    328 Posts 27 Posters 740.6k Views 24 Watching
      @sdetweil weird…
      ok, my fault… number 1 and l (lowercase letter L ) looks close to the same
      lets try again
      npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
      notice the 7l the char after 7 is taller than the number
      and with number 71 it is not taller
        bobwilliams
        Yes, I also did not pay attention
          sdetweil @bobwilliams
          @bobwilliams you shouldn’t have to!.. there is arm6 L and B (lowercase) and arm7 L and B (lowercase)
          there is no arm 7 1… and the darned download website agrees!!
          but my upgrade script used number, instead of letter… (and there is no electron 3.013 for arm6 L), but there IS for arm7 L
          and my 1st instructions to you used number instead of letter…
            bobwilliams
            pi@raspberrypi:~/MagicMirror $ npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
            electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
            node install.js
            Downloading tmp-13770-1-SHASUMS256.txt-3.0.13
            [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
            npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
            • electron@3.0.13
              added 5 packages from 6 contributors and audited 3475 packages in 652.83s
              found 28 vulnerabilities (1 low, 1 moderate, 26 high)
              run npm audit fix to fix them, or npm audit for details
              @bobwilliams woohoo!!!..
              now try to start mirror
                bobwilliams
                this site can’t be reached
                localhost refused to connect
                  @bobwilliams can I see your start script?
                    bobwilliams
                    Yes, where do I need to look for him? ))))
                      @bobwilliams how do you start mirror? pm2, or something else
                      if pm2, pm2 show 0, and there is a script path,
                      mine is /home/odroid/MagicMirror/installers/mm.sh
                        @sdetweil and if it is pm2, then show pm2 logs --lines=100
                        (will have to ctrl-c to get out)
                          bobwilliams
                          in mm.sh file
                          cd ~ / MagicMirror
                          DISPLAY =: 0 npm start
                          pi@raspberrypi:~ $ pm2 logs mm
                          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                          did not quite understand how this is done
                            @bobwilliams ok… do
                            pm2 stop 0
                            then
                            npm start
                            you should get a bunch of messages
                              bobwilliams
                              magicmirror@2.9.0 start /home/pi/MagicMirror
                              sh run-start.sh
                                @bobwilliams ok, lets do the upgrade again , now that I fixed the parm…
                                bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                                need force as u have 2.9.0 already, and we are gonna do it again
                                  bobwilliams
                                  writes update wait … wait 10 minutes
                                  should it be long?
                                    @bobwilliams no longer than before i don’t think
                                      @sdetweil do
                                      tail ~/MagicMirror/installers/upgrade.log -n 30
                                        bobwilliams
                                        it seems like the mirror is running but does not show in the browser
                                          @bobwilliams we were waiting for the upgrade to finish… it does not START the mirror
                                            bobwilliams
                                            What do we do?
                                            • 16
                                            • 17
                                            • 6 / 17
