    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 112.1k Views 14 Watching
      bobbythemoh
      @idoodler I have to ask for help again:
      Just updated my Magic Mirror with
      cd MagicMirror
      git pull
      npm install
      Its Version is 2.9.0.
      Now i am not able to start the Module any more…
      pm2 Log gives:
      0|MagicMir | Connecting socket for: MMM-Loxone
      0|MagicMir | Connecting socket for: calendar
      0|MagicMir | Starting node helper for: calendar
      0|MagicMir | Connecting socket for: MMM-RPI-LED
      0|MagicMir | Starting module helper: MMM-RPI-LED
      0|MagicMir | Connecting socket for: MMM-MoonPhase
      0|MagicMir | Starting module helper: MMM-MoonPhase
      0|MagicMir | Connecting socket for: newsfeed
      0|MagicMir | Starting module: newsfeed
      0|MagicMir | Sockets connected & modules started ...
      0|MagicMir | Launching application.
      0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
      0|MagicMir | Create new calendar fetcher for url: http://localhost:8080/modules/calendars/ - Interval: 300000
      0|MagicMir | Create new news fetcher for url: http://derStandard.at/?page=rss&ressort=Seite1 - Interval: 300000
      0|MagicMir | Create new news fetcher for url: https://rss.orf.at/news.xml - Interval: 300000
      0|MagicMir | Opening Socket to your Miniserver
      0|MagicMir | (node:1367) UnhandledPromiseRejectionWarning: RangeError [ERR_OUT_OF_RANGE]: The value of "value" is out of range. It must be >= 0 and <= 4294967295. Received -1344780921
      0|MagicMir |     at checkInt (internal/buffer.js:35:11)
      0|MagicMir |     at writeU_Int32BE (internal/buffer.js:625:3)
      0|MagicMir |     at Buffer.writeUInt32BE (internal/buffer.js:638:10)
      0|MagicMir |     at WebSocketFrame.toBuffer (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketFrame.js:257:24)
      0|MagicMir |     at WebSocketConnection.sendFrame (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:857:43)
      0|MagicMir |     at WebSocketConnection.fragmentAndSend (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:793:14)
      0|MagicMir |     at WebSocketConnection.sendUTF (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:733:10)
      0|MagicMir |     at W3CWebSocket.send (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/W3CWebSocket.js:116:26)
      0|MagicMir |     at LxWebSocket.self.onSend (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/WebSocketWrapper.js:192:21)
      0|MagicMir |     at LxWebSocket.send (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/WebSocketWrapper.js:253:14)
      0|MagicMir | (node:1367) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      0|MagicMir | (node:1367) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      0|MagicMir | Error: Malformed UTF-8 data
      0|MagicMir |     at Object.stringify (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/crypto-js/core.js:478:24)
      0|MagicMir |     at WordArray.init.toString (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/crypto-js/core.js:215:38)
      0|MagicMir |     at Object.aesDecrypt (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/CryptoAdapter.js:189:26)
      0|MagicMir |     at WebSocket._decryptResponse (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:879:38)
      0|MagicMir |     at WebSocket._handleResponse (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:807:25)
      0|MagicMir |     at WebSocket._textMessageHandler (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:753:18)
      0|MagicMir |     at W3CWebSocket.onmessage (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/vendor/WebSocketWrapper.js:99:56)
      0|MagicMir |     at W3CWebSocket._dispatchEvent [as dispatchEvent] (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/yaeti/lib/EventTarget.js:107:17)
      0|MagicMir |     at W3CWebSocket.onMessage (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/W3CWebSocket.js:234:14)
      0|MagicMir |     at WebSocketConnection.<anonymous> (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/W3CWebSocket.js:205:19)
      0|MagicMir | WebSocket: ERROR while parsing string: 'undefined'
      0|MagicMir | SyntaxError: Unexpected token u in JSON at position 0
      0|MagicMir |     at JSON.parse (<anonymous>)
      0|MagicMir |     at WebSocket._handleResponse (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator/modules/WebSocket.js:810:29)
      0|MagicMir |     at WebSocketConnection.emit (events.js:182:13)
      0|MagicMir |     at WebSocketConnection.processFrame (/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:552:26)
      0|MagicMir |     at /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/lib/WebSocketConnection.js:321:40
      0|MagicMir | WebSocket:  socket failed! WS Close Code: 1006
      0|MagicMir | { errorCode: 418 }
      idoodlerI 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @bobbythemoh
        @bobbythemoh Hi, did you make any changes to your Loxone installation?
