    328 Posts 27 Posters 740.6k Views 24 Watching
      bobwilliams
      Yes, I also did not pay attention
        sdetweil @bobwilliams
        @bobwilliams you shouldn’t have to!.. there is arm6 L and B (lowercase) and arm7 L and B (lowercase)
        there is no arm 7 1… and the darned download website agrees!!
        but my upgrade script used number, instead of letter… (and there is no electron 3.013 for arm6 L), but there IS for arm7 L
        and my 1st instructions to you used number instead of letter…
          bobwilliams
          pi@raspberrypi:~/MagicMirror $ npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
          electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
          node install.js
          Downloading tmp-13770-1-SHASUMS256.txt-3.0.13
          [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
          npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
          • electron@3.0.13
            added 5 packages from 6 contributors and audited 3475 packages in 652.83s
            found 28 vulnerabilities (1 low, 1 moderate, 26 high)
            run npm audit fix to fix them, or npm audit for details
            @bobwilliams woohoo!!!..
            now try to start mirror
              bobwilliams
              this site can’t be reached
              localhost refused to connect
                @bobwilliams can I see your start script?
                  bobwilliams
                  Yes, where do I need to look for him? ))))
                    @bobwilliams how do you start mirror? pm2, or something else
                    if pm2, pm2 show 0, and there is a script path,
                    mine is /home/odroid/MagicMirror/installers/mm.sh
                      @sdetweil and if it is pm2, then show pm2 logs --lines=100
                      (will have to ctrl-c to get out)
                        bobwilliams
                        in mm.sh file
                        cd ~ / MagicMirror
                        DISPLAY =: 0 npm start
                        pi@raspberrypi:~ $ pm2 logs mm
                        [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                        did not quite understand how this is done
                          @bobwilliams ok… do
                          pm2 stop 0
                          then
                          npm start
                          you should get a bunch of messages
                            bobwilliams
                            magicmirror@2.9.0 start /home/pi/MagicMirror
                            sh run-start.sh
                              @bobwilliams ok, lets do the upgrade again , now that I fixed the parm…
                              bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                              need force as u have 2.9.0 already, and we are gonna do it again
                                bobwilliams
                                writes update wait … wait 10 minutes
                                should it be long?
                                  @bobwilliams no longer than before i don’t think
                                    @sdetweil do
                                    tail ~/MagicMirror/installers/upgrade.log -n 30
                                      bobwilliams
                                      it seems like the mirror is running but does not show in the browser
                                        @bobwilliams we were waiting for the upgrade to finish… it does not START the mirror
                                          bobwilliams
                                          What do we do?
                                            @bobwilliams lets reboot pi
                                            sudo shutdown now -r
                                            • 16
                                            • 17
                                            • 6 / 17
