    MMM-Loxone
    loxonesmart home
    94 Posts 11 Posters 112.1k Views 14 Watching
    • idoodlerI
      idoodler Module Developer @bobbythemoh
      @bobbythemoh Hi, did you make any changes to your Loxone installation?
      If not please try to reinstall the MMM-Loxone project.
        bobbythemoh
        Hey if you mean to the Mini-Server Software, than no. It was working perfectly before the update. Ok, ill try reinstalling.
          bobbythemoh
          Here is what I did:
          cd MagicMirror/Modules
          rm -rf MMM-Loxone
          cd ~/MagicMirror/modules
          git clone https://github.com/idoodler/MMM-Loxone
          cd ~/MagicMirror/modules/MMM-Loxone
          npm install
          npm install gives:
          pi@MagicMirror:~/MagicMirror/modules/MMM-Loxone $ npm install
          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something bett er. This package will continue to work with Grunt v1, but it will not receive any updates.
          > websocket@1.0.29 install /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket
          > (node-gyp rebuild 2> builderror.log) || (exit 0)
          make: Entering directory '/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/build'
            CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
            SOLINK_MODULE(target) Release/obj.target/bufferutil.node
            COPY Release/bufferutil.node
            CXX(target) Release/obj.target/validation/src/validation.o
            SOLINK_MODULE(target) Release/obj.target/validation.node
            COPY Release/validation.node
          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Loxone/node_modules/websocket/build'
          > lxcommunicator@1.0.1 postinstall /home/pi/MagicMirror/modules/MMM-Loxone/node_modules/lxcommunicator
          > node ./browserify.js
          Creating browserified module...
          Creating debug module
          Creating release module
          Saving debug module
          Saving release module
          LxCommunicator~Browser.js and LxCommunicator~Browser.min.js has been created!
          npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dep endencies yourself.
          npm WARN stylelint-config-standard@19.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must insta ll peer dependencies yourself.
          npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must ins tall peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":" any"} (current: {"os":"linux","arch":"arm"})
          added 650 packages from 453 contributors and audited 8175 packages in 323.529s
          found 1 moderate severity vulnerability
            run `npm audit fix` to fix them, or `npm audit` for details
          Then I did a reboot
            bobbythemoh
            Well there is some weird stuff going on… config file is there…
            Guess thats not related to MMM-Loxone… i think ill do a new installation… or do you have a better idea?
            0|MagicMir | No helper found for module: clock.
            0|MagicMir | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
            0|MagicMir | Loading module helpers ...
            0|MagicMir | No helper found for module: alert.
            0|MagicMir | App threw an error during load
            0|MagicMir | Error: Cannot find module 'node_helper'
            0|MagicMir |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
            0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
            0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:658:17)
            0|MagicMir |     at require (internal/modules/cjs/helpers.js:20:18)
            0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:9:18)
            0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:82:3)
            0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:711:30)
            0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
            0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:620:32)
            0|MagicMir | Whoops! There was an uncaught exception...
            0|MagicMir | { Error: Cannot find module 'node_helper'
            0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
            idoodlerI S 2 Replies Last reply
            • idoodlerI
              @bobbythemoh Yeah, looks like there are some files missing. I think a new installation is a good idea. You can first check if there are any problems with git status.
                sdetweil @bobbythemoh
                @bobbythemoh Do
                git checkout -- modules/node_modules/node_helper/index.js
                  bobbythemoh
                  Hey guys, I was pretty busy in work this week, so i just wanted to redo the installation, then i saw your post @sdetweil That solved the issue for me! thank you so much for your help…
                  • elmatttE
                    elmattt
                    Hi ! this is working great !!
                    it show my indoor temp in the forecast module, and presence works great.
                    i have an issue, i want to show on the mirror the temp of another room (mine), but it show only : CHARGEMENT &HELLIP; (loading …)
                    any idea ??
                    Thanks :D
                    P 1 Reply Last reply
                      pavka28 @elmattt
                      @elmattt
                      Recieved the same
                      Loading…&HELLIP
                      Did you solve?
                      idoodlerI 1 Reply Last reply
                      • idoodlerI
                        idoodler Module Developer @pavka28
                        @pavka28 @elmattt Can you guys please provide me your MMM-Loxone config without your credentials. Can you also please double check the UUID of the control you want to display.
                        • idoodlerI
                          @pavka28 @elmattt Any update, did you fix the issue?
                          • elmatttE
                            elmattt
                            didn’t have time to test … sorry ! but i think i was doing the wrong thing… is it possible to double the module in the config ? and show another UUID for the second module ?
                            • idoodlerI
                              idoodler Module Developer @elmattt
                              @elmattt I guess you want to show multiple controls, right? If this is the case you need to assign the observingUuids property an array of UUIDs, something like.
