    Creating Module with API Key/Secret
    15 Posts 4 Posters 7.0k Views 4 Watching
    • L
      lilpkstud Module Developer
      @lavolp3 Thanks for the example I will look into it more
      However, is there a way to put my request token inside of the request header?
      • lavolp3L
        lavolp3 Module Developer
        @lilpkstud
        Well, you can call any variable from your config/defaults using the reference this.config.variable.
        Or this.config.requestToken respectively.
        Something important to remember:
        Sometimes, e.g. when you use a callback function, note that the this reference may change (better: the context changes).
        Therefore you will often see something like this in the module codes early in a function:
        self = this
        And later on in the callback function
        self.config.requestToken
        Here, the “this” instance that is bound to its context, gives it’s properties to the global variable “self” that can then be used in any context (because it is global).
        For (much) more information check out https://scotch.io/@alZami/understanding-this-in-javascript
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • L
          Having trouble displaying the information that I received from Yelp API
           getDom: function() {
                  var self = this;
                  //If this.dataRequest is not empty
                  if(this.data && this.data.length > 0){
                      console.log("MMM-Test: This.data is set" + this.data);
                      //Name of Business
                      var wrapperDataRequest = document.createElement("h1");
                      wrapperDataRequest.innerHTML = this.data;
                      wrapperDataRequest.className = 'yelpBusinessName';
                      wrapper.appendChild(imgDataRequest);
                      wrapper.appendChild(wrapperDataRequest);
                  } else {
                      console.log("MMM-Test: this.data couldn't be found");
                      wrapper.innerHTML = "This didn't work";
                  return wrapper;
          MMM-Test: This.data is set{"id":"E8RJkjfdcwgtyoPMjQ_Olg","alias":"four-barrel-coffee-san-francisco","name":"Four Barrel Coffee","image_url":"https://s3-media1.fl.yelpcdn.com/bphoto/-_Ks4eF8aZcm3GZgUf5Urg/o.jpg","is_closed":false,"url":"https://www.yelp.com/biz/four-barrel-coffee-san-francisco?adjust_creative=joufChkTQP-Ru-G_5cRrMA&utm_campaign=yelp_api_v3&utm_medium=api_v3_business_search&utm_source=joufChkTQP-Ru-G_5cRrMA","review_count":2069,"categories":[{"alias":"coffee","title":"Coffee & Tea"}],"rating":4,"coordinates":{"latitude":37.7670169511878,"longitude":-122.42184275},"transactions":[],"price":"$","location":{"address1":"375 Valencia St","address2":"","address3":"","city":"San Francisco","zip_code":"94103","country":"US","state":"CA","display_address":["375 Valencia St","San Francisco, CA 94103"]},"phone":"+14158964289","display_phone":"(415) 896-4289","distance":1452.8696502343696}
          How can I display name?
          I tried this.data[0].name or this.data.name but no luck
          • lavolp3L
            lavolp3 Module Developer @lilpkstud
            @lilpkstud this.data is an object, not an array. So this.data.name should do the trick. In the code above you have only this.data!?
            • L
              lilpkstud Module Developer @lavolp3
              @lavolp3 I deleted this.data.name because I was getting undefined and I still am
              • L
                @lavolp3
                This line of code will show a { on my mirror so I’m assuming everything is turned into a string?
                I used JSON.stringify() in my node_helper file
                            wrapperDataRequest.innerHTML = this.data[0];
                  sdetweil @lilpkstud
                  @lilpkstud said in Creating Module with API Key/Secret:
                  JSON.stringify()
                  correct… u converted the object to a string… don’t need to do that
                  just pass the object from helper up to module …
                  then it will use the this.data.name
                  • strawberry 3.141S
                    @lilpkstud next to what sdetweil said you should also not save your result into this.data as it is an instance property which already contains data, see https://github.com/MichMich/MagicMirror/tree/master/modules#available-module-instance-properties for reference
                      sdetweil @strawberry 3.141
                      @strawberry-3-141 should call it api_data maybe!
                      • L
                        @sdetwell @strawberry-3-141 thanks guys got it to work!
                        I used JSON.Stringify() to look at the data when I was console.loggining so that was the reason why my object were turning into strings
                          sdetweil @lilpkstud
                          @lilpkstud cool… if need it in strings someplace, need to convert it back object=JSON.parse(string)
