    Clean installation of MM 2.9.0 on an Orange Pi PC sbc, armbian buster
    24 Posts 3 Posters 15.4k Views 3 Watching
    • qu1queQ
      qu1que Project Sponsor @sdetweil
      @sdetweil I’m going to try your installation script on the Orange Pi PC.
      Do I only have to launch this command?
      bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)”
        sdetweil @qu1que
        @qu1que Yes, that’s it
        • qu1queQ
          Well. MM installed Perfect with @sdetweil script on an Orange Pi PC board.
          Very good Job!
            sdetweil @qu1que
            @qu1que Thx. And set the screen saver?
            • qu1queQ
              @sdetweil yes, On installation scirpt last step, I’ve disabled screensaver. It’s a good idea to include that option.
                sdetweil @qu1que
                @qu1que Mine does what the original does, just fixes and more platforms.
                Soon as it passes test, I will submit to replace original
                qu1queQ 1 Reply Last reply
                • qu1queQ
                  @sdetweil I have another sbc called “La Frite” (http://wiki.loverpi.com/sbc:libre-computer-aml-s805x-ac), I could try your script on it too. When I’ve find some free time. I’ll tell you when I can
                    sdetweil @qu1que
                    @qu1que That would be great! Thanks
                    Is that an arm processor?
                    Show me the output of
                    uname -a
                    • qu1queQ
                      @sdetweil I’m not at home now, but yes, it’s ARM. Take a look at the specifications:
                      http://wiki.loverpi.com/specs:sbc:libre-aml-s805x-specs-libre-computer-specification
                      • qu1queQ
                        Hi! Finally I’ve get working the MM installation on “La Frite” board using your script. The only issue is that I’ve had to download your raspberry.sh script from the dropbox link and copy on home folder of that board, give execution permissions and execute it. Works fine!! (only basic installation, no modules).
                        Thanks again for your work
                          sdetweil @qu1que
                          @qu1que great!, thanks… you had to download cause no network on that board?
                          • qu1queQ
                            Not exactly, that board has ethernet connection and so, internet connection. The problem is that when I run the command bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” it shows me an error similar like this (I don’t remember exactly):
                            #!/bin/bash not found (or something similar)
                              sdetweil @qu1que
                              @qu1que ah. Thanks. Bash is optional on your system …hmmmm
                              • qu1queQ
                                no no, bash is the default shell used in that system, O.S. is debian for arm64, but maybe the problem is an syntax error, I don’t know, the thing is that using the raspberry.sh script on local works perfect
                                  sdetweil @qu1que
                                  @qu1que oh. Maybe it’s the darned quotes. Sometimes the cut/paste makes them Ms office word doc quotes, which don’t work in Linux bash shell
                                  • qu1queQ
                                    Yes, I supposed something like that.
                                      sk8josh @sdetweil
                                      @sdetweil Help! Trying to use your script on a Orange Pi Zero 2W running Arch Linux (orange Pi version)
                                      When i run the script I get:
                                      install log being saved to /home/joshw/install.log
                                      Updating packages …
                                      sudo: apt-get: command not found
                                      Update failed, retrying installation …
                                      Installing helper tools …
                                      Check current Node installation …
                                      Minimum Node version: v20.18.1
                                      Installed Node version: v22.14.0
                                      No Node.js upgrade necessary.
                                      Check current NPM installation …
                                      Minimum npm version: V10.8.2
                                      Installed npm version: V10.9.2
                                      No npm upgrade necessary.
                                      Cloning MagicMirror …
                                      bash: line 494: git: command not found
                                      Unable to clone MagicMirror.
                                      [joshw@Opi ~]$ ^C
                                      [joshw@Opi ~]$
                                      I cannot figure out how to 'install GIT" I have been at this for hours.
                                      Thanks in advance
                                      Josh.
                                        sdetweil @sk8josh
                                        @sk8josh
                                        my script doesn’t work on arch linux as it depends on apt
                                        also it would only install latest release 2.30.0
                                        google is your friend
