    MMM-NewsFeedTicker, how do I make the marquee go faster
    8 Posts 3 Posters 3.0k Views 3 Watching
    • LordyL
      Lordy
      I would like to make the marquee faster, but do not know how?
      I’ve already tried it with “Animation Speed”.
      Which possibilities are still there?
      Lordy
      (translate by google)
        broberg Project Sponsor
        Try adding this to your custom.css :
        .MMM-NewsFeedTicker .tickerbody {
          -webkit-animation: marquee 2s linear infinite;
          -moz-animation: marquee 2s linear infinite;
          -ms-animation: marquee 2s linear infinite;
          -o-animation: marquee 2s linear infinite;
        • LordyL
          Lordy
          Thanks first. (Erstmal Danke)
          But feel no difference to before. (Aber spüre keinen unterschied zu voher)
          Can you do it even faster? (Kann man es noch schneller machen?)
          B 1 Reply Last reply
            broberg Project Sponsor @Lordy
            @Lordy
            Try this, but after that I don’t know.
            .tickerbody {
              -webkit-animation: marquee 1s linear infinite !important;
              -moz-animation: marquee 1s linear infinite !important;
              -ms-animation: marquee 1s linear infinite !important;
              -o-animation: marquee 1s linear infinite !important;
            Be aware that the Raspberry pi doesn’t do animations very well, so something that works smooth and quick on a normal computer won’t work as well on a pi.
            • LordyL
              Lordy
              Thanks, great job.:winking_face:
              There you can see how “important” is important, the same, did yesterday too.
              • LordyL
                Lordy
                I have now discovered a new problem.
                I want to read the entire line and not the same line twice. *(Ich möchte die gesamte Zeile und nicht zweimal dieselbe Zeile lesen.)
                Where can you extend the display time? (Wo kann man die Anzeigezeit verlängern?)
                  JohnDelta
                  @broberg said in MMM-NewsFeedTicker, how do I make the marquee go faster:
                  MMM-NewsFeedTicker
                  go to the following line in the MMM-NewsFeedTicker.js file and change the number 1000 to a lower number. (some users are finding that changing to 300 works best for them, adjust to your preference)
                  tickerBody.style.animationDuration = Math.round(this.config.updateInterval / 1000) + "s";
                  hope it helps you
                  LordyL 1 Reply Last reply
                  • LordyL
                    Lordy @JohnDelta
                    @JohnDelta
                    Unfortunately no, thanks anyway.
                    My main concern is: “I want to read the entire line and not the same line twice. Where can you extend the display time?”
                    Lordy
