    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
    • G
      gekberlin @Guest
      @Sean Hi Sean, any news regarding the module ?
      ? 2 Replies Last reply
        A Former User @gekberlin
        @gekberlin
        Sorry, almost done. But always writing manual is boring work. Only manual remains. I hope I can release this in a few hours. (Maybe… after my lunch. :D)
          @gekberlin
          Released.
          [card:eouia/MMM-CalendarExtMinimonth]
            Doni90
            Hi everybody! I’m setting up Calendar-ext2 but I’m not able to read the location and the description of the event. Is there a specific setting to show it? Thanks!😁
            ? 1 Reply Last reply
              A Former User @Doni90
              @Doni90
              By Default, upcoming and current view shows location and description automatically by default. (In week and monthviews, not allowed - you can modify CSS to reveal even in those views, but not recommended)
              If you want to show location/description on daily, weekly, and monthly views, add this into your css/custom.css
              .CX2 .eventSub {
                display:block;
              D 1 Reply Last reply
                Doni90 @Guest
                @Sean said in MMM-CalendarExt2:
                @Doni90
                .CX2 .eventSub {
                  display:block;
                Thank you! :D
                • G
                  gonzonia
                  Okay. This is all amazing. I was starting to configure MMM-CalendarExt when I found a reference to this. It has some features that I like a lot but I’m having some issues.
                  1. It doesn’t seem to always load the data. Sometimes it works, sometimes it doesn’t. I’ve been trying to narrow this down. I’ve got 6 calendars I’m loading to show my sons homework. I put them in an upcoming and I see some data so I know they are loading (at least 3 of them), but I switch to daily (5 slots) and I get nothing even though some of the data is for the next few days.
                  One second view it loads one calendar fine, but the moment I add a second the data disappears. I
                  Config for upcoming view -
                  mode: “upcoming”,
                  title: “Homework Due Soon”,
                  position: “top_center”,
                  calendars: [“Algebra”, “Latin”, “Transitions”, “Ceramics”,“English”, “Biology”],
                  maxItems: 50,
                  maxDays: 5,
                  for daily view (not working)-
                  mode: “daily”,
                  slotCount:5,
                  hideOverflow: false
                  1. In a daily view when the data is getting cut off because it’s too long for the column width. What do I need to change to remove some of the column spacing or expand the height of each data cell based on the data.
                  2. How do I hide the Week count (41st ,42nd, etc) in a monthly view. 0_1570934373594_Screen Shot 2019-10-12 at 4.35.50 PM.png
                    A Former User
                    @gonzonia
                    1. I think maxItems should be bigger for using many calendars at the same time. Your config says 50 events to be loaded in that view and many of those events were old to be displayed in that view.
                      Smaller values will make performance better but by that value, some events would be dropped. You can use filter to filter UNNECESSARY events, but somewhat difficult, so just giving a bigger value to maxItems would work.
                    2. Width of horizontal MM is not enough wide to display 5 columns :D If you are using 1920x1080 resolution, the width will be 1080(max) or somehow narrower. It means usually each column will take 200px or smaller in 5 columns.
                      Anyway, there could be a few solutions.
                    • remove the outer frame margin/padding of MagicMirror itself.
                    • adjust the column size of MMM-CalendarExt2
                      It is not such an easy because it is hard-coded.
                      https://github.com/eouia/MMM-CalendarExt2/blob/e7535e8fda1fdad1078af158d6e299f730292174/CALEXT2_View.js#L284
                        if (this.config.type == "row") slotDom.style.width = ((100 / count) - 3) + "%"
                    You can modify this. (change 3 to 1 or 0 and save it) But not recommended.
                    • make font smaller
                      redefine --font-size in CSS(in your css/custom.css. referenced by MMM-CalendarExt2.css). Adjusting details might be needed.
                    • Title as multi-lines. (Recommended)
                    .CX2 .period .eventTitle {
                      white-space:normal;
                    • Or you can abbreviate long title to shorter by using transform
                    1. add this into your css/custom.css
                    .CX2 .weeksmark {
                      display:none;
                    • G
                      gonzonia
                      Thanks for the quick reply!
                      I think it’s much closer to where I want it now. It takes some time for the data to load initially, but it seems to be working. Still some visual tweaks to make.
                      I kinda miss the built in styles from CalendarExt. It made it easy to just make each calendar different.
                      • F
                        Fr8Trayne
                        Howdy @Sean something weird is happening. I have this module setup and it’s been working great for a while. It is a scene with two views. The first view is great, but the second view which has the exact same calendars only shows today. The rest of the month is blank. Have you seen this happen before?
                          A Former User @Fr8Trayne
                          @Fr8Trayne
                          show me the configuration.
                          • F
                            Fr8Trayne
                            I’ve removed the actual links to calendars solely for this . Please note that it has been working up until 2 days ago. I love this module just not sure this stopped working. Also note I have a second version of this one a weekly view that still is working just fine.