        If not please try to reinstall the MMM-Loxone project.
          bobbythemoh
          Hey if you mean to the Mini-Server Software, than no. It was working perfectly before the update. Ok, ill try reinstalling.
            bobbythemoh
            Here is what I did:
            cd MagicMirror/Modules
            rm -rf MMM-Loxone
            cd ~/MagicMirror/modules
            git clone https://github.com/idoodler/MMM-Loxone
            cd ~/MagicMirror/modules/MMM-Loxone
            npm install
            npm install gives:
            pi@MagicMirror:~/MagicMirror/modules/MMM-Loxone $ npm install
            npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something bett er. This package will continue to work with Grunt v1, but it will not receive any updates.
            > websocket@1.0.29 install /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket
            > (node-gyp rebuild 2> builderror.log) || (exit 0)
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/build'
              CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
              SOLINK_MODULE(target) Release/obj.target/bufferutil.node
              COPY Release/bufferutil.node
              CXX(target) Release/obj.target/validation/src/validation.o
              SOLINK_MODULE(target) Release/obj.target/validation.node
              COPY Release/validation.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/build'
            > lxcommunicator@1.0.1 postinstall /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator
            > node ./browserify.js
            Creating browserified module...
            Creating debug module
            Creating release module
            Saving debug module
            Saving release module
            LxCommunicator~Browser.js and LxCommunicator~Browser.min.js has been created!
            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dep endencies yourself.
            npm WARN stylelint-config-standard@19.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must insta ll peer dependencies yourself.
            npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must ins tall peer dependencies yourself.
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":" any"} (current: {"os":"linux","arch":"arm"})
            added 650 packages from 453 contributors and audited 8175 packages in 323.529s
            found 1 moderate severity vulnerability
              run `npm audit fix` to fix them, or `npm audit` for details
            Then I did a reboot
              bobbythemoh
              Well there is some weird stuff going on… config file is there…
              Guess thats not related to MMM-Loxone… i think ill do a new installation… or do you have a better idea?
              0|MagicMir | No helper found for module: clock.
              0|MagicMir | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
              0|MagicMir | Loading module helpers ...
              0|MagicMir | No helper found for module: alert.
              0|MagicMir | App threw an error during load
              0|MagicMir | Error: Cannot find module 'node_helper'
              0|MagicMir |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
              0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
              0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
              0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:658:17)
              0|MagicMir |     at require (internal/modules/cjs/helpers.js:20:18)
              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:9:18)
              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:82:3)
              0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:711:30)
              0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
              0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:620:32)
              0|MagicMir | Whoops! There was an uncaught exception...
              0|MagicMir | { Error: Cannot find module 'node_helper'
              0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
              idoodlerI S 2 Replies Last reply
              • idoodlerI
                @bobbythemoh Yeah, looks like there are some files missing. I think a new installation is a good idea. You can first check if there are any problems with git status.
                  sdetweil @bobbythemoh
                  @bobbythemoh Do
                  git checkout -- modules/node_modules/node_helper/index.js
                    bobbythemoh
                    Hey guys, I was pretty busy in work this week, so i just wanted to redo the installation, then i saw your post @sdetweil That solved the issue for me! thank you so much for your help…
                    • elmatttE
                      elmattt
                      Hi ! this is working great !!
                      it show my indoor temp in the forecast module, and presence works great.
                      i have an issue, i want to show on the mirror the temp of another room (mine), but it show only : CHARGEMENT &HELLIP; (loading …)
                      any idea ??
                      Thanks :D
                      P 1 Reply Last reply
                        pavka28 @elmattt
                        @elmattt
                        Recieved the same
                        Loading…&HELLIP
                        Did you solve?
                        • idoodlerI
                          idoodler Module Developer @pavka28
                          @pavka28 @elmattt Can you guys please provide me your MMM-Loxone config without your credentials. Can you also please double check the UUID of the control you want to display.
                          • idoodlerI
                            @pavka28 @elmattt Any update, did you fix the issue?
                            • elmatttE
                              elmattt
                              didn’t have time to test … sorry ! but i think i was doing the wrong thing… is it possible to double the module in the config ? and show another UUID for the second module ?
                              • idoodlerI
                                idoodler Module Developer @elmattt
                                @elmattt I guess you want to show multiple controls, right? If this is the case you need to assign the observingUuids property an array of UUIDs, something like.
                                observingUuids: ["0eaf7a2f-0011-1f28-ffff2083eaf2523c", "12a97c52-00a6-aea9-ffffc00216fecef2", "10338564-033c-226f-ffff0b7b5fc746d6"]
                                Please provide the relevant part of your config.js without any crucial informations like IP, username, password, …
                                  Phil__
                                  Hello Everyone,
                                  today i updated my MagicMirror Setup (and all modules).
