This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
MMM-Temperature/Humidity Module (DHT11, DHT22 and AM2302 sensors.)
@d3r Dht 22 and 11 series doesnt require one :)
PS: Just saw the post.Was out of town for two weeks…
@psk
That depends on the sensor you buy. If you use a sensor with 4 pins you need the resistor. If you use the sensor with 3 pins mounted to a circuit board you don’t need the resistor. -
This was my reference. Both the models are similar, though the one without the PCB(4 pin model) might require some resistance. Not sure though…Need to dig Deeper :D
Cheers :) -
Right. I have the 4 pin version and this requires a resistor
This post is deleted! -
Apparently, this project is dead. modules are missing all over the place, and unable to install…
rpi-dht-sensor not found.
npm install falls all over itself.Just a mess.
