    328 Posts 27 Posters 740.6k Views 24 Watching
      bobwilliams
      where to send? here does not let me write writes that spam
        sdetweil @bobwilliams
        @bobwilliams my userid (sdetweil) at gmail (.com)
          bobwilliams @sdetweil
          @sdetweil sort of sent))))
            @bobwilliams got it… looking…
              @sdetweil can u show me the output of
              uname -m
              thanks
              this appears to be a pi 0, correct?
                bobwilliams
                yes PI zero WH
                pi@raspberrypi:~ $ uname -m
                armv6l
                  @bobwilliams
                  ok, lets try this
                  npm install --arch=armv71 electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                    bobwilliams
                    ok it started … in my opinion this is a long process
                      @bobwilliams yes, but only 5 minutes
                        bobwilliams
                        but no, it seems to have accelerated … at first he thought for a long time for some reason
                          bobwilliams
                          sent by mail
                          mistakes again
                            @bobwilliams yes, I see… working
                              @sdetweil weird…
                              ok, my fault… number 1 and l (lowercase letter L ) looks close to the same
                              lets try again
                              npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                              notice the 7l the char after 7 is taller than the number
                              and with number 71 it is not taller
                                bobwilliams
                                Yes, I also did not pay attention
                                  @bobwilliams you shouldn’t have to!.. there is arm6 L and B (lowercase) and arm7 L and B (lowercase)
                                  there is no arm 7 1… and the darned download website agrees!!
                                  but my upgrade script used number, instead of letter… (and there is no electron 3.013 for arm6 L), but there IS for arm7 L
                                  and my 1st instructions to you used number instead of letter…
                                    bobwilliams
                                    pi@raspberrypi:~/MagicMirror $ npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                                    electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                                    node install.js
                                    Downloading tmp-13770-1-SHASUMS256.txt-3.0.13
                                    [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                                    npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                    npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                                    • electron@3.0.13
                                      added 5 packages from 6 contributors and audited 3475 packages in 652.83s
                                      found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                                      run npm audit fix to fix them, or npm audit for details
                                      @bobwilliams woohoo!!!..
                                      now try to start mirror
                                        bobwilliams
                                        this site can’t be reached
                                        localhost refused to connect
                                          @bobwilliams can I see your start script?
                                            bobwilliams
                                            Yes, where do I need to look for him? ))))
                                            • 16
                                            • 17
                                            • 6 / 17