                                  Now i have trouble with the MMM-Loxone Module. My Display do not turn off, it shows a black screen instead turning off.
                                  The pm2 log shows a interessting Message: " This is no Raspberry Pi, toggle the display is not supported!"
                                  My Setup:
                                  • Raspberry Pi 4
                                  • latest Raspian Image with all Updates
                                  • latest Updates for MagicMirror and Modules
                                  Can anyone help me?
                                  Phil
                                  1|MagicMirror | MMM-Loxone Found room: Wohnzimmer
                                  1|MagicMirror | [2020-09-25 12:57:13.716] [INFO] MMM-Loxone Search IRC for room temperature
                                  1|MagicMirror | [2020-09-25 12:57:13.723] [INFO]
                                  1|MagicMirror | MMM-Loxone Found IRC (WZ Raumregelung) in room Wohnzimmer
                                  1|MagicMirror | [2020-09-25 12:57:13.724] [INFO] MMM-Loxone Check if presenceUuid is defined
                                  1|MagicMirror | [2020-09-25 12:57:13.733] [INFO]
                                  1|MagicMirror | MMM-Loxone Search LightControls and LightV2Controls in room
                                  1|MagicMirror | [2020-09-25 12:57:13.735] [INFO]
                                  1|MagicMirror | MMM-Loxone Found LightControl (Flur-EG Lichtsteuerung) in room Wohnzimmer
                                  1|MagicMirror | [2020-09-25 12:57:13.737] [INFO]
                                  1|MagicMirror | MMM-Loxone NotificationUuid: 0d314264-022b-0294-ffffed497d367efa
                                  1|MagicMirror | [2020-09-25 12:57:13.738] [INFO] MMM-Loxone Enabling statusupdates
                                  1|MagicMirror | [2020-09-25 12:57:13.798] [LOG]
                                  1|MagicMirror | MMM-Loxone Successfully executed ‘dev/sps/enablebinstatusupdate’ with code 200 and value 1
                                  1|MagicMirror | [2020-09-25 12:57:14.467] [INFO]
                                  1|MagicMirror | MMM-Loxone Got room temperature: 23.5
                                  1|MagicMirror | [2020-09-25 12:57:14.531] [INFO]
                                  1|MagicMirror | MMM-Loxone Got lightMood change to: All off(778)
                                  1|MagicMirror | [2020-09-25 12:57:14.534] [INFO]
                                  1|MagicMirror | This is no Raspberry Pi, toggle the display is not supported!
                                  • idoodlerI
                                    idoodler Module Developer @Phil__
                                    Hi @Phil__,
                                    I think the Raspberry Pi 4 works a little bit different that the 3 or so.
                                    If MMM-Loxone can‘t toggle off the display it just fades in a black overlay to hopefully trigger the screens power saving mode.
                                    I will have a look at it when my Pi 4 arrives.
                                    Meanwhile I ask you to create an issue on the Github Repo
                                      bobbythemoh
                                      Dear Community and David,
                                      I was operating the mirror for 3 years now without any issue but 2 weeks ago i destroyed it with an update. So i made a new setup and found out some things with MMM-Loxone where i need help. I did not change the hardware (still raspi 3B) - just new OS + Latest MM + Latest Modules.
                                      “Fade Out” is default false according to documentation but my obervation is: If nothing is in the config - it is fading out - if I set fadeout: false, peresence is not working anymore. I think this is not working correctly.
                                      The monitor is not switching off - its just getting black but no power safe option - so “wasting” 46 Watts all the time. i found a commit from 09.02.2022 where you removed “vcgencmd” because of compatibility issues - i found the passage in “node_helper.js” at line 314 - uncommented it and it works fine again.
                                      CSS Style - The font became so much smaller - i would like to make it bigger i tried to edit it in custom.css file but it did not change fontsize - then i found out that there is a “MMM-Loxone.css” - why is there a separate css?
                                      I tried to add the code below without success. How to make the font bigger?
                                      Thank you in advance!
                                       * MMM-Loxone
                                       * idoodler
                                       * MIT Licensed.
                                       * Custom here your css module
                                      .xsmall{
                                      font-family: 'Roboto Condensed';
                                      font-size: 30px;
                                      line-height: 40px;
                                      .small{
                                      font-size: 30px;
                                      line-height: 40px;
                                      .medium{
                                      font-size: 30px;
                                      line-height: 40px;
                                        @bobbythemoh I recommend u open an issue on the module GitHub page to engage the author. no guarantee they are looking at the forum
                                        B 1 Reply Last reply
                                          bobbythemoh @sdetweil
                                          @sdetweil thanks, i will do so!
                                          • 5 / 5
