    Raspberry 4 with two 24-inch screens ?
    17 Posts 7 Posters 9.0k Views 6 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @Cbob
      @Cbob That is a very great and expensive idea!!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        Cbob
        @lavolp3 I have 2 recycled 24 inch screens (easily found and easily for repair), and the big screen (46/50 inch) is more expensive :)
        @SammyJankins “If someone has the right config for the css”, it interests me too :)
          Cbob
          I work on my project but i have a probleme :/.
          I can not activate the 2nd screen with magic miror.
          could you tell me how to activate the 2nd screen ? Raspbian works well on both, but I can not find how to activate the 2nd screen with magic mirror ?
          thank you :)
            sdetweil @Cbob
            @Cbob you will have to run two instances of MagicMirror, and use the electron options to position the one instance on each screen.
            see here for another user positioning the MM screen on the right monitor
            https://forum.magicmirror.builders/topic/11158/cannot-get-magic-mirror-to-start-on-second-screen/9
              Cbob
              thank you for your answer, but I did not succeed.
              I have two instances that launch, but it appears on the same screen. Are you solution for to help me ?
                sdetweil @Cbob
                @Cbob
                following the configuration instructions
                https://github.com/MichMich/MagicMirror#general
                you can add a section for passing to the browser, electron
                add that line in front of the modules: line
                this says,
                not fullscreen
                800 pixels wide
                and starting (left edge is 0) at pixel 600
                 electronOptions: {fullscreen:false, width:800, x:600},
                so, if your screen is 1920*2 wide
                to get the window onto the second screen,
                x:1920 seems right
                  Bruno
                  Guys, I’m having problem starting two instances of magic mirror.
                  I have a Raspberry Pi 4. One HDMI port is connected on my PC Screen, the other one on my TV (just for example. I’ll use two screens on my actual mirror).
                  I am able to start Magic Mirror on the second screen putting this line on the config.js of the second instance
                  electronOptions: {fullscreen:true, x:1920},
                  (My first screen is 1920px wide).
                  I can get two instances to work, the problem is they are ALWAYS the same instance.
                  One instance is installed on ~/MagicMirror. The second is on ~/MagicMirror2.
                  I have two start scripts:
                  ~/MagicMirror/mm.sh
                  cd /home/pi/MagicMirror
                  DISPLAY=:0 npm start
                  And ~/MagicMirror2/mm2.sh
                  cd /home/pi/MagicMirror2
                  The first instance I have my modules and the second is the default instance (default config.js) that comes with the instalation (except for the “electronOptions” above, “address” and “ipWhiteList”).
                  The problem is that the second instance I start ALWAYS is the same as the first one.
                  For example, if I use “pm2 start mm”, my first instance appears on my first screen.
                  After that I use “pm2 start mm2” and also the FIRST INSTANCE appears on the second screen.
                  Any thoughts on how to correct that? What am I doing wrong?
                    sdetweil @Bruno
                    @Bruno use pm2 info mm, and pm2 mm2 to make sure they are starting the right script
                      Bruno
                      Ok, sorry. Just found out… I was using the same port on both instances :neutral_face:
                        banbutcher
                        for display 1 - mm.sh
                        for display 2 - mm2.sh
                        DISPLAY=:1 npm start
                        i could be wrong tho…
