    MMM-Temperature/Humidity Module (DHT11, DHT22 and AM2302 sensors.)
    34 Posts 11 Posters 41.1k Views 10 Watching
    • H Offline
      H3L1o150
      @yawns so i left the config.js file like that?
               module: 'MMM-Temperature-Humidity',
                position: 'top_right',
      • Y Offline
        yawns Moderator @H3L1o150
        I never played around with this module. But I would use this:
        { module: 'MMM-Temperature-Humidity', position: 'top_right' }
        And then you edit node_helper.js to set for DHT11 or DHT22 and the correct pin in ( )
        • H Offline
          H3L1o150
          @yawns Tanks for the help
          maybe i’m wrong in code. with me show a white screen
            psk @H3L1o150
            @H3L1o150 currently, to define the pin to which sensor is connected, you need to edit the node_helper.js file ind MMM-Temperature-Humidity directory and edit line number 12.
            var dht = new rpiDhtSensor.DHT11(2); to var dht = new rpiDhtSensor.DHT11(21);
            you can leave the config as
            			position: 'bottom_right',
            				refreshInterval: 10000,
            				temperaturePrefix: "Room temperature: ",
            				temperatureSuffix: "°C",
            				humidityPrefix: "Humidity: ",
            				humiditySuffix: "%"
            guess this needs to be improved in future release… :D
            P.S.K
            • H Offline
              H3L1o150
              Tanks @psk
                jsyzthz
                i found MMM cannot auto startup if use it. because it must be run with sudo. but i don’t know how to run sudo with ‘DISPLAY=:0’? @psk
                  Bangee Module Developer
                  @jsyzthz checkt this out: https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module
                    psk @jsyzthz
                    @jsyzthz Unfortunately neither did I have any luck executing with sudo while using ‘DISPLAY=:0’ .
                    For auto start I used PM2.
                    This is my mm.sh file
                    DISPLAY=:0 sudo npm start
                    P.S : I haven’t yet tried this alternative by Bangee. But it sure looks promising in this scenario where we need the mirror to start from ssh(or Terminal) while specifying the display device.
                    If i come across any workarounds, I’ll update.
                    Cheers.
                    P.S.K
                      jsyzthz
                      @psk , when i execute your command in my pi3 from putty. will get below error.
                      0_1476980028924_upload-94e2d7d2-b3a1-493a-a093-7ac8645113c3
                        d3r
                        I’m going to order the dht-22 soon. I was reading about the sensor set up and most guides mention using a resistor. Do you guys have one in your set up?
                          psk @d3r
                          @d3r Dht 22 and 11 series doesnt require one :)
                          PS: Just saw the post.Was out of town for two weeks…
                          P.S.K
                          • Y Offline
                            yawns Moderator @psk
                            @psk
                            That depends on the sensor you buy. If you use a sensor with 4 pins you need the resistor. If you use the sensor with 3 pins mounted to a circuit board you don’t need the resistor.
                              psk
                              This was my reference. Both the models are similar, though the one without the PCB(4 pin model) might require some resistance. Not sure though…Need to dig Deeper :D
                              Cheers :)
                              P.S.K
                              • Y Offline
                                yawns Moderator
                                Right. I have the 4 pin version and this requires a resistor
                                • T Offline
                                  techzeero
                                  • BKeyportB Offline
                                    BKeyport Module Developer
                                    Apparently, this project is dead. modules are missing all over the place, and unable to install…
                                    rpi-dht-sensor not found.
                                    npm install falls all over itself.
                                    Just a mess.
