    Clean installation of MM 2.9.0 on an Orange Pi PC sbc, armbian buster
    24 Posts 3 Posters 15.0k Views 3 Watching
    • qu1queQ Offline
      qu1que Project Sponsor
      Hi!
      I’ve just installed Magic Mirror (v. 2.9.0) on an Orange Pi PC sbc with latest armbian buster. It’s a clean installation with only the default modules, WITHOUT any module added to greater (whoever installs and configures as needed).
      If you wanna try it, here is the image file:
      https://www.dropbox.com/sh/udma3rp5ha8eg28/AACOeQR-gPDSnt2fNHo93LNfa?dl=0
      Hope it helps
        sdetweil @qu1que
        @qu1que what install process did you use?
        the base,
        my updated?
        https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        • qu1queQ Offline
          @sdetweil your process is for raspberry? I’ve just follow these steps on orange pi PC:
          • Donwload buster server image from armbian web
          • Update & Upgrade, configure locales, etc.
          • Install full desktop from armbian-config
          • I’ve followed these steps from MM github:
          • Finally rename ~/MagicMirror/config/config.js.sample to config.js
          That’s all.
            sdetweil @qu1que
            @qu1que ok, even more manual…
            my script does all that plus pm2. and screen saver turn off…
            any os… mac, ubuntu, pi stretch, buster, pi0 thru pi 4, odroid, jetson nano, sure others…
            qu1queQ 1 Reply Last reply Reply Quote 1
            • qu1queQ Offline
              qu1que Project Sponsor @sdetweil
              Oh! I’ve forgot to turn off screen saver…:anguished_face:
              Maybe tomorrow I can try your script and tell if it works too on this board.
                sdetweil @qu1que
                @qu1que cool, that would be good feedback
                qu1queQ 1 Reply Last reply Reply Quote 0
                • qu1queQ Offline
                  @sdetweil I’m going to try your installation script on the Orange Pi PC.
                  Do I only have to launch this command?
                  bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)”
                    sdetweil @qu1que
                    @qu1que Yes, that’s it
                    • qu1queQ Offline
                      Well. MM installed Perfect with @sdetweil script on an Orange Pi PC board.
                      Very good Job!
                        sdetweil @qu1que
                        @qu1que Thx. And set the screen saver?
                        • qu1queQ Offline
                          @sdetweil yes, On installation scirpt last step, I’ve disabled screensaver. It’s a good idea to include that option.
                            sdetweil @qu1que
                            @qu1que Mine does what the original does, just fixes and more platforms.
                            Soon as it passes test, I will submit to replace original
                            • qu1queQ Offline
                              @sdetweil I have another sbc called “La Frite” (http://wiki.loverpi.com/sbc:libre-computer-aml-s805x-ac), I could try your script on it too. When I’ve find some free time. I’ll tell you when I can
                                sdetweil @qu1que
                                @qu1que That would be great! Thanks
                                Is that an arm processor?
                                Show me the output of
                                uname -a
                                • qu1queQ Offline
                                  @sdetweil I’m not at home now, but yes, it’s ARM. Take a look at the specifications:
                                  http://wiki.loverpi.com/specs:sbc:libre-aml-s805x-specs-libre-computer-specification
                                  • qu1queQ Offline
                                    Hi! Finally I’ve get working the MM installation on “La Frite” board using your script. The only issue is that I’ve had to download your raspberry.sh script from the dropbox link and copy on home folder of that board, give execution permissions and execute it. Works fine!! (only basic installation, no modules).
                                    Thanks again for your work
                                      sdetweil @qu1que
                                      @qu1que great!, thanks… you had to download cause no network on that board?
                                      • qu1queQ Offline
                                        Not exactly, that board has ethernet connection and so, internet connection. The problem is that when I run the command bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” it shows me an error similar like this (I don’t remember exactly):
                                        #!/bin/bash not found (or something similar)
                                          sdetweil @qu1que
                                          @qu1que ah. Thanks. Bash is optional on your system …hmmmm
                                          • qu1queQ Offline
                                            no no, bash is the default shell used in that system, O.S. is debian for arm64, but maybe the problem is an syntax error, I don’t know, the thing is that using the raspberry.sh script on local works perfect
