    328 Posts 27 Posters 726.7k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams said in new update/upgrade script, ready for testing:
      git merge-tree git merge-base master HEAD HEAD master
      there were two little backtics (left of 1 on us keyboard)
      replace backtic in the next command with that keyboard character
       git merge-tree backtic git merge-base master HEAD backtic HEAD master
      git pull results hm… we did a stash, why are those files still listed
      try some more
      git stash show
      git stash
      git pull
        bobwilliams
        pi@raspberrypi:~/MagicMirror $ git merge-tree ~ git merge-base master HEAD ~ HEAD master
        usage: git merge-tree
        pi@raspberrypi:~/MagicMirror $ git stash show
        No stash entries found.
        *** Please tell me who you are.
        Run
        git config --global user.email “you@example.com”
        git config --global user.name “Your Name”
        to set your account’s default identity.
        Omit --global to set the identity only in this repository.
        fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
        Cannot save the current index state
        pi@raspberrypi:~/MagicMirror $ git pull
        Updating a31546b…500147e
        error: Your local changes to the following files would be overwritten by merge:
        modules/default/currentweather/currentweather.js
        modules/default/weather/weather.js
        modules/default/weatherforecast/weatherforecast.js
        package-lock.json
        run-start.sh
        Please commit your changes or stash them before you merge.
        Aborting
          @bobwilliams great!!.. let me see what I can do about that…
          also ~ git , that is the tilde character, i need the single quote leaning to the left (backtic), same keyboard key for me, just not with shift
            @bobwilliams lets try this
            git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
            then
            git stash show
              bobwilliams @sdetweil
              @sdetweil English is not my native language … sorry but I did not quite understand what to do
                @bobwilliams no problems… no need to apologize… we will work thru it…
                ps, I can’t speak ANYTHING in your language.
                  bobwilliams
                  pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash
                  Saved working directory and index state WIP on master: a31546b Merge pull request #1717 from MichMich/develop
                  installers/mm.sh | 2 ±
                  modules/default/calendar/calendar.js | 4 ±
                  modules/default/currentweather/currentweather.js | 2 ±
                  modules/default/weather/weather.js | 2 ±
                  modules/default/weatherforecast/weatherforecast.js | 2 ±
                  package-lock.json | 799 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------------------------------------------------
                  run-start.sh | 4 ±
                  7 files changed, 442 insertions(+), 373 deletions(-)
                    @bobwilliams cool… then try this
                    git status
                    git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                    git status
                      bobwilliams
                      pi@raspberrypi:~/MagicMirror $ git status
                      On branch master
                      Your branch is behind ‘origin/master’ by 2715 commits, and can be fast-forwarded.
                      (use “git pull” to update your local branch)
                      Untracked files:
                      (use “git add …” to include in what will be committed)
                          installers/dumpactivemodules.js
                          installers/mm_temp.sh
                          installers/pm2_MagicMirror_new.json
                          installers/startMagicMirror.sh
                          installers/stashed_files
                          xdotool.sh
                      nothing added to commit but untracked files present (use “git add” to track)
                      pi@raspberrypi:~/MagicMirror $ git -c user.name=upgrade_script -c user.email=script@upgrade.com stash pop
                      On branch master
                      (use “git add …” to update what will be committed)
                      (use “git checkout – …” to discard changes in working directory)
                          modified:   installers/mm.sh
                          modified:   modules/default/calendar/calendar.js
                          modified:   modules/default/currentweather/currentweather.js
                          modified:   modules/default/weather/weather.js
                          modified:   modules/default/weatherforecast/weatherforecast.js
                          modified:   package-lock.json
                          modified:   run-start.sh
                      Untracked files:
                          xdotool.sh
                      no changes added to commit (use “git add” and/or “git commit -a”)
                      Dropped refs/stash@{0} (83cd0d8b2b4ace83bbebb79d03b3d7456a861583)
                      On branch master
                      Untracked files:
                          xdotool.sh
                        @bobwilliams fabulous!!
                        so the ‘problem’ was that there were modified files found…
                        you asked to save them, but the save command (stash) failed, because it needed some additional info
                        so the files weren’t merged, and then we reinstalled the currently downloaded version (2.8.0)
                        I didn’t detect that, i do now
                        so, when u have time, please retry the upgrade script.
                         bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                          bobwilliams
                          thanks, I’ll try now
                            bobwilliams
                            a lot of mistakes and the mirror stopped showing
                              @bobwilliams can u send me the log ? same userid as here on gmail
                                bobwilliams
                                where to send? here does not let me write writes that spam
                                  @bobwilliams my userid (sdetweil) at gmail (.com)
                                    @sdetweil sort of sent))))
                                      @bobwilliams got it… looking…
                                        @sdetweil can u show me the output of
                                        uname -m
                                        thanks
                                        this appears to be a pi 0, correct?
                                          bobwilliams
                                          yes PI zero WH
                                          pi@raspberrypi:~ $ uname -m
                                          armv6l
                                            @bobwilliams
                                            ok, lets try this
                                            npm install --arch=armv71 electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                                            • 16
                                            • 17
                                            • 5 / 17
