    show info from a webpage
    8 Posts 5 Posters 4.1k Views 5 Watching
      cazz
      I wonder if that is possible to easy show value from a website.
      I have a webserver on the local network that show value when it read the page
      ex
      http://theaddress/show.php?show=1
      it give me “11” and I like to show that on the MM like
      Temp: 11 C
        cazz
        Hmm still trying to add text into MM but no luck.
        It have to be something easy to do that??
          sdetweil @cazz
          @cazz tell me more about what you have done…
          can u display some static text? how u want it to look?
          then we can go about getting the data from your server…
          • evroomE
            evroom
            Probably there are better and possible simpler ways to get it done, but I do something similar using a Perl script and this module:
            https://github.com/eouia/MMM-HTMLBox
            The Perl script reads values and builds a HTML page.
            The module displays it on the Magic Mirror.
            A cron job makes it semi-static as it runs the script regularly.
            MagicMirror version: 2.37.0
              retroflex Project Sponsor Module Developer
              If the returned result is in JSON format, I found two modules for this:
              https://github.com/timdows/MMM-JsonTable
              https://github.com/amcolash/MMM-json-feed
              Also found a module for XML result:
              https://github.com/Eunanibus/MMM-HTTPRequestDisplay
                cazz
                ohh sorry for the all replay.
                I did not got any notice that someone have replay.
                I have forgot about this thread but I going to look at the info you all give me because I have now create a new MMM from the ground.
                That I have done is I have a weather station that create a textfile that I use a PHP file to get the info I need.
                I have setup a dummy to show how it looks
                http://c-media.se/temp/info.php?idnr=1
                http://c-media.se/temp/info.php?idnr=2
                as you can see it is just a plain text that I like to show in MMM
                @evroom
                Hmm yes that is maybe something I can use, going to look into that.
                @retroflex
                well no but I can create so it show in XML or JSON if I have to do that.
                  A Former User
                  @cazz
                  make a test directory in your ~/MagicMirror/modules/.
                  Then copy below codes and save it as test.js
                  Module.register("test", {
                    defaults: {
                      refreshInterval: 5000, // ms, 0 will be deactivation
                      sourceURL: "",
                      appendSeed: (url) => {
                        return url
                      display: (result) => {
                        return result
                      className: ""
                    start: function() {
                      this.url = "https://cors-anywhere.herokuapp.com/" + this.config.sourceURL
                      this.timer = null
                      this.content = null
                    notificationReceived: function(noti, payload, sender) {
                      if (noti == "DOM_OBJECTS_CREATED") {
                        this.refresh()
                    refresh: function() {
                      console.log("refreshed", Date.now())
                      clearTimeout(this.timer)
                      this.timer = null
                      this.readContent()
                      if (this.config.refreshInterval > 0) {
                        this.timer = setTimeout(()=>{
                          this.refresh()
                        }, this.config.refreshInterval)
                    getDom: function() {
                      var wrapper = document.createElement("div")
                      wrapper.className = this.config.className
                      wrapper.innerHTML = this.content
                      return wrapper
                    readContent: function() {
                      var url = this.config.appendSeed(this.url)
                      var xmlHttp = new XMLHttpRequest()
                      xmlHttp.onreadystatechange = () => {
                         if (xmlHttp.readyState == 4 && xmlHttp.status == 200) {
                            console.log("SUCCESS:", this.config.sourceURL, xmlHttp.responseText)
                            this.content = this.config.display(xmlHttp.responseText)
                            setTimeout(()=>{this.updateDom()}, 500)
                      xmlHttp.open("GET", url, true)
                      xmlHttp.send(null)
                  Then config like this;
                        module: "test",
                          refreshInterval: 1000 * 60  // 1000 ms, 0 will be deactivation
                          sourceURL: "http://c-media.se/temp/info.php?idnr=1",
                            return url + "&" + Date.now()
                          className: "firstInstance"
                        module: "test",
                          refreshInterval: 1000 * 30, // ms, 0 will be deactivation
                          sourceURL: "http://c-media.se/temp/info.php?idnr=2",
                            return "TEMP : " + result + " C"
                          className: "secondInstance"
                  It will show like this;
                  PS This sample has an issue about CORS. to avoid, I’m using https://cors-anywhere.herokuapp.com/. But in your real usage, you might need to adjust your server setup for cross-domain issue.
                    cazz
                    Thanks for the replay
                    I have now got it to work with the module (MMM-jsonTable) that @retroflex gave me.
                    I did just create a PHP script that convert my info to JSON so it was easy to insert the info now.
                    @Sean
                    Thanks for the code, it look very nice but I did not got it to work :smiling_face:
                    It was something about the “sourceURL” it did not like but I guess I have done something wrong.
                    Also it was a little easy with the JSON table because I was going to insert alot of info from my weater station.