                              observingUuids: ["0eaf7a2f-0011-1f28-ffff2083eaf2523c", "12a97c52-00a6-aea9-ffffc00216fecef2", "10338564-033c-226f-ffff0b7b5fc746d6"]
                              Please provide the relevant part of your config.js without any crucial informations like IP, username, password, …
                                Phil__
                                Hello Everyone,
                                today i updated my MagicMirror Setup (and all modules).
                                Now i have trouble with the MMM-Loxone Module. My Display do not turn off, it shows a black screen instead turning off.
                                The pm2 log shows a interessting Message: " This is no Raspberry Pi, toggle the display is not supported!"
                                My Setup:
                                • Raspberry Pi 4
                                • latest Raspian Image with all Updates
                                • latest Updates for MagicMirror and Modules
                                Can anyone help me?
                                Phil
                                1|MagicMirror | MMM-Loxone Found room: Wohnzimmer
                                1|MagicMirror | [2020-09-25 12:57:13.716] [INFO] MMM-Loxone Search IRC for room temperature
                                1|MagicMirror | [2020-09-25 12:57:13.723] [INFO]
                                1|MagicMirror | MMM-Loxone Found IRC (WZ Raumregelung) in room Wohnzimmer
                                1|MagicMirror | [2020-09-25 12:57:13.724] [INFO] MMM-Loxone Check if presenceUuid is defined
                                1|MagicMirror | [2020-09-25 12:57:13.733] [INFO]
                                1|MagicMirror | MMM-Loxone Search LightControls and LightV2Controls in room
                                1|MagicMirror | [2020-09-25 12:57:13.735] [INFO]
                                1|MagicMirror | MMM-Loxone Found LightControl (Flur-EG Lichtsteuerung) in room Wohnzimmer
                                1|MagicMirror | [2020-09-25 12:57:13.737] [INFO]
                                1|MagicMirror | MMM-Loxone NotificationUuid: 0d314264-022b-0294-ffffed497d367efa
                                1|MagicMirror | [2020-09-25 12:57:13.738] [INFO] MMM-Loxone Enabling statusupdates
                                1|MagicMirror | [2020-09-25 12:57:13.798] [LOG]
                                1|MagicMirror | MMM-Loxone Successfully executed ‘dev/sps/enablebinstatusupdate’ with code 200 and value 1
                                1|MagicMirror | [2020-09-25 12:57:14.467] [INFO]
                                1|MagicMirror | MMM-Loxone Got room temperature: 23.5
                                1|MagicMirror | [2020-09-25 12:57:14.531] [INFO]
                                1|MagicMirror | MMM-Loxone Got lightMood change to: All off(778)
                                1|MagicMirror | [2020-09-25 12:57:14.534] [INFO]
                                1|MagicMirror | This is no Raspberry Pi, toggle the display is not supported!
                                • idoodlerI
                                  idoodler Module Developer @Phil__
                                  Hi @Phil__,
                                  I think the Raspberry Pi 4 works a little bit different that the 3 or so.
                                  If MMM-Loxone can‘t toggle off the display it just fades in a black overlay to hopefully trigger the screens power saving mode.
                                  I will have a look at it when my Pi 4 arrives.
                                  Meanwhile I ask you to create an issue on the Github Repo
                                    bobbythemoh
                                    Dear Community and David,
                                    I was operating the mirror for 3 years now without any issue but 2 weeks ago i destroyed it with an update. So i made a new setup and found out some things with MMM-Loxone where i need help. I did not change the hardware (still raspi 3B) - just new OS + Latest MM + Latest Modules.
                                    “Fade Out” is default false according to documentation but my obervation is: If nothing is in the config - it is fading out - if I set fadeout: false, peresence is not working anymore. I think this is not working correctly.
                                    The monitor is not switching off - its just getting black but no power safe option - so “wasting” 46 Watts all the time. i found a commit from 09.02.2022 where you removed “vcgencmd” because of compatibility issues - i found the passage in “node_helper.js” at line 314 - uncommented it and it works fine again.
                                    CSS Style - The font became so much smaller - i would like to make it bigger i tried to edit it in custom.css file but it did not change fontsize - then i found out that there is a “MMM-Loxone.css” - why is there a separate css?
                                    I tried to add the code below without success. How to make the font bigger?
                                    Thank you in advance!
                                     * MMM-Loxone
                                     * idoodler
                                     * MIT Licensed.
                                     * Custom here your css module
                                    .xsmall{
                                    font-family: 'Roboto Condensed';
                                    font-size: 30px;
                                    line-height: 40px;
                                    .small{
                                    font-size: 30px;
                                    line-height: 40px;
                                    .medium{
                                    font-size: 30px;
                                    line-height: 40px;
                                      @bobbythemoh I recommend u open an issue on the module GitHub page to engage the author. no guarantee they are looking at the forum
                                      B 1 Reply Last reply
                                        bobbythemoh @sdetweil
                                        @sdetweil thanks, i will do so!
                                        • 5 / 5
