    328 Posts 27 Posters 706.3k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams yes, I see… working
        @sdetweil weird…
        ok, my fault… number 1 and l (lowercase letter L ) looks close to the same
        lets try again
        npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
        notice the 7l the char after 7 is taller than the number
        and with number 71 it is not taller
          bobwilliams
          Yes, I also did not pay attention
            @bobwilliams you shouldn’t have to!.. there is arm6 L and B (lowercase) and arm7 L and B (lowercase)
            there is no arm 7 1… and the darned download website agrees!!
            but my upgrade script used number, instead of letter… (and there is no electron 3.013 for arm6 L), but there IS for arm7 L
            and my 1st instructions to you used number instead of letter…
              bobwilliams
              pi@raspberrypi:~/MagicMirror $ npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
              electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
              node install.js
              Downloading tmp-13770-1-SHASUMS256.txt-3.0.13
              [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
              npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
              • electron@3.0.13
                added 5 packages from 6 contributors and audited 3475 packages in 652.83s
                found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                run npm audit fix to fix them, or npm audit for details
                @bobwilliams woohoo!!!..
                now try to start mirror
                  bobwilliams
                  this site can’t be reached
                  localhost refused to connect
                    @bobwilliams can I see your start script?
                      bobwilliams
                      Yes, where do I need to look for him? ))))
                        @bobwilliams how do you start mirror? pm2, or something else
                        if pm2, pm2 show 0, and there is a script path,
                        mine is /home/odroid/MagicMirror/installers/mm.sh
                          @sdetweil and if it is pm2, then show pm2 logs --lines=100
                          (will have to ctrl-c to get out)
                            bobwilliams
                            in mm.sh file
                            cd ~ / MagicMirror
                            DISPLAY =: 0 npm start
                            pi@raspberrypi:~ $ pm2 logs mm
                            [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                            did not quite understand how this is done
                              @bobwilliams ok… do
                              pm2 stop 0
                              then
                              npm start
                              you should get a bunch of messages
                                bobwilliams
                                magicmirror@2.9.0 start /home/pi/MagicMirror
                                sh run-start.sh
                                  @bobwilliams ok, lets do the upgrade again , now that I fixed the parm…
                                  bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                                  need force as u have 2.9.0 already, and we are gonna do it again
                                    bobwilliams
                                    writes update wait … wait 10 minutes
                                    should it be long?
                                      @bobwilliams no longer than before i don’t think
                                        @sdetweil do
                                        tail ~/MagicMirror/installers/upgrade.log -n 30
                                          bobwilliams
                                          it seems like the mirror is running but does not show in the browser
                                            @bobwilliams we were waiting for the upgrade to finish… it does not START the mirror
                                            • 16
                                            • 17
                                            • 6 / 17
