    328 Posts 27 Posters 716.6k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams
      ok, lets try this
      npm install --arch=armv71 electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
        bobwilliams
        ok it started … in my opinion this is a long process
          @bobwilliams yes, but only 5 minutes
            bobwilliams
            but no, it seems to have accelerated … at first he thought for a long time for some reason
              bobwilliams
              sent by mail
              mistakes again
                @bobwilliams yes, I see… working
                  @sdetweil weird…
                  ok, my fault… number 1 and l (lowercase letter L ) looks close to the same
                  lets try again
                  npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                  notice the 7l the char after 7 is taller than the number
                  and with number 71 it is not taller
                    bobwilliams
                    Yes, I also did not pay attention
                      @bobwilliams you shouldn’t have to!.. there is arm6 L and B (lowercase) and arm7 L and B (lowercase)
                      there is no arm 7 1… and the darned download website agrees!!
                      but my upgrade script used number, instead of letter… (and there is no electron 3.013 for arm6 L), but there IS for arm7 L
                      and my 1st instructions to you used number instead of letter…
                        bobwilliams
                        pi@raspberrypi:~/MagicMirror $ npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                        electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                        node install.js
                        Downloading tmp-13770-1-SHASUMS256.txt-3.0.13
                        [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                        npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                        • electron@3.0.13
                          added 5 packages from 6 contributors and audited 3475 packages in 652.83s
                          found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                          run npm audit fix to fix them, or npm audit for details
                          @bobwilliams woohoo!!!..
                          now try to start mirror
                            bobwilliams
                            this site can’t be reached
                            localhost refused to connect
                              @bobwilliams can I see your start script?
                                bobwilliams
                                Yes, where do I need to look for him? ))))
                                  @bobwilliams how do you start mirror? pm2, or something else
                                  if pm2, pm2 show 0, and there is a script path,
                                  mine is /home/odroid/MagicMirror/installers/mm.sh
                                    @sdetweil and if it is pm2, then show pm2 logs --lines=100
                                    (will have to ctrl-c to get out)
                                      bobwilliams
                                      in mm.sh file
                                      cd ~ / MagicMirror
                                      DISPLAY =: 0 npm start
                                      pi@raspberrypi:~ $ pm2 logs mm
                                      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                      did not quite understand how this is done
                                        @bobwilliams ok… do
                                        pm2 stop 0
                                        then
                                        npm start
                                        you should get a bunch of messages
                                          bobwilliams
                                          magicmirror@2.9.0 start /home/pi/MagicMirror
                                          sh run-start.sh
                                            @bobwilliams ok, lets do the upgrade again , now that I fixed the parm…
                                            bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                                            need force as u have 2.9.0 already, and we are gonna do it again
                                            • 16
                                            • 17
                                            • 6 / 17
