    328 Posts 27 Posters 740.6k Views 24 Watching
      bobwilliams
      in mm.sh file
      cd ~ / MagicMirror
      DISPLAY =: 0 npm start
      pi@raspberrypi:~ $ pm2 logs mm
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      did not quite understand how this is done
        sdetweil @bobwilliams
        @bobwilliams ok… do
        pm2 stop 0
        then
        npm start
        you should get a bunch of messages
          bobwilliams
          magicmirror@2.9.0 start /home/pi/MagicMirror
          sh run-start.sh
            @bobwilliams ok, lets do the upgrade again , now that I fixed the parm…
            bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
            need force as u have 2.9.0 already, and we are gonna do it again
              bobwilliams
              writes update wait … wait 10 minutes
              should it be long?
                @bobwilliams no longer than before i don’t think
                  @sdetweil do
                  tail ~/MagicMirror/installers/upgrade.log -n 30
                    bobwilliams
                    it seems like the mirror is running but does not show in the browser
                      @bobwilliams we were waiting for the upgrade to finish… it does not START the mirror
                        bobwilliams
                        What do we do?
                          @bobwilliams lets reboot pi
                          sudo shutdown now -r
                            bobwilliams
                            continue tomorrow … it’s too late … it’s time to sleep))))
                            S 2 Replies Last reply
                              @bobwilliams ok…
                                @bobwilliams and one thing to try, is to reinstall again…
                                mv MagicMirror MagicMirror.save
                                then use my updated installer
                                bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                so we can see if the install works, and then work on the update again..
                                B 1 Reply Last reply
                                  bobwilliams
                                  Well, let’s start reinstalling
                                    bobwilliams @sdetweil
                                    Installation was successful, but the mirror did not start
                                      @bobwilliams can you show me the pm2 logs
                                        bobwilliams
                                        no longer, I removed raspbian, and put it all over again …
                                          bobwilliams
                                          I think the problem was not in your script, but in my system
                                            bobwilliams
                                            I will reinstall now and let you know
                                            • 16
                                            • 17
                                            • 7 / 17