                            module: “MMM-CalendarExt2”,
                            pages: {second: “fullscreen_above”},
                            defaultset: {
                            view: {
                            slotCount: 5,
                            				scenes: [
                                				name: "Month Calendar",
                            				views: ["family"],
                            				className: "scene_1",
                            				views: [
                                				    mode: "week",
                            				    fromNow:0,
                            				    className: "view_1",
                            				    calendars: [],
                            				    slotTitleFormat:"MM/DD",
                            				    slotSubTitleFormat: "dddd",
                            				    beforeDays: "7",
                            				    hideOverflow: false,
                            				    type: "row",
                            				    name: "Family Calendar",
                            				    url: "https://calendar.google.com/calendar/ical",
                            				    scanInterval: 2000,
                            				    className: "family_calendar",
                            				    maxIterations: 100,
                            				    name: "Dad's Calendar",
                            					    scanInterval: 2000,
                            				    className: "dads_calendar",
                            				    maxIterations: 100,
                            				    name: "Mom's Calendar",
                            				    scanInterval: 2000,
                            				    className: "moms_calendar",
                            				    maxIterations: 100,
                            				    name: "Alana's Calender",
                            				    scanInterval: 2000,
                            				    className: "alanas_calendar",
                            				    maxIterations: 100,
                            				    name: "John's Calendar",
                            				    scanInterval: 2000,
                            				    className: "johns_calendar",
                            				    maxIterations: 100,
                            				    name: "Holiday Calendar",
                            				    url: "https://calendar.google.com/calendar/ical,
                            				    scanInterval: 2000,
                            				    className: "holiday_calendar",
                            				    maxIterations: 100,
                              @Fr8Trayne
                              I think this could be also maxItems issue of view.
                              You have several calendars in a view, it means you might have tons of events in the memory of RPI.(You can check how much events are selected to load on your log.)
                              Which events should be displayed would be decided by some rules with some condition - filter, sort, … In this case, you haven’t set your rule, so the view would contain 100 events(set as default, sorted by time) from whole calendars. And most(or all) of them would be too old events to display in this view.
                              Just set the maxItems of view bigger, or set your rule of filter or sort events to display.
                              • F
                                Fr8Trayne
                                @Sean thanks. I have added those changes with no effect. Would you mind guiding me to find those stores events in the RPI? I’d like to see if that is the issue.
                                  @Fr8Trayne
                                  Could you share with me your real ical url or file to inspect? you can send it via email. (eouia0819@gmail.com)
                                  • L
                                    lotusvball
                                    Can someone show me what I am doing wrong. I have this configuration:
                                    		module: 'MMM-CalendarExt2',
                                    			//firstDrawingDelay: 1000*10,
                                    			scenes:[
                                    					views: ["VIEW1"],
                                    			views:[
                                    					mode: "daily",
                                    					title: "Bard Family Schedule",
                                    					position: "bottom_right",
                                    					maxItems: 100,
                                    					maxDays: 5,
                                    					locale: "en",
                                    					hideOverflow: true,
                                    					filterPassedEvent: true,
                                    					slotCount: 4,
                                    					calendars: ["Steve","Tracie","Alex"],
                                    					url: "https://calendar.google.com/calendar/ical/",
                                    					beforeDays:0,
                                    					afterDays: 5,
                                    					beforeDays:0,
                                    					afterDays: 5,
                                    					beforeDays:0,
                                    					afterDays: 5,
                                    The actual calendars have the correct url in my setup. If I set one calendar to show in the view ie. [“Alex”] it works but if I try to do all of them I get nothing. Only the headings for the days.
                                    Here is the startup sequence:
                                    Starting MagicMirror: v2.9.0
                                    Loading config …
                                    Loading module helpers …
                                    Module helper loaded: MMM-GooglePhotos
                                    Module helper loaded: MMM-MyScoreboard
                                    No helper found for module: MMM-pages.
                                    Module helper loaded: MMM-OnScreenMenu
                                    No helper found for module: MMM-SmartWebDisplay.
                                    Module helper loaded: MMM-CalendarExt2
                                    All module helpers loaded.
                                    Starting server on port 8080 …
                                    Server started …
                                    Connecting socket for: MMM-GooglePhotos
                                    MMM-GooglePhotos started
                                    Connecting socket for: MMM-MyScoreboard
                                    Starting node_helper for module [MMM-MyScoreboard]
                                    Connecting socket for: MMM-OnScreenMenu
                                    Connecting socket for: MMM-CalendarExt2
                                    Sockets connected & modules started …
                                    Launching application.
                                    MMM-GooglePhotos initialized after loading.
                                    [CALEXT2] calendar:Steve >> Scanning start with interval:1800000
                                    [CALEXT2] calendar:Tracie >> Scanning start with interval:1800000
                                    [CALEXT2] calendar:Alex >> Scanning start with interval:1800000
                                    [CALEXT2] calendar:Alex >> Scanned: 3, Selected: 3
                                    [GPHOTO] Scan finished : 66
                                    [CALEXT2] calendar:Steve >> Scanned: 0, Selected: 0
                                    [CALEXT2] calendar:Tracie >> Scanned: 7, Selected: 7
                                    Can you see anything I am doing wrong?
                                      A Former User @lotusvball
                                      @lotusvball
                                      Could you share with me your real ical(.ics) file or URL? By only inspection of real ical, I can tell what’s wrong.
                                      email : eouia0819@gmail.com
                                      L 1 Reply Last reply
                                      • L
                                        lotusvball @Guest
                                        @Sean Just emailed it. from sabard@gmail.com
                                          code999 @wegz15
                                          @wegz15 Hey!! your layout is the exact one I have been trying to do for many hours over the last months. May you please paste the code you used to make it looks like that? thx ( the doc’s are confusing and do not show where the part of the codes go to make it work. i liked the first Ext docs better.)
                                            rookiepilot
                                            Did anybody else’s MMM-CalendarExt2 module break after daylight savings? (Sunday November 3rd). Both my “MMM-MyCalendar” AND “MMM-CalendarExt2” modules are showing events on the wrong days now. The problem seems to only occur with reoccurring events; they usually show up one day earlier. Rebooting does not correct the issue. I hope someone can figure this out soon 😞
                                            • 24
                                            • 25
                                            • 4 / 25
