    328 Posts 27 Posters 727.0k Views 24 Watching
      sdetweil @bobwilliams
      @bobwilliams can I see your start script?
        bobwilliams
        Yes, where do I need to look for him? ))))
          @bobwilliams how do you start mirror? pm2, or something else
          if pm2, pm2 show 0, and there is a script path,
          mine is /home/odroid/MagicMirror/installers/mm.sh
            @sdetweil and if it is pm2, then show pm2 logs --lines=100
            (will have to ctrl-c to get out)
              bobwilliams
              in mm.sh file
              cd ~ / MagicMirror
              DISPLAY =: 0 npm start
              pi@raspberrypi:~ $ pm2 logs mm
              [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
              did not quite understand how this is done
                @bobwilliams ok… do
                pm2 stop 0
                then
                npm start
                you should get a bunch of messages
                  bobwilliams
                  magicmirror@2.9.0 start /home/pi/MagicMirror
                  sh run-start.sh
                    @bobwilliams ok, lets do the upgrade again , now that I fixed the parm…
                    bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                    need force as u have 2.9.0 already, and we are gonna do it again
                      bobwilliams
                      writes update wait … wait 10 minutes
                      should it be long?
                        @bobwilliams no longer than before i don’t think
                          @sdetweil do
                          tail ~/MagicMirror/installers/upgrade.log -n 30
                            bobwilliams
                            it seems like the mirror is running but does not show in the browser
                              @bobwilliams we were waiting for the upgrade to finish… it does not START the mirror
                                bobwilliams
                                What do we do?
                                  @bobwilliams lets reboot pi
                                  sudo shutdown now -r
                                    bobwilliams
                                    continue tomorrow … it’s too late … it’s time to sleep))))
                                      @bobwilliams ok…
                                        @bobwilliams and one thing to try, is to reinstall again…
                                        mv MagicMirror MagicMirror.save
                                        then use my updated installer
                                        bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                        so we can see if the install works, and then work on the update again..
                                          bobwilliams
                                          Well, let’s start reinstalling
                                            bobwilliams @sdetweil
                                            Installation was successful, but the mirror did not start
                                            • 16
                                            • 17
                                            • 7 / 17
