and/or “git commit -a”)
                Dropped refs/stash@{0} (83cd0d8b2b4ace83bbebb79d03b3d7456a861583)
                On branch master
                Untracked files:
                    xdotool.sh
                  @bobwilliams fabulous!!
                  so the ‘problem’ was that there were modified files found…
                  you asked to save them, but the save command (stash) failed, because it needed some additional info
                  so the files weren’t merged, and then we reinstalled the currently downloaded version (2.8.0)
                  I didn’t detect that, i do now
                  so, when u have time, please retry the upgrade script.
                   bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                    bobwilliams
                    thanks, I’ll try now
                      bobwilliams
                      a lot of mistakes and the mirror stopped showing
                        @bobwilliams can u send me the log ? same userid as here on gmail
                        • 10
                        • 11
                        • 32
                        • 33
                        • 9 / 33
